Use a iMac as Monitor
(04-19-2016, 10:57 AM)SirLenuxx Wrote: Then i need to buy a new screen
Why? 'It might (not) work also implies the opposite' Smile
I just don't know. The older 21" iMacs have a 1080p resolution (that's what Pine64 prefers) and customers use them as displays for nearly everything. But according to many reports here in the forums the Pine64 seems somewhat picky.
I still suspect that the HDMI issue we currently face with the BSP kernel currently used with every OS image is something similar as we had with the Ethernet driver: Allwinner delivered untested 32-bit code and when the 2GB Pine64 models connected an Ethernet cable the driver has been loaded and immediately crashed due to an integer overflow. And I would suspect it's something similar with HDMI: small bug (that is easy to fix) --> crashed driver --> no display.
But unfortunately the people running into this issue are not even thinking about starting to debug or at least look whether something crashed or not. So it's somewhat unlikely that any progress will be made the next time.
Use a iMac as Monitor - by SirLenuxx - 04-19-2016, 10:39 AM
RE: Use a iMac as Monitor - by tkaiser - 04-19-2016, 10:50 AM
RE: Use a iMac as Monitor - by SirLenuxx - 04-19-2016, 10:57 AM
RE: Use a iMac as Monitor - by tkaiser - 04-19-2016, 11:08 AM
RE: Use a iMac as Monitor - by tllim - 04-19-2016, 09:15 PM
Sad Any OS for 2K Monitor? sercancayir 3 4,669 02-20-2018, 04:21 AM
Last Post: sercancayir
  Rezize Monitor ? Spore 1 2,785 02-28-2017, 09:51 PM
Last Post: MarkHaysHarris777
