Erratic Trackpad
Bug
I can completely understand the issues with the keyboard. But, with a heavy hand or a slight modification it becomes a non-issue.
But does anyone else find the trackpad completely erratic?
Example, I'll try and move the cursor a couple of pixels diagonally. A precise finger movement causes the mouse to do a Torvil-and-Dean-level flick and twist, and end up further away than before.
Other times, I feel like I've suddenly turned into Edward Cullen as the trackpad flat out refuses to react to my touch, especially if you have sweaty hands. I try to use heavier movements, but I end up accidentally dragging my desktop icons into the recycling bin, or the application launcher.
Does anyone else find the trackpad absolutely unusable? I understand that there's no specific driver so it uses a generic PS2 input driver, but daaammmnnn there must be something better?! Currently using either a USB mouse or KDE Connect wireless input mode.
[ PHP Developer | Pinebook 1G | About me ]
Erratic Trackpad - by soupbowl - 09-21-2018, 03:28 PM
  Replace/Upgrade trackpad tophneal 6 10,720 01-10-2020, 02:30 AM
Last Post: karlitos
  Trackpad research bbraun 0 1,758 11-25-2018, 03:00 PM
Last Post: bbraun
