Have eMMC adapter - but can't seem to fix eMMC card
Question
Hi - I had purchased two Rock64 boards, two 64GB eMMC chips and the USB adapter - got the image onto one of the cards using Balaena Etcher (been working great to get images on to microSD cards and the like). Went and re-formatted it after plugging it back into my Windows machine, went to reset an image - but now the eMMC card only appears as a 14.4 GB removable drive called "CARD" on drive E: and I can never seem to delete the partition, format the drive or anything else with it.
Things I've tried:
Volume manager and DISKPART on windows - all the way to deleting the partition - even forcing the delete
Plugged it into the Pi's USB port and using "sudo fdisk" and trying everything I could google to remove it to redo the drive to no avail.
The only thing that seems to show up now is a DOS partition that always has a "uupd.bin" file in it - and I can never reformat it. Is there something magical - or set of steps to get that rogue volume off the eMMC and back to where I can use it like the 64GB chip it is?
Is this chip lost for eternity or is there a way to really access it, blow it all away and redo it from scratch? Until I can figure something out I am afraid to take the other eMMC out of the bag.
Thanks!
Have eMMC adapter - but can't seem to fix eMMC card - by SirRyanTheGeek - 03-18-2019, 07:44 AM
Question Compatible eMMC modules and benchmarks danboid 7 14,606 03-09-2023, 08:14 AM
Last Post: arvendui
  DAC (ES9023) addon card on other SBCs like rpi? AlexS 1 2,204 08-28-2021, 04:53 AM
Last Post: CounterPillow
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 11,281 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
  Will Gert's VGA666 adapter work with the Rock64? Other display options? pcosm 0 1,737 05-03-2019, 01:32 AM
Last Post: pcosm
  emmc module help default_user8 1 2,888 04-05-2019, 07:19 PM
Last Post: SirRyanTheGeek
  Does the Pine usb to sata adapter work with hd-parm? FabrizioMaurizio 0 1,768 02-06-2019, 11:37 AM
Last Post: FabrizioMaurizio
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD and USB serial adapter for Pine64 jovval 2 3,780 12-01-2018, 03:53 AM
Last Post: jovval
  Dead eMMC? machina 8 9,249 11-21-2018, 05:05 AM
Last Post: machina
  FORSEE eMMC is reliable? ramprasad 3 5,100 11-12-2018, 03:34 PM
Last Post: Tortax
  50 kb with RTL8188eu WIFI adapter Juice4 2 3,567 11-09-2018, 12:56 PM
Last Post: Juice4
