Detailed NAS Case assembly (ameriDroid)
(04-13-2019, 06:28 AM)g_t_j Wrote: Are all the cables necessary included with the NAS kit?
What extras should I buy? Only heatsink, fan and power supply?
Will the tall heatsink fit in the enclosure or should I opt for the medium one?
Is the future upgrade of the RockPro64 going to be the same form factor so it will fit in the NAS kit - sort of a future-proof build ?
A few questions that I'd be grateful if someone can help.
There are two SATA data cables and one 12V to SATA power cable (2 power connector) included with NAS case that enough to power on two HDDs.
You can use the tall or medial height heatsink. Please note that there is only one fan power (controlled) connector, you can either connect to case or CPU heatsink fan.
For power supply, please use 12V 5A type.
We will try to keep the same form factor (model A) on future SBC release.
Detailed NAS Case assembly (ameriDroid) - by Luke - 09-28-2018, 02:28 AM
RE: Detailed NAS Case assembly (ameriDroid) - by tllim - 04-15-2019, 04:40 PM
  Anyone require a apple-sleek NAS case, w/ ample passive cooling & mutliple ssds? dairymilkbatman 0 597 01-19-2024, 02:17 PM
Last Post: dairymilkbatman
  3D Printed 2 SSD Vertical NAS Case tenox 1 2,237 12-19-2021, 01:30 PM
Last Post: CounterPillow
  [Turorial] NAS Using A Recycled 1U Proliant Case ColPanic_ 1 2,856 06-02-2021, 12:51 AM
Last Post: LMM
  NAS/fileserver project—RP64 in 1U ATX/ITX case (comments welcome!) Skirmisher 10 13,975 04-09-2021, 01:37 AM
Last Post: MNtinkerer
  Ideas to use extra space in NAS case? _hg_ 1 3,370 10-04-2020, 11:42 PM
Last Post: zer0sig
