Did anyone succeeded with NetBSD
I have the latest version of NetBSD from https://www.invisible.ca/arm/
Unfortunately, the system will not start.
Is it possible to boot system from emmc?
Here's my log
Abe
DDR Version 1.19 20190305
In
channel 0
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
OUT
U-Boot SPL board init
U-Boot SPL 2017.09-rockchip-ayufan-1062-gbb4886a528 (Jun 19 2019 - 19:41:49)
booted from SPI flash
Trying to boot from SPI
NOTICE:  BL31: v1.3(debug):370ab80
NOTICE:  BL31: Built : 09:23:41, Mar  4 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1181): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-rockchip-ayufan-1062-gbb4886a528 (Jun 19 2019 - 19:41:56 +0000)
Model: Pine64 RockPro64
DRAM:  3.9 GiB
DCDC_REG1@vdd_center: ; enabling
DCDC_REG2@vdd_cpu_l: ; enabling
DCDC_REG3@vcc_ddr: ; enabling (ret: -38)
DCDC_REG4@vcc_1v8: set 1800000 uV; enabling
LDO_REG1@vcc1v8_dvp: set 1800000 uV; enabling
LDO_REG2@vcc3v0_touch: set 3000000 uV; enabling
LDO_REG3@vcc1v8_pmu: set 1800000 uV; enabling
LDO_REG4@vcc_sd: set 3300000 uV; enabling
LDO_REG5@vcca3v0_codec: set 3000000 uV; enabling
LDO_REG6@vcc_1v5: set 1500000 uV; enabling
LDO_REG7@vcca1v8_codec: set 1800000 uV; enabling
LDO_REG8@vcc_3v0: set 3000000 uV; enabling
SWITCH_REG1@vcc3v3_s3: ; enabling (ret: -38)
SWITCH_REG2@vcc3v3_s0: ; enabling (ret: -38)
vcc1v8-s0@vcc1v8_s0: set 1800000 uV; enabling (ret: -38)
dc-12v@dc_12v: set 12000000 uV; enabling (ret: -38)
vcc-sys@vcc_sys: set 5000000 uV; enabling (ret: -38)
vcc3v3-sys@vcc3v3_sys: set 3300000 uV; enabling (ret: -38)
vcc-phy-regulator@vcc_phy: ; enabling (ret: -38)
vdd-log@vdd_log: ; enabling (ret: -38)
MMC:   sdhci@fe330000: 0, dwmmc@fe320000: 1
SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
In:    serial@ff1a0000
Out:   serial@ff1a0000
Err:   serial@ff1a0000
Net:   eth0: ethernet@fe300000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
reading /dtb/rockchip/rk3399-rockpro64.dtb
78622 bytes read in 26 ms (2.9 MiB/s)
Found EFI removable media binary efi/boot/bootaa64.efi
reading efi/boot/bootaa64.efi
200728 bytes read in 38 ms (5 MiB/s)
## Starting EFI application at 02000000 ...
Scanning disk sdhci@fe330000.blk...
Card did not respond to voltage select!
mmc_init: -95, time 9
Scanning disk dwmmc@fe320000.blk...
MMC: block number 0x1 exceeds max(0x0)
MMC: block number 0x44 exceeds max(0x0)
Found 2 disks
>> NetBSD/evbarm EFI Boot (aarch64), Revision 1.9 (Fri Jun 21 16:57:12 UTC 2019) (from NetBSD 8.99.47)
Press return to boot now, any other key for boot prompt
booting netbsd - starting in 5 seconds. 4 seconds. 3 seconds. 2 seconds. 1 seconds. 0 seconds.
\|/-\|/-\|/-\6001728|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/+2667864-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-+1776700\|/-\|/-\|/-\|/-\|/-\|/-\|/-\+1824332|/ [730104-\|/-\|/-\|/+501197-\|/-\|]=0xe9c748
[   1.0000000] NetBSD/evbarm (fdt) booting ...
