[Archived] Initial Linux release from ayufan (0.6.XX)
#24
@deeproot
HI
Warning!
Even when starting my linux based Picocom V1.7 with cli option -b 150000. It will not run... says baud rate not supported.
I am having limited success with minicom, after about 30 hours struggling with putty,  this works sometimes, more often  it fails, but I can see some valid info on the boot process.
The only distro I have found to boot  even  part way is the stretch image. this never gets to the linux prompt,   it stops at different points in the boot flow.
What was very exciting on stretch was that this blinding white led lit up for the first time showing the board had some signs of lfe!
Frankly, I feel that I need to put the rockpro board in a cupboard for some weeks and only get it out when things are more stable, nothing seems repeatable at the mo.
regards
Patrick
RE: Initial Linux release from ayufan (0.6.XX) - by superpat - 06-02-2018, 04:17 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 681 03-25-2024, 12:12 PM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 927 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,444 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 2,298 04-23-2023, 01:32 PM
Last Post: diederik
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,094 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 linux console video mode callegar 0 917 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 8,449 04-30-2022, 03:57 PM
Last Post: TRS-80
  Armbian 22.02 Release Announcement TRS-80 0 1,198 02-28-2022, 05:08 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 4,443 01-03-2022, 10:32 AM
Last Post: whitecat23
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 1,489 07-24-2021, 09:46 PM
Last Post: Mentaluproar
