03-02-2019, 01:40 PM
(03-02-2019, 01:27 PM)Neo2018 Wrote:(03-02-2019, 01:01 PM)tuxd3v Wrote: Try:The same thing >
Code:openSeaChest_Basics --scan --scanFlags interfaceSCSI interfaceATA interfaceUSB sd ata scsi -V 4
Code::~# openSeaChest_Basics --scan --scanFlags interfaceSCSI interfaceATA interfaceUSB sd ata scsi -V 4
openSeaChest_Basics - openSeaChest drive utilities - NVMe Enabled
Copyright (c) 2014-2018 Seagate Technology LLC and/or its Affiliates, All Rights Reserved
openSeaChest_Basics Version: 2.8.0-1_19_0 ARM
Build Date: Feb 28 2019
Today: Sat Mar 2 20:18:59 2019
Version Info for openSeaChest_Basics:
Utility Version: 2.8.0
opensea-common Version: 1.18.0
opensea-transport Version: 1.19.0
opensea-operations Version: 1.20.0
Compiled Architecture: ARM
Detected Endianness: Little Endian
Compiler Used: GCC
Compiler Version: 6.3.0
Operating System Type: Linux
Operating System Version: 4.4.154-1132
Operating System Name: Debian GNU/Linux 9 (stretch)
open: Bad address
open failure
Error: 14 - Bad address
open: Bad address
open failure
If you don't succeed, try with option.. scan but with 'S' -> --Scan
Code:openSeaChest_Basics --Scan --scanFlags interfaceSCSI interfaceATA interfaceUSB sd ata scsi -V 4
Code::~# openSeaChest_Basics --Scan --scanFlags interfaceSCSI interfaceATA interfaceUSB sd ata scsi -V 4
Today: Sat Mar 2 20:22:40 2019
Compiler Used: GCC
open: Bad address
open failure
open: Bad address
open failure
Assuming the binaries are ok,
My best bet is that maybe you need to insert the disks in a real Sata port, for example, to enable Power Up in StandBy and SpinUp Control..
