Can't install any distro. Preinstalled neon freezes
Hi
Sounds a bit fishy, I think the installed Neon should not just crash after a while.
Can you boot from an SD-Card at all? Or is that how you took the screenshot?
If it is an SD-Card I would just try to write it again, that sometimes actually works.
Or try a different OS.
Also make sure to test more than one SD-card.
Otherwise I would look into a return.
RE: Can't install any distro. Preinstalled neon freezes - by Surehand53 - 07-22-2019, 10:32 PM
  Printer install icemeister 4 6,756 01-14-2020, 08:34 AM
  Firefox freezes Pinebook forcing hard reboot chris-justExploded 1 3,075 08-05-2019, 01:11 AM
Last Post: chris-justExploded
  Manpages fix on KDE neon? acruhl 7 9,547 11-18-2018, 12:49 PM
Last Post: cvmiller
  Poll: Which distro do you use for pinebook? erchache2000 2 5,157 09-12-2018, 12:36 AM
Last Post: Wizzard