[   1.0000000] Copyright (c) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005,
[   1.0000000]     2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016, 2017,
[   1.0000000]     2018, 2019 The NetBSD Foundation, Inc.  All rights reserved.
[   1.0000000] Copyright (c) 1982, 1986, 1989, 1991, 1993
[   1.0000000]     The Regents of the University of California.  All rights reserved.
[   1.0000000] NetBSD 8.99.47 (GENERIC64) #0: Fri Jun 21 16:57:12 UTC 2019
[   1.0000000] mkrepro@mkrepro.NetBSD.org:/usr/src/sys/arch/evbarm/compile/GENERIC64
[   1.0000000] total memory = 3952 MB
[   1.0000000] avail memory = 3810 MB
[   1.0000000] armfdt0 (root)
[   1.0000000] simplebus0 at armfdt0: Pine64 RockPro64
[   1.0000000] cpus0 at simplebus0
[   1.0000000] simplebus1 at simplebus0
[   1.0000000] simplebus2 at simplebus0
[   1.0000000] cpu0 at cpus0: Cortex-A53 r0p4 (Cortex V8-A core)
[   1.0000000] cpu0: package 0, core 0, smt 0
[   1.0000000] cpu0: IC enabled, DC enabled, EL0/EL1 stack Alignment check enabled
[   1.0000000] cpu0: Cache Writeback Granule 16B, Exclusives Reservation Granule 16B
[   1.0000000] cpu0: Dcache line 64, Icache line 64
[   1.0000000] cpu0: L1 32KB/64B 2-way read-allocate VIPT Instruction cache
[   1.0000000] cpu0: L1 32KB/64B 4-way write-back read-allocate write-allocate PIPT Data cache
[   1.0000000] cpu0: L2 512KB/64B 16-way write-back read-allocate write-allocate PIPT Unified cache
[   1.0000000] cpu0: revID=0x180, PMCv3, 4k table, 64k table, 16bit ASID
[   1.0000000] cpu0: auxID=0x11120, GICv3, FP, CRC32, SHA1, SHA256, AES+PMULL, NEON, rounding, NaN propagation, denormals, 32x64bitRegs, Fused Multiply-Add
[   1.0000000] cpufreqdt0 at cpu0
[   1.0000000] cpu1 at cpus0: Cortex-A53 r0p4 (Cortex V8-A core)
[   1.0000000] cpu1: package 0, core 1, smt 0
[   1.0000000] cpufreqdt1 at cpu1
[   1.0000000] cpu2 at cpus0: Cortex-A53 r0p4 (Cortex V8-A core)
[   1.0000000] cpu2: package 0, core 2, smt 0
[   1.0000000] cpufreqdt2 at cpu2
[   1.0000000] cpu3 at cpus0: Cortex-A53 r0p4 (Cortex V8-A core)
[   1.0000000] cpu3: package 0, core 3, smt 0
[   1.0000000] cpufreqdt3 at cpu3
[   1.0000000] cpu4 at cpus0: Cortex-A72 r0p2 (Cortex V8-A core)
[   1.0000000] cpu4: package 1, core 0, smt 0
[   1.0000000] cpufreqdt4 at cpu4
[   1.0000000] cpu5 at cpus0: Cortex-A72 r0p2 (Cortex V8-A core)
[   1.0000000] cpu5: package 1, core 1, smt 0
[   1.0000000] cpufreqdt5 at cpu5
[   1.0000000] gicvthree0 at simplebus0: GICv3
[   1.0000000] gicvthree0: ITS TT0 type 0x1 size 0x80000
[   1.0000000] syscon0 at simplebus0: System Controller Registers
[   1.0000000] syscon1 at simplebus0: System Controller Registers
[   1.0000000] fclock0 at simplebus0: 125000000 Hz fixed clock (clkin_gmac)
[   1.0000000] syscon2 at simplebus0: System Controller Registers
[   1.0000000] syscon3 at simplebus0: System Controller Registers
