Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities
#23
(03-04-2019, 02:48 PM)Neo2018 Wrote:
(03-04-2019, 11:08 AM)tuxd3v Wrote: Does you like the disks always in max performance?
O noticed that yours is in APM level 254 ( max performance.. )
The 4TB Seagate discs are mostly used for watching movies (DLNA, Plex and data backup like Nextcloud). Otherwise, the hard drive is sleeping.
The 500GB disc is 24/7 in operation.
Where did you see that? > O noticed that yours is in APM level 254 ( max performance.. )
I use OMV with these settings > [Image: 2R3Yf.jpg]
I saw here
=== START OF INFORMATION SECTION ===
Model Family:     Seagate IronWolf
Device Model:     ST4000VN008-xxxxxx
Serial Number:    xxxxxxxx
LU WWN Device Id: xxxxxxxxxxxxxxxxxxx
Firmware Version: SC60
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5980 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Mar  2 18:28:35 2019 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM level is:     254 (maximum performance)
I have mines in mode 127,
Since it has no operating system running there, it will enter later in APM mode 1( StandBy )..
There exists a lag on first access, but after they are working fast, and a great part of the day, I am not using the Nas, so its nice
The disk is presented like normal to the OS, don't know why is hasn't worked
your /dev/sdb should have spits something out with or something else..
openSeaChest_Basics -d  /dev/sdb -i -v 4
To check the pcie controller:
dmesg|grep -Ei "ahci|pcie" --color
what is the output?
With usb adapter you should be ok then.
RE: Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities - by tuxd3v - 03-04-2019, 07:46 PM
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 10,097 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 4,416 01-17-2021, 11:33 AM
  Tutorial:How to Configure ATS Fan control tuxd3v 26 53,730 11-06-2020, 08:56 PM
Last Post: g_t_j
  Serial Connection Tutorial: FTDI 232RL hmuller 0 3,288 10-23-2020, 11:56 AM
Last Post: hmuller
Video How to Install Google PlayStore NightCrawler504 2 5,374 04-08-2020, 02:20 PM
Last Post: pino88
Wink Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment tuxd3v 14 24,353 06-19-2019, 04:40 AM
Last Post: Neo2018
Video Video and Guide to install Android to emmc no emmc to usb adapter NightCrawler504 0 3,394 04-21-2019, 07:19 PM
Last Post: NightCrawler504
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 2,757 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 3,996 11-06-2018, 01:03 PM
Last Post: tuxd3v
  HOW TO - install linux on emmc without etcher or USB adapter dukla2000 4 10,632 07-31-2018, 12:40 PM
Last Post: dukla2000
