suggested config for C++ programming
After some tries & discuss, here they are my opinions on some IDE for working in C++:
- Eclipse seems too old on ARM platform
- Codebocks seems to work very fine. It also includes a Qt project wizard that allows to create Qt application in conjunction with Qt designer; nevertheless the integration of Qt is not complete, especially the code generation which has to be done using the command line tools (uic, moc), but this works.
- Qt creator works very very fine and, of course, the integration of Qt is perfect.
I precise that i use a rock64/4G + 16 Go eMMc + Bionic/LXDE. So now, i use Qt creator which is a very complete set of tools + framework.
regards
suggested config for C++ programming - by pas059 - 04-23-2018, 11:54 AM
RE: suggested config for programming - by pas059 - 05-03-2018, 03:43 AM
RE: suggested config for programming - by tllim - 05-03-2018, 09:43 PM
RE: suggested config for programming - by pas059 - 05-04-2018, 03:02 AM
RE: suggested config for programming - by pas059 - 05-07-2018, 03:39 AM
RE: suggested config for programming - by pas059 - 07-05-2018, 02:22 AM
  Hoe to Update Buildroot Package config from SDK build.sh file shivarj89 0 1,728 09-09-2019, 09:39 AM
Last Post: shivarj89
  Enable I2C, I2s, SPI in boot-config file? HelgeMK 3 7,293 08-14-2018, 10:59 AM
Last Post: pas059
