Android flashed, SD card shows empty?
(04-24-2016, 12:52 AM)Tarjei85 Wrote: Not shire if it is the correct answer but the filesystem for Android (ext2, ext3, ext4) is NOT possible to show in Windows. This is a linux-filesystem so I guess you can get it to show if you use linux.
If anybody can verify or correct me it would be nice.
You are correct, the Android and Linux build are on EXT4 format. Windows will not display EXT4 partition.
RE: Android flashed, SD card shows empty? - by tllim - 04-24-2016, 02:56 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 391,983 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 30,032 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 17,014 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,050 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,121 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,662 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,372 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 261,342 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,580 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 106,143 02-10-2019, 07:44 PM
Last Post: mmmarcus