[   1.0000000] syscon4 at simplebus0: System Controller Registers
[   1.0000000] syscon5 at simplebus0: System Controller Registers
[   1.0000000] syscon6 at simplebus0: System Controller Registers
[   1.0000000] syscon7 at simplebus0: System Controller Registers
[   1.0000000] syscon8 at simplebus0: System Controller Registers
[   1.0000000] syscon9 at simplebus0: System Controller Registers
[   1.0000000] syscon10 at simplebus0: System Controller Registers
[   1.0000000] syscon11 at simplebus0: System Controller Registers
[   1.0000000] syscon12 at simplebus0: System Controller Registers
[   1.0000000] syscon13 at simplebus0: System Controller Registers
[   1.0000000] syscon14 at simplebus0: System Controller Registers
[   1.0000000] syscon15 at simplebus0: System Controller Registers
[   1.0000000] syscon16 at simplebus0: System Controller Registers
[   1.0000000] syscon17 at simplebus0: System Controller Registers
[   1.0000000] syscon18 at simplebus0: System Controller Registers
[   1.0000000] syscon19 at simplebus0: System Controller Registers
[   1.0000000] syscon20 at simplebus0: System Controller Registers
[   1.0000000] syscon21 at simplebus0: System Controller Registers
[   1.0000000] syscon22 at simplebus0: System Controller Registers
[   1.0000000] syscon23 at simplebus0: System Controller Registers
[   1.0000000] fclock1 at simplebus0: 24000000 Hz fixed clock (xin24m)
[   1.0000000] syscon24 at simplebus0: System Controller Registers
[   1.0000000] syscon25 at simplebus0: System Controller Registers
[   1.0000000] syscon26 at simplebus0: System Controller Registers
[   1.0000000] syscon27 at simplebus0: System Controller Registers
[   1.0000000] gtmr0 at simplebus0: Generic Timer
[   1.0000000] gtmr0: interrupting on GICv3 irq 27
[   1.0000000] armgtmr0 at gtmr0: ARM Generic Timer (24000 kHz)
[   1.0000060] rkcru0 at simplebus0: RK3399 CRU
[   1.0000060] rkcru1 at simplebus0: RK3399 PMU CRU
[   1.0000060] rkiomux0 at simplebus0: RK3399 IOMUX control
[   1.0000060] rkgpio0 at rkiomux0: GPIO (gpio0@ff720000)
[   1.0000060] gpio0 at rkgpio0: 32 pins
[   1.0000060] rkgpio1 at rkiomux0: GPIO (gpio1@ff730000)
[   1.0000060] gpio1 at rkgpio1: 32 pins
[   1.0000060] rkgpio2 at rkiomux0: GPIO (gpio2@ff780000)
[   1.0000060] gpio2 at rkgpio2: 32 pins
[   1.0000060] rkgpio3 at rkiomux0: GPIO (gpio3@ff788000)
[   1.0000060] gpio3 at rkgpio3: 32 pins
[   1.0000060] rkgpio4 at rkiomux0: GPIO (gpio4@ff790000)
[   1.0000060] gpio4 at rkgpio4: 32 pins
[   1.0000060] rkpwm0 at simplebus0: PWM
[   1.0000060] rkpwm1 at simplebus0: PWM
[   1.0000060] rkpwm2 at simplebus0: PWM
[   1.0000060] fregulator0 at simplebus0: vcc3v3_pcie
[   1.0000060] fregulator1 at simplebus0: vcc1v8_s3
[   1.0000060] fregulator2 at simplebus0: vcc5v0_sys
[   1.0000060] fregulator3 at simplebus0: vcc3v3_sys
[   1.0000060] fregulator4 at simplebus0: vcc5v0_typec
[   1.0000060] fregulator5 at simplebus0: vcc5v0_host
