Set Static IP
(04-19-2016, 01:10 PM)rakib-hasan Wrote: Please do not just uninstall a software from your system just on a guess from someone else. If you have Network Manager installed, use it with the right settings and read the corresponding articles in the ubuntu-wiki if unsure what to do.
If Network Manager is not installed your problem has another reason...
You are right. I was just suggesting that because he was already re-imaging the sd card over and over anyway to do this.
I forgot to mention that I was also successful of changing the IP by using the network manager from the taskbar (if you have a monitor connected to it). But to do this via terminal, I had to uninstall the network manager.
[/quote]
There also is a documentation to use the correct settings in NM via console.....
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
Set Static IP - by JCMPine64 - 04-19-2016, 07:58 AM
RE: Set Static IP - by rakib-hasan - 04-19-2016, 11:48 AM
RE: Set Static IP - by JCMPine64 - 04-19-2016, 12:41 PM
RE: Set Static IP - by androsch - 04-19-2016, 01:01 PM
RE: Set Static IP - by rakib-hasan - 04-19-2016, 01:10 PM
RE: Set Static IP - by androsch - 04-19-2016, 01:24 PM
RE: Set Static IP - by JCMPine64 - 05-04-2016, 08:24 PM
Set Static IP - by Leoncito81 - 05-05-2016, 05:32 AM
RE: Set Static IP - by JCMPine64 - 05-05-2016, 08:34 AM
RE: Set Static IP - by tkaiser - 05-05-2016, 08:44 AM
RE: Set Static IP - by JCMPine64 - 05-05-2016, 09:06 AM
RE: Set Static IP - by tkaiser - 05-05-2016, 09:26 AM
RE: Set Static IP - by JCMPine64 - 05-05-2016, 10:31 AM
RE: Set Static IP - by JCMPine64 - 05-06-2016, 07:50 AM
RE: Set Static IP - by tkaiser - 05-06-2016, 08:02 AM
RE: Set Static IP - by JCMPine64 - 05-06-2016, 08:08 AM
Set Static IP - by Leoncito81 - 05-06-2016, 09:53 AM
RE: Set Static IP - by JCMPine64 - 05-06-2016, 10:05 AM
RE: Set Static IP - by tkaiser - 05-06-2016, 10:14 AM
RE: Set Static IP - by JCMPine64 - 05-06-2016, 10:33 AM
RE: Set Static IP - by g_t_j - 05-31-2016, 07:09 AM
RE: Set Static IP - by Inuyasha - 05-31-2016, 07:34 AM
RE: Set Static IP - by g_t_j - 05-31-2016, 08:24 AM
RE: Set Static IP - by Inuyasha - 05-31-2016, 08:44 AM
RE: Set Static IP - by g_t_j - 05-31-2016, 09:41 AM
RE: Set Static IP - by Inuyasha - 05-31-2016, 11:36 AM
