FreeBSD for Clusterboard (V1.1) [*WIP]
(07-31-2018, 03:09 PM)paradise Wrote: Hi,
I made an image of an almost complete world of FreeBSD for the SoPine including all my patches.
* What works
- Can boots from eMMC and should boot from SD. (didn't test)
- Can boot with MFS (not in this image but you can change the boot.scr or push settings with dhcp)
- Can boot from PXE
- CPU Frequency settings (1248Mhz, 1200Mhz, 1008Mhz, 816Mhz (DEFAULT), 528Mhz)
- Thermal sensor
- DMA Controller
- SRAM Controller for ethernet only
- SD, eMMC both work but may spit out messages at boot only depending on what you have inserted. (I use PXE+MFS+NFS so less prio)
- pkg install / portsnap (ports - I installed glusterfs from ports with somewhat same build as this so it should work!)
* Doesn't work
- No framebuffer (can't use/test it on clusterboard)
- USB doesn't seem to be working but I doubt the connection didn't get it working in Linux either.
- No MALI support what so ever.. regulators for MALI and other stuff are off.
* Issues
- Ethernet is fast but not yet 100% stable.. there are a few link drops for a millisecond or so
   I use MFS as root to prevent NFS from freaking out on that if it's the rootfs.
This is only a beta and it's version 1;
I have it running on 7 nodes myself using PXE/MFS and NFS and it's getting more stable with every patch. :-)
Next version I'll also include configs and stuff I use for DHCP/PXE booting the other 6 modules of the 1'st.. Need to compile it first for ARM.
You can use pkg install and portsnap to install stuff.
Login via SSH: sopine/sopine (sopine is in wheel)
Root has no password
https://drive.google.com/open?id=1i7MbXJ...me-Jrl25Lp
manu@FreeBSD here.
You talk about patches, where are they ?
For SD boot I know that andrew@ booted some sopine module from sdcard on the clusterboard so it should definitely work.
Framebuffer works (well EFIFB work), on pine64-lts and Pinebook.
USB should work, it work on Pine64/-LTS/Book so I don't see why it doesn't here.
RE: FreeBSD for Clusterboard [*WIP] - by manu - 07-31-2018, 03:47 PM
RE: FreeBSD for Clusterboard [*WIP] - by paradise - 07-31-2018, 04:05 PM
RE: FreeBSD for Clusterboard [*WIP] - by manu - 08-01-2018, 01:52 AM
RE: FreeBSD for Clusterboard [*WIP] - by paradise - 08-01-2018, 02:52 AM
RE: FreeBSD for Clusterboard [*WIP] - by paradise - 07-31-2018, 06:09 PM
RE: FreeBSD for Clusterboard [*WIP] - by manu - 08-01-2018, 04:40 AM
RE: FreeBSD for Clusterboard [*WIP] - by paradise - 08-01-2018, 04:50 AM
RE: FreeBSD for Clusterboard [*WIP] - by manu - 08-01-2018, 05:07 AM
RE: FreeBSD for Clusterboard [*WIP] - by paradise - 08-01-2018, 05:28 AM
  Upper USB slot not working on FreeBSD Pbowen 4 9,439 03-22-2020, 06:40 AM
Last Post: Pbowen
