Python GPIO Library for the Rock64 (R64.GPIO)
(04-12-2018, 08:08 AM)martinayotte Wrote: Internal SoC PullUps are usually between 20K to 100K.
So, using a external PullDown to put it low is like creating a voltage divider with the internal pullup, therefore with a external 20K, you get a voltage that is neither a LOW or a HIGH, explaining why you get interrupts triggered repeatedly.
If you use a external 1K as a pulldown instead, you will see that will be close to 0V ...
Thanks for your reply.
By calculation, the internal pull-up resistor is around 60K, it is normal.
As I expected the pin was pull-down internally and I had prepared a switch with 5K resistor to pull it up, so when I found the pin was pull-up, I was a little confused - I wanted to pull it down and use the switch to pull it up to trigger the interrupt.
RE: Python GPIO Library for the Rock64 (R64.GPIO) - by edupv - 04-12-2018, 09:31 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 426 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,665 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,868 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,407 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 397 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 2,012 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,623 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,207 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 789 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 992 10-07-2022, 07:50 PM
Last Post: rookie_267