[   1.0000060] fregulator6 at simplebus0: vcc12v_dcin
[   1.0000060] fregulator7 at simplebus0: vcc5v0_usb
[   1.0000060] com0 at simplebus0: ns16550a, working fifo
[   1.0000060] com0: interrupting on GICv3 irq 131
[   1.0000060] com1 at simplebus0: ns16550a, working fifo
[   1.0000060] com1: console
[   1.0000060] com1: interrupting on GICv3 irq 132
[   1.0000060] rkpciephy0 at syscon0: RK3399 PCIe PHY
[   1.0000060] rkusb0 at syscon0: USB2 PHY
[   1.0000060] rkusbphy0 at rkusb0: USB2 host port
[   1.0000060] rkusbphy1 at rkusb0: USB2 OTG port
[   1.0000060] rkusb1 at syscon0: USB2 PHY
[   1.0000060] rkusbphy2 at rkusb1: USB2 host port
[   1.0000060] rkusbphy3 at rkusb1: USB2 OTG port
[   1.0000060] /opp-table0 at simplebus0 not configured
[   1.0000060] rkiic0 at simplebus0: Rockchip I2C (400000 Hz)
[   1.0000060] iic0 at rkiic0: I2C bus
[   1.0000060] rkpmic0 at iic0 addr 0x1b: RK808 Power Management IC
[   1.0000060] rkreg0 at rkpmic0: vdd_center
[   1.0000060] rkreg1 at rkpmic0: vdd_cpu_l
[   1.0000060] rkreg2 at rkpmic0: vcc_ddr
[   1.0000060] rkreg3 at rkpmic0: vcc_1v8
[   1.0000060] rkreg4 at rkpmic0: vcc1v8_dvp
[   1.0000060] rkreg5 at rkpmic0: vcc3v0_touch
[   1.0000060] rkreg6 at rkpmic0: vcca_1v8
[   1.0000060] rkreg7 at rkpmic0: vcc_sdio
[   1.0000060] rkreg8 at rkpmic0: vcca3v0_codec
[   1.0000060] rkreg9 at rkpmic0: vcc_1v5
[   1.0000060] rkreg10 at rkpmic0: vcca1v8_codec
[   1.0000060] rkreg11 at rkpmic0: vcc_3v0
[   1.0000060] rkreg12 at rkpmic0: vcc3v3_s3
[   1.0000060] rkreg13 at rkpmic0: vcc3v3_s0
[   1.0000060] fan53555reg0 at iic0 addr 0x40: Silergy SYR82X
[   1.0000060] fan53555reg1 at iic0 addr 0x41: Silergy SYR82X
[   1.0000060] /opp-table1 at simplebus0 not configured
[   1.0000060] /vop@ff8f0000 at simplebus0 not configured
[   1.0000060] /vop@ff900000 at simplebus0 not configured
[   1.0000060] rkpcie0 at simplebus0: RK3399 PCIe
[   1.0000060] rkpcie0: link training timeout (link_st 0)
[   1.0000060] /power-management@ff310000/power-controller at syscon1 not configured
[   1.0000060] rkemmcphy0 at syscon0: eMMC PHY
[   1.0000060] /phy@ff7c0000 at simplebus0 not configured
[   1.0000060] /phy@ff800000 at simplebus0 not configured
[   1.0000060] /amba/dma-controller@ff6e0000 at simplebus1 not configured
[   1.0000060] /amba/dma-controller@ff6d0000 at simplebus1 not configured
[   1.0000060] rktsadc0 at simplebus0: RK3328/3399 Temperature Sensor ADC
[   1.0000060] rktsadc0: interrupting on GICv3 irq 129
[   1.0000060] /iommu@ff650800 at simplebus0 not configured
[   1.0000060] sdhc0 at simplebus0: Arasan SDHCI controller
[   1.0000060] sdhc0: interrupting on GICv3 irq 43
[   1.0000060] sdhc0: SDHC 3.0, rev 16, 32-bit ADMA2, 200000 kHz, embedded slot, HS SDR50 DDR50 SDR104 HS200 1.8V, re-tuning mode 1, 1024 byte blocks
[   1.0000060] sdmmc0 at sdhc0 slot 0
[   1.0000060] /iommu@ff8f3f00 at simplebus0 not configured
