Android never fully boots.
I have had 2 weeks to play with my 2gb Pine64, but could not get it to boot completely even once. I changed OS to burn with (Linux & Windows 10), beefed up the power supply, and unplugged every extra peripheral. Here's what finally worked:
  1. Downloaded the current Android image (Pine A64 Android Lollipop Image Rev 2016012)
  2. Used WinRAR to decompress the archive (I believe this was the big change - was using 7Zip)
  3. Used Allwinner PhoenixCard Bootable SD-Card Creator to format and burn the image (Larson's video was helpful)
  4. Inserted into the Pine64 and powered on with only power and HDMI plugged in.
It worked.  Big Grin
My Solution to frozen start (Stuck on Pine64 Screen) - by gpoints - 04-10-2016, 08:39 AM
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 1,954 03-18-2021, 11:52 AM
Last Post: Avron
Question Do I need a touchscreen to run Android? chrbar 3 5,217 08-08-2018, 10:55 PM
Last Post: chrbar
  ethernet lan speed problem android fulltone 0 2,657 04-23-2018, 01:47 AM
Last Post: fulltone
  Boots, but won't recognize keyboard davidgs 4 6,787 04-02-2018, 03:27 PM
Last Post: davidgs
  No sound on Android 6 or 7.1 reeno 0 2,946 07-29-2017, 06:31 PM
Last Post: reeno
  Boots just fine. Can not install new image. willpine 5 7,642 07-25-2017, 06:39 AM
Last Post: willpine
  Android pretty slow Passiday 2 5,118 10-08-2016, 03:46 AM
Last Post: Passiday
  Can't make the Android image boot Passiday 3 5,551 10-07-2016, 09:34 AM
Last Post: Passiday
  LCD screen with android, runs fine, screen does not turn back on..? GhostlyAspens 2 4,315 09-01-2016, 12:24 AM
Last Post: GhostlyAspens
  No IMG file after extracting Android dd tomwjr 15 21,462 08-12-2016, 03:53 PM
Last Post: tomwjr
