Is PCIE x4 bootable for NVMe SSD under Linux
(06-11-2018, 07:40 AM)Bullet64 Wrote: Plug & Play  Big Grin But not stable atm.
When not allowed, please delete the link. More infos ->   https://frank-mankel.org/topic/58/rockpro64-pcie-x4/7 (only german)
Thanks for the link... I'll be sure to follow your progress Wink I'm getting some PCI-e test cards so I can check the PCI-e ports, and can hopefully get the NVM card running once the drive arrives. I'm surprised that just plugging in the SATA card with no drives attached didn't work (get detected) for me though... although from your notes it seems like there is a fault? Since AFAIK this hasn't been documented as a possible known issue on the forum yet (as it should have been by now), I'm assuming from the #rock64 IRC chat history from the 27/28th of May 2018 that removal of the resistor indicated in this picture is the solution to my problem with a pre-production rockpro64? https://app.box.com/s/wghe5gu40dliaz2014g1rj28i2j164bv If so, looks easy enough, will warm up the soldering iron and do some surgery Smile
RE: Is PCIE x4 bootable for NVMe SSD under Linux - by pfeerick - 06-11-2018, 06:37 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 657 03-25-2024, 12:12 PM
  RK3399 PCIe enumeration jhadd 0 316 01-31-2024, 08:56 AM
Last Post: jhadd
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 919 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,426 07-14-2023, 04:22 AM
Last Post: hunderteins
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,087 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 2,287 10-14-2022, 06:24 AM
Last Post: rwk-
  RockPro64 linux console video mode callegar 0 913 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 8,432 04-30-2022, 03:57 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 4,424 01-03-2022, 10:32 AM
Last Post: whitecat23
  No PCIe controller detected... Limhes 1 1,641 11-23-2021, 06:23 AM
Last Post: Limhes