[   1.0000060] /hdmi@ff940000 at simplebus0 not configured
[   1.0000060] /iommu@ff903f00 at simplebus0 not configured
[   1.0000060] /i2s@ff8a0000 at simplebus0 not configured
[   1.0000060] rkiic1 at simplebus0: Rockchip I2C (100000 Hz)
[   1.0000060] iic1 at rkiic1: I2C bus
[   1.0000060] /opp-table2 at simplebus0 not configured
[   1.0000060] awge0 at simplebus0: GMAC
[   1.0000060] awge0: Core version: 00001035
[   1.0000060] awge0: Ethernet address 56:6f:82:69:e7:22
[   1.0000060] awge0: HW feature mask: d0f17
[   1.0000060] rgephy0 at awge0 phy 0: RTL8211F 1000BASE-T media interface
[   1.0000060] rgephy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT-FDX, auto
[   1.0000060] rgephy1 at awge0 phy 1: RTL8211F 1000BASE-T media interface
[   1.0000060] rgephy1: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT-FDX, auto
[   1.0000060] awge0: interrupting on GICv3 irq 44
[   1.0000060] dwcmmc0 at simplebus0: DesignWare SD/MMC
[   1.0000060] dwcmmc0: interrupting on GICv3 irq 97
[   1.0000060] ehci0 at simplebus0: EHCI
[   1.0000060] ehci0: interrupting on GICv3 irq 58
[   1.0000060] ehci0: 1 companion controller, 1 port
[   1.0000060] usb0 at ehci0: USB revision 2.0
[   1.0000060] ohci0 at simplebus0: OHCI
[   1.0000060] ohci0: interrupting on GICv3 irq 60
[   1.0000060] ohci0: OHCI version 1.0
[   1.0000060] usb1 at ohci0: USB revision 1.0
[   1.0000060] ehci1 at simplebus0: EHCI
[   1.0000060] ehci1: interrupting on GICv3 irq 62
[   1.0000060] ehci1: 1 companion controller, 1 port
[   1.0000060] usb2 at ehci1: USB revision 2.0
[   1.0000060] ohci1 at simplebus0: OHCI
[   1.0000060] ohci1: interrupting on GICv3 irq 64
[   1.0000060] ohci1: OHCI version 1.0
[   1.0000060] usb3 at ohci1: USB revision 1.0
[   1.0000060] xhci0 at simplebus0: 'otg' not supported
[   1.0000060] xhci1 at simplebus0: DesignWare USB3 XHCI (rev. 3.00a)
[   1.0000060] xhci1: interrupting on GICv3 irq 142
[   1.0000060] usb4 at xhci1: USB revision 3.0
[   1.0000060] usb5 at xhci1: USB revision 2.0
[   1.0000060] /saradc@ff100000 at simplebus0 not configured
[   1.0000060] rkiic2 at simplebus0: Rockchip I2C (100000 Hz)
[   1.0000060] iic2 at rkiic2: I2C bus
[   1.0000060] /syscon@ff320000/io-domains at syscon23 not configured
[   1.0000060] rkiic3 at simplebus0: Rockchip I2C (100000 Hz)
[   1.0000060] iic3 at rkiic3: I2C bus
[   1.0000060] typec-portc at iic3 addr 0x22 not configured
[   1.0000060] /video-codec@ff650000 at simplebus0 not configured
[   1.0000060] /rga@ff680000 at simplebus0 not configured
[   1.0000060] /efuse@ff690000 at simplebus0 not configured
[   1.0000060] /syscon@ff770000/io-domains at syscon0 not configured
[   1.0000060] /rktimer@ff850000 at simplebus0 not configured
[   1.0000060] /i2s@ff880000 at simplebus0 not configured
[   1.0000060] /i2s@ff890000 at simplebus0 not configured
[   1.0000060] /gpu@ff9a0000 at simplebus0 not configured
