I cannot see the administrator panel in Control Centre
(07-06-2018, 04:02 AM)pfeerick Wrote:
(07-06-2018, 02:48 AM)alexyia Wrote: I have tried booting into GRUB by holding in ESC and then again SHIFT on start up as read on a few posts. Later I read I need to hold down shift on a grey splashscreen which I don't see so I tried the login screen but that didn't work. I've tried various root combinations suggested such as debian debian but none work.
This won't work at all, as there is no grub bootloader. I don't actually know of any single-board computer that has grub on it.
(07-06-2018, 02:48 AM)alexyia Wrote: My goal is to change the power settings so that it never goes into sleep mode but now I also want to get the root account so I at least know what it is.
To access the root account, you'll need to set a password for it, which will unlock the account. The rock64 user account is a admin level account, so you can do a "sudo passwd root" at a terminal prompt (hint: Applications -> System Tools -> MATE Terminal) and type in a password for the root user.
As far as power settings, they should be in the System -> Administration or System -> Preferences section, pretty sure the applet you're after is just called "Power"...
I see. Thanks for the guidance. I was able to change the root password! Unfortunately I still can't see the Administration option under System so I can't access any of the admin settings that I need to change. I logged in as root hoping it would show but still not. Any ideas? I only see Hardware, Internet & Hardware, Look & Feel and Personal none of which contain power settings.
RE: I cannot see the administrator panel in Control Centre - by alexyia - 07-06-2018, 06:11 AM
  Baseboard DC-006 centre tap? Bazmundi 1 3,114 07-14-2020, 05:10 AM
Last Post: michaelengel
  7" LCD Touch Screen Panel IanJames 0 2,077 04-01-2020, 04:40 PM
Last Post: IanJames
  Content Control teddyj 1 3,174 07-14-2018, 11:41 AM
  7" LCD Touch Screen Panel TDetwiler3@gmail.com 1 4,215 06-24-2016, 02:07 PM
Last Post: xalius
  LCD Panel bsa 2 4,590 06-19-2016, 06:27 PM
Last Post: Severian
