[Archived] Initial Linux release from ayufan (0.6.XX)
#23
(06-01-2018, 08:37 PM)deeproot Wrote: Yes I am getting that error with all builds including the newest 6.45
All night I have been trying to get a serial dump and I have had no success with two usb serial adapters. I only can get garbage on the terminal.
picocom -b 1500000 /dev/ttyUSB0 is the command im using. It works for all other serial devices but I can't get information from the rockpro64.
I get garbage on the terminal when I power up the board until around 1.8/2.0 seconds into the initrd boot process, but when it reboots it is fine (I get all the output then), so maybe it's something not set initially re: timing
Either way, for the moment I can't reproduce your fault on an earlier image, and I'm guessing one of the changes in 0.6.45 will have to be reverted or tweaked - looks like ayufan's trying to get the GPU drivers up and running...
RE: Initial Linux release from ayufan (0.6.XX) - by pfeerick - 06-01-2018, 10:12 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 682 03-25-2024, 12:12 PM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 927 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,446 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 2,304 04-23-2023, 01:32 PM
Last Post: diederik
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,095 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 linux console video mode callegar 0 917 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 8,450 04-30-2022, 03:57 PM
Last Post: TRS-80
  Armbian 22.02 Release Announcement TRS-80 0 1,198 02-28-2022, 05:08 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 4,444 01-03-2022, 10:32 AM
Last Post: whitecat23
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 1,489 07-24-2021, 09:46 PM
Last Post: Mentaluproar
