Set Static IP
#22
(05-31-2016, 07:09 AM)g_t_j Wrote: Hi all,
I want to set a static IP on my Pine running latest Android build. There is a sub menu for setting an IP on WiFi but there's no option if you use wired connection.
For that reason, I have successfully connected my Pine to my Windows PC via SSH client but trying to edit /etc/network/interfaces returns command not found.
What am I doing wrong?
One workaround would be to assign an IP address to the board's MAC address in your router's settings, provided you have access to the settings. I'm still waiting on my board, but have done this with several other devices(printers, NAS, security camera DVR, etc.) on my network with no issues.
Set Static IP - by JCMPine64 - 04-19-2016, 07:58 AM
RE: Set Static IP - by rakib-hasan - 04-19-2016, 11:48 AM
RE: Set Static IP - by JCMPine64 - 04-19-2016, 12:41 PM
RE: Set Static IP - by androsch - 04-19-2016, 01:01 PM
RE: Set Static IP - by rakib-hasan - 04-19-2016, 01:10 PM
RE: Set Static IP - by androsch - 04-19-2016, 01:24 PM
RE: Set Static IP - by JCMPine64 - 05-04-2016, 08:24 PM
Set Static IP - by Leoncito81 - 05-05-2016, 05:32 AM
RE: Set Static IP - by JCMPine64 - 05-05-2016, 08:34 AM
RE: Set Static IP - by tkaiser - 05-05-2016, 08:44 AM
RE: Set Static IP - by JCMPine64 - 05-05-2016, 09:06 AM
RE: Set Static IP - by tkaiser - 05-05-2016, 09:26 AM
RE: Set Static IP - by JCMPine64 - 05-05-2016, 10:31 AM
RE: Set Static IP - by JCMPine64 - 05-06-2016, 07:50 AM
RE: Set Static IP - by tkaiser - 05-06-2016, 08:02 AM
RE: Set Static IP - by JCMPine64 - 05-06-2016, 08:08 AM
Set Static IP - by Leoncito81 - 05-06-2016, 09:53 AM
RE: Set Static IP - by JCMPine64 - 05-06-2016, 10:05 AM
RE: Set Static IP - by tkaiser - 05-06-2016, 10:14 AM
RE: Set Static IP - by JCMPine64 - 05-06-2016, 10:33 AM
RE: Set Static IP - by g_t_j - 05-31-2016, 07:09 AM
RE: Set Static IP - by Inuyasha - 05-31-2016, 07:34 AM
RE: Set Static IP - by g_t_j - 05-31-2016, 08:24 AM
RE: Set Static IP - by Inuyasha - 05-31-2016, 08:44 AM
RE: Set Static IP - by g_t_j - 05-31-2016, 09:41 AM
RE: Set Static IP - by Inuyasha - 05-31-2016, 11:36 AM
