+LTS/SOPINE how to change for init status of gpio
thanks for your reply.
i have a question about configuration compared the Raspberry pi.
raspberry pi can change the state of pin using the dtoverlay command in config.txt file.
Isn't it possible in A64?
In the Raspberry Pi, modify the config.txt file and it can change the state of pin high or low.
(ex. dtoverlay=lirc-rpi:gpio_out_=16,gpio_in_pin=17,gpio _in_pull=down)
if you know the way, reply plz.
Thanks.
RE: how to change for init status of gpio - by chun jong rock - 03-25-2018, 06:23 PM
  Battery status on panel? Zoidiano0 3 5,694 05-08-2017, 05:51 PM
Last Post: Zoidiano0
