GPIO in sleep mode
There is a 4 Pin JST Connector just behind the Power DC Jack .... its directly connected to the power rail ... you could rig a simple circuit up completely independent of the GPIO using a 555 Timer some resistors, a tranny and and capacitors etc even safer install your own buck converted to drop the voltage down to be even saver. But I take it you wanted GPIO / PWM to avoid the complicated electronics !
GPIO in sleep mode - by Mentaluproar - 02-18-2019, 03:27 AM
RE: GPIO in sleep mode - by axelf - 04-08-2019, 03:06 PM
RE: GPIO in sleep mode - by Mentaluproar - 04-08-2019, 03:50 PM
  External Touchscreen via DP-Alt Mode soloquintett 0 789 05-01-2023, 12:29 PM
Last Post: soloquintett
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,651 11-18-2022, 10:20 AM
Last Post: colinmarc
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,454 07-18-2022, 10:05 PM
Last Post: zer0sig
  Using GPIO interrupts antonlyap 3 3,723 06-30-2021, 01:32 PM
Last Post: antonlyap
  GPIO performance 100x slower compared to Raspberry Pi 3 axelf 9 9,785 08-19-2020, 04:41 PM
Last Post: Gienek
  Make SD Card to read-only mode rahulsharma 1 2,163 11-04-2019, 11:42 AM
Last Post: Nikolay_Po