[   1.0000060] mmcpwrseq0 at simplebus0: couldn't acquire ext_clock
[   1.0000060] /vdd-log at simplebus0 not configured
[   1.0000060] /display-subsystem at simplebus0 not configured
[   1.0000060] armpmu0 at simplebus0: Performance Monitor Unit
[   1.0000060] armpmu1 at simplebus0: Performance Monitor Unit
[   1.0000060] psci0 at simplebus0: PSCI 1.0
[   1.0000060] /watchdog@ff848000 at simplebus0 not configured
[   1.0000060] gpiokeys0 at simplebus0: GPIO Key Power
[   1.0000060] gpioleds0 at simplebus0: work diy
[   1.0000060] pwmfan0 at simplebus0: PWM Fan (levels 0% 58% 76% 94%)
[   1.0000060] cpu1: IC enabled, DC enabled, EL0/EL1 stack Alignment check enabled
[   1.0000060] cpu1: Cache Writeback Granule 16B, Exclusives Reservation Granule 16B
[   1.0000060] cpu1: Dcache line 64, Icache line 64
[   1.0000060] cpu1: L1 32KB/64B 2-way read-allocate VIPT Instruction cache
[   1.0000060] cpu1: L1 32KB/64B 4-way write-back read-allocate write-allocate PIPT Data cache
[   1.0000060] cpu1: L2 512KB/64B 16-way write-back read-allocate write-allocate PIPT Unified cache
[   1.0000060] cpu1: revID=0x180, PMCv3, 4k table, 64k table, 16bit ASID
[   1.0000060] cpu1: auxID=0x11120, GICv3, FP, CRC32, SHA1, SHA256, AES+PMULL, NEON, rounding, NaN propagation, denormals, 32x64bitRegs, Fused Multiply-Add
[   1.0000060] cpu3: IC enabled, DC enabled, EL0/EL1 stack Alignment check enabled
[   1.0000060] cpu3: Cache Writeback Granule 16B, Exclusives Reservation Granule 16B
[   1.0000060] cpu3: Dcache line 64, Icache line 64
[   1.0000060] cpu3: L1 32KB/64B 2-way read-allocate VIPT Instruction cache
[   1.0000060] cpu3: L1 32KB/64B 4-way write-back read-allocate write-allocate PIPT Data cache
[   1.0000060] cpu3: L2 512KB/64B 16-way write-back read-allocate write-allocate PIPT Unified cache
[   1.0000060] cpu3: revID=0x180, PMCv3, 4k table, 64k table, 16bit ASID
[   1.0000060] cpu3: auxID=0x11120, GICv3, FP, CRC32, SHA1, SHA256, AES+PMULL, NEON, rounding, NaN propagation, denormals, 32x64bitRegs, Fused Multiply-Add
[   1.7613220] cpu2: IC enabled, DC enabled, EL0/EL1 stack Alignment check enabled
[   1.7613220] cpu2: Cache Writeback Granule 16B, Exclusives Reservation Granule 16B
[   1.7613220] cpu2: Dcache line 64, Icache line 64
[   1.7613220] cpu2: L1 32KB/64B 2-way read-allocate VIPT Instruction cache
[   1.7613220] cpu2: L1 32KB/64B 4-way write-back read-allocate write-allocate PIPT Data cache
[   1.7613220] cpu2: L2 512KB/64B 16-way write-back read-allocate write-allocate PIPT Unified cache
[   1.7613220] cpu2: revID=0x180, PMCv3, 4k table, 64k table, 16bit ASID
[   1.7613220] cpu2: auxID=0x11120, GICv3, FP, CRC32, SHA1, SHA256, AES+PMULL, NEON, rounding, NaN propagation, denormals, 32x64bitRegs, Fused Multiply-Add
[   1.7613220] cpu5: IC enabled, DC enabled, EL0/EL1 stack Alignment check enabled
[   1.7613220] cpu5: Cache Writeback Granule 16B, Exclusives Reservation Granule 16B
