PCI-E add-on Success & Failures
Wink
Good day,
I purchased two of the Rockpro64 Boards and NAS case.
So far I really like the unit.
I plan on donating second board to freebsd project.  waiting on them to tell me where to send it.
I am starting to try a few PCI boards boards in the rockpro64.
I was able to get High point RAId card that comes with san digital to work after upgrade of the kernel.
Please post any PCI devices that work here and anything you need to do to get it recognized.
uname -a
Linux rockpro64 4.18.0-rc8-1060-ayufan-g45828c4db727 #1 SMP PREEMPT Thu Aug 9 19:41:21 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
lspci -v
00:00.0 PCI bridge: Rockchip Inc. RK3399 PCI Express Root Port Device 0100 (prog-if 00 [Normal decode])
    Flags: bus master, fast devsel, latency 0, IRQ 255
    Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
    I/O behind bridge: 00000000-00000fff
    Memory behind bridge: fa000000-fa0fffff
    Prefetchable memory behind bridge: 00000000-000fffff
    Capabilities: <access denied>
01:00.0 RAID bus controller: HighPoint Technologies, Inc. RocketRAID 642L SATA-III Controller (2 eSATA ports + 2 internal SATA ports) (rev 01)
    Subsystem: HighPoint Technologies, Inc. RocketRAID 642L SATA-III Controller (2 eSATA ports + 2 internal SATA ports)
    Flags: bus master, fast devsel, latency 0, IRQ 231
    I/O ports at 0000
    I/O ports at 0000
    I/O ports at 0000
    I/O ports at 0000
    I/O ports at 0000
    Memory at fa010000 (32-bit, non-prefetchable) [size=2K]
    Expansion ROM at fa000000 [disabled] [size=64K]
    Kernel driver in use: ahci
lsscsi -v
[0:0:0:0]    disk    ATA      TOSHIBA HDWN160  FS1M  /dev/sda
 dir: /sys/bus/scsi/devices/0:0:0:0  [/sys/devices/platform/f8000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/ata1/host0/target0:0:0/0:0:0:0]
[0:1:0:0]    disk    ATA      TOSHIBA HDWE160  FS2A  /dev/sdb
 dir: /sys/bus/scsi/devices/0:1:0:0  [/sys/devices/platform/f8000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/ata1/host0/target0:1:0/0:1:0:0]
[0:2:0:0]    disk    ATA      TOSHIBA HDWN160  FS1M  /dev/sdc
 dir: /sys/bus/scsi/devices/0:2:0:0  [/sys/devices/platform/f8000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/ata1/host0/target0:2:0/0:2:0:0]
[0:3:0:0]    disk    ATA      TOSHIBA HDWE160  FS2A  /dev/sdd
 dir: /sys/bus/scsi/devices/0:3:0:0  [/sys/devices/platform/f8000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/ata1/host0/target0:3:0/0:3:0:0]
[2:0:0:0]    disk    ATA      TOSHIBA HDWE150  FP2A  /dev/sde
 dir: /sys/bus/scsi/devices/2:0:0:0  [/sys/devices/platform/f8000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/ata3/host2/target2:0:0/2:0:0:0]
[3:0:0:0]    disk    ATA      TOSHIBA HDWE150  FP2A  /dev/sdf
 dir: /sys/bus/scsi/devices/3:0:0:0  [/sys/devices/platform/f8000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/ata4/host3/target3:0:0/3:0:0:0]
/dev/sda:
Timing cached reads:   1976 MB in  2.00 seconds = 987.65 MB/sec
Timing buffered disk reads: 590 MB in  3.00 seconds = 196.52 MB/sec
/dev/sdb:
Timing cached reads:   1980 MB in  2.00 seconds = 989.73 MB/sec
Timing buffered disk reads: 586 MB in  3.01 seconds = 194.69 MB/sec
/dev/sdc:
Timing cached reads:   1990 MB in  2.00 seconds = 995.44 MB/sec
Timing buffered disk reads: 586 MB in  3.01 seconds = 194.71 MB/sec
/dev/sdd:
Timing cached reads:   1986 MB in  2.00 seconds = 992.67 MB/sec
Timing buffered disk reads: 468 MB in  3.00 seconds = 155.81 MB/sec
/dev/sde:
Timing cached reads:   1948 MB in  2.00 seconds = 973.81 MB/sec
Timing buffered disk reads: 402 MB in  3.00 seconds = 133.85 MB/sec
PCI-E add-on Success & Failures - by macross_dyrl - 08-25-2018, 06:41 PM
RE: PCI-E add-on Success & Failures - by nuumio - 11-18-2018, 10:53 AM
RE: PCI-E add-on Success & Failures - by huey - 12-15-2018, 08:18 AM
RE: PCI-E add-on Success & Failures - by nuumio - 01-27-2019, 02:08 AM
RE: PCI-E add-on Success & Failures - by nuumio - 12-15-2018, 12:31 PM
RE: PCI-E add-on Success & Failures - by huey - 12-15-2018, 01:09 PM
RE: PCI-E add-on Success & Failures - by gokuz - 12-19-2018, 12:12 AM
RE: PCI-E add-on Success & Failures - by nuumio - 12-19-2018, 02:07 PM
RE: PCI-E add-on Success & Failures - by gokuz - 12-19-2018, 11:43 PM
RE: PCI-E add-on Success & Failures - by nuumio - 12-20-2018, 03:08 AM
RE: PCI-E add-on Success & Failures - by nuumio - 01-29-2019, 12:49 PM
RE: PCI-E add-on Success & Failures - by nuumio - 02-02-2019, 11:00 AM
RE: PCI-E add-on Success & Failures - by huey - 03-05-2019, 12:51 PM
RE: PCI-E add-on Success & Failures - by ChNaed - 03-22-2019, 02:30 AM
RE: PCI-E add-on Success & Failures - by taube - 12-27-2019, 10:47 AM
RE: PCI-E add-on Success & Failures - by fysa - 02-19-2020, 09:05 AM
Music No success with audio crmcalls 2 3,146 04-15-2021, 11:17 PM
Last Post: crmcalls
  4K Success? bprotas 1 3,443 08-08-2018, 06:22 AM
Last Post: gabrielsr
