Pine64 Linux fixup script
(04-23-2016, 03:48 PM)longsleep Wrote: I am a friend of pragmatic solutions, so here is a very simple one to handle current and future fixes required on Pine64 without having to provide packaging.
So there is now a script which can be run on any Pine64 (Linux) any time, multiple times. The script will fix whatever needs fixing. Thus the script is called "pine64_fix_whatever.sh". The idea is that whenever some issue comes up, a solution can be added to this script, run it again and be good.
Fixes (in the order as they have been added):
- Pulseaudio stuttering by disable timer-based audio scheduling
The script is part of my platform-scripts at https://github.com/longsleep/build-pine6...rm-scripts.
You can simply run it like this on all Linux images (as root):
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_fix_whatever.sh)
And reboot afterwards.
I've wondered for a while now why some people favor this syntax over the simple, old-style pipe, e.g.,
curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_fix_whatever.sh | bash
Functionally, they're the same, and connecting processes with a pipe "|" doesn't make the shell mess with named pipes; it also isn't whitespace sensitive, while <(...) is, leading to possible error and confusion.
Pine64 Linux fixup script - by longsleep - 04-23-2016, 03:48 PM
RE: Pine64 Linux fixup script - by patrickhwood - 04-23-2016, 06:55 PM
RE: Pine64 Linux fixup script - by longsleep - 04-24-2016, 01:34 AM
RE: Pine64 Linux fixup script - by patrickhwood - 04-24-2016, 10:55 PM
  Programming languages support under PINE64 baryluk 6 12,433 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 9,312 03-28-2020, 06:20 PM
Last Post: ty1911
  Manjaro arm on pine64+ roel 2 5,955 10-19-2019, 05:13 AM
Last Post: roel
  Howto run Linux with resolution other than 1080p longsleep 28 66,878 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 5,146 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,294 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Volumio for PINE64 Released mikelangeloz 11 24,641 03-22-2019, 09:25 AM
Last Post: llungster
  Gentoo Linux test image xalius 23 48,856 01-28-2019, 11:05 PM
Last Post: necrose99
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 4,068 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 6,041 01-04-2019, 03:47 PM
Last Post: Max11
