Unable to access other UART devices
I think you have different baud rate, the GPS module running on 9600, so you should set it.
for me, I connected my USB to UART converter, (i can send you image later), then installed screen (sudo apt-get install screen), written "screen /dev/ttyS2 9600" (9600 as baud rate), opened Putty on my host PC, set baud rate and com port of USB to UART converter , and it works!
RE: Unable to access other UART devices - by gamelaster - 10-09-2018, 05:57 AM
  Unable to change resolution and poor performance MaWalla 3 5,542 12-26-2017, 11:06 AM
Last Post: dkryder