[   1.7613220] cpu5: Dcache line 64, Icache line 64
[   1.7613220] cpu5: L1 48KB/64B 3-way read-allocate PIPT Instruction cache
[   1.7613220] cpu5: L1 32KB/64B 2-way write-back read-allocate write-allocate PIPT Data cache
[   1.7613220] cpu5: L2 1024KB/64B 16-way write-back read-allocate write-allocate PIPT Unified cache
[   1.7713142] cpu5: revID=0x4, PMCv3, 4k table, 64k table, 16bit ASID
[   1.7713142] cpu5: auxID=0x11120, GICv3, FP, CRC32, SHA1, SHA256, AES+PMULL, NEON, rounding, NaN propagation, denormals, 32x64bitRegs, Fused Multiply-Add
[   1.7713142] cpu4: IC enabled, DC enabled, EL0/EL1 stack Alignment check enabled
[   1.7713142] cpu4: Cache Writeback Granule 16B, Exclusives Reservation Granule 16B
[   1.7713142] cpu4: Dcache line 64, Icache line 64
[   1.7713142] cpu4: L1 48KB/64B 3-way read-allocate PIPT Instruction cache
[   1.7713142] cpu4: L1 32KB/64B 2-way write-back read-allocate write-allocate PIPT Data cache
[   1.7713142] cpu4: L2 1024KB/64B 16-way write-back read-allocate write-allocate PIPT Unified cache
[   1.7713142] cpu4: revID=0x4, PMCv3, 4k table, 64k table, 16bit ASID
[   1.7713142] cpu4: auxID=0x11120, GICv3, FP, CRC32, SHA1, SHA256, AES+PMULL, NEON, rounding, NaN propagation, denormals, 32x64bitRegs, Fused Multiply-Add
[   1.8413212] sdmmc1 at dwcmmc0
[   2.0013290] uhub0 at usb2: NetBSD (0000) EHCI root hub (0000), class 9/0, rev 2.00/1.00, addr 1
[   2.0013290] uhub1 at usb4: NetBSD (0000) xHCI root hub (0000), class 9/0, rev 3.00/1.00, addr 0
[   2.0013290] uhub2 at usb5: NetBSD (0000) xHCI root hub (0000), class 9/0, rev 2.00/1.00, addr 0
[   2.0013290] uhub3 at usb1: NetBSD (0000) OHCI root hub (0000), class 9/0, rev 1.00/1.00, addr 1
[   2.0013290] sdhc0: cmd timeout error
[   2.0213288] armpmu0: interrupting on GICv3 irq 23
[   2.0213288] armpmu1: failed to initialize PMU
[   2.0213288] uhub4 at usb0: NetBSD (0000) EHCI root hub (0000), class 9/0, rev 2.00/1.00, addr 1
[   2.0213288] uhub5 at usb3: NetBSD (0000) OHCI root hub (0000), class 9/0, rev 1.00/1.00, addr 1
[   3.0513686] sdmmc0: sdmmc_mem_enable failed with error 60
[   3.0613696] sdmmc0: couldn't enable card: 60
[   3.2313757] WARNING: 4 errors while detecting hardware; check system log.
[   3.2413763] sdhc0: cmd timeout error
[   3.2413763] boot device: <unknown>
[   3.2413763] root device: sdmmc0: sdmmc_mem_enable failed with error 60
[   4.2914157] sdmmc0: couldn't enable card: 60
[  20.8820428] use one of: awge0 ddb halt reboot
[  20.8820428] root device:
Did anyone succeeded with NetBSD - by olivier - 10-31-2018, 10:21 PM
RE: Did anyone succeeded with NetBSD - by tllim - 06-07-2019, 12:12 PM
RE: Did anyone succeeded with NetBSD - by tllim - 06-13-2019, 07:27 PM
RE: Did anyone succeeded with NetBSD - by abe - 06-24-2019, 11:50 AM
  NetBSD for RockPro64 Luke 3 7,050 06-12-2019, 11:52 PM
Last Post: beard5849
