HW Acceleration Working
I was able to compile the Mali-Fbdev drive from the ARM Mali website. Now I'm downloading the kernel source so I can compile the mali_drm kernel module, not included with xenial. I will try the libmali.so binaries for arm64 also available from the ARM Mali website.
Some progress:
X.Org X Server 1.18.3
Release Date: 2016-04-04
[  9223.728] X Protocol Version 11, Revision 0
[  9223.728] Build Operating System: Linux 4.2.0-34-generic aarch64 Ubuntu
[  9223.728] Current Operating System: Linux localhost.localdomain 3.10.65-4-pine64-longsleep #16 SMP PREEMPT Sun Apr 3 10:56:40 CEST 2016 aarch64
[  9223.729] Kernel command line: console=tty0 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr=a6:f4:ed:cc:2f:50 root=/dev/mmcblk0p2 ro rootwait
[  9223.729] Build Date: 07 April 2016  09:19:04AM
[  9223.729] xorg-server 2:1.18.3-1ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[  9223.729] Current version of pixman: 0.33.6
[  9223.729] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[  9223.729] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[  9223.730] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Apr 20 03:18:35 2016
[  9223.731] (==) Using config file: "/etc/X11/xorg.conf"
[  9223.731] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  9223.732] (==) No Layout section.  Using the first Screen section.
[  9223.732] (**) |-->Screen "Mali-Screen" (0)
[  9223.732] (**) |   |-->Monitor "<default monitor>"
[  9223.733] (**) |   |-->Device "Mali-Fbdev"
[  9223.733] (==) No monitor specified for screen "Mali-Screen".
Using a default monitor configuration.
[  9223.733] (==) Automatically adding devices
[  9223.733] (==) Automatically enabling devices
[  9223.733] (==) Automatically adding GPU devices
[  9223.733] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  9223.733] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[  9223.733] Entry deleted from font path.
[  9223.733] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[  9223.733] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[  9223.734] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[  9223.734] Entry deleted from font path.
[  9223.734] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[  9223.734] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[  9223.734] (==) ModulePath set to "/usr/lib/aarch64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[  9223.734] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[  9223.734] (II) Loader magic: 0x556fbfcd68
[  9223.734] (II) Module ABI versions:
[  9223.734] X.Org ANSI C Emulation: 0.4
[  9223.734] X.Org Video Driver: 20.0
[  9223.734] X.Org XInput driver : 22.1
[  9223.734] X.Org Server Extension : 9.0
[  9223.738] (--) using VT number 2
[  9223.738] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[  9223.738] (II) no primary bus or device found
[  9223.738] (II) LoadModule: "glx"
[  9223.740] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  9223.745] (II) Module glx: vendor="X.Org Foundation"
[  9223.745] compiled for 1.18.3, module version = 1.0.0
[  9223.746] ABI class: X.Org Server Extension, version 9.0
[  9223.746] (==) AIGLX enabled
[  9223.746] (II) LoadModule: "mali"
[  9223.748] (II) Loading /usr/lib/xorg/modules/drivers/mali_drv.so
[  9223.748] (II) Module mali: vendor="X.Org Foundation"
[  9223.748] compiled for 1.18.3, module version = 0.4.2
[  9223.748] ABI class: X.Org Video Driver, version 20.0
[  9223.748] (II) MALI: driver for Mali Framebuffer: mali
[  9223.786] (WW) Falling back to old probe method for mali
[  9223.787] (II) MALI(0): using /dev/fb0
[  9223.787] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[  9223.787] (II) MALI(0): [MaliPreInit:1046]: Entering
[  9223.787] (II) MALI(0): [MaliGetRec:179]: Entering
[  9223.787] (II) MALI(0): [MaliHWInit:829]: Entering
[  9223.787] (II) MALI(0): [MaliHWGetDepth:861]: Entering
[  9223.787] (II) MALI(0): Creating default Display subsection in Screen section
"Mali-Screen" for depth/fbbpp 24/32
[  9223.787] (**) MALI(0): Depth 24, (--) framebuffer bpp 32
[  9223.787] (==) MALI(0): RGB weight 888
[  9223.787] (==) MALI(0): Default visual is TrueColor
[  9223.787] (==) MALI(0): Using gamma correction (1.0, 1.0, 1.0)
[  9223.787] (II) MALI(0): [MaliHWGetVidmem:879]: Entering
[  9223.787] (II) MALI(0): [MaliHWGetName:887]: Entering
[  9223.787] (II) MALI(0): hardware:  (video memory: 16200kB)
[  9223.788] (**) MALI(0): Option "DRI2" "true"
[  9223.788] (**) MALI(0): Option "DRI2_PAGE_FLIP" "true"
[  9223.788] (**) MALI(0): Option "DRI2_WAIT_VSYNC" "true"
[  9223.788] (**) MALI(0): Option "UMP_CACHED" "false"
[  9223.788] (**) MALI(0): Option "UMP_LOCK" "false"
[  9223.788] (**) MALI(0): DRI Fullscreen page flip enabled
[  9223.788] (**) MALI(0): DRI Fullscreen page flip VSYNC'd
[  9223.788] (**) MALI(0): Use uncached UMP memory
[  9223.788] (**) MALI(0): Don't use umplock across processes
[  9223.889] (EE) MALI(0): [mali_drm_open_master:1015] Error: mali_drm_open_master Unable to open DRM: No such file or directory
[  9223.889] (EE) MALI(0): [MaliPreInit:1148] Error: Failed to be master of DRM!
[  9223.890] (II) UnloadModule: "mali"
[  9223.890] (EE) Screen(s) found, but none have a usable configuration.
[  9223.890] (EE)
Fatal server error:
[  9223.890] (EE) no screens found(EE)
[  9223.890] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[  9223.891] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[  9223.891] (EE)
[  9223.998] (EE) Server terminated with error (1). Closing log file.
Any recommendations?
HW Acceleration Working - by Luke - 04-06-2016, 07:29 PM
RE: Help with HW Acceleration - by tllim - 04-07-2016, 11:12 AM
RE: Help with HW Acceleration - by rdPine64 - 04-13-2016, 11:22 AM
RE: Help with HW Acceleration - by longsleep - 04-14-2016, 11:00 AM
RE: Help with HW Acceleration - by rdPine64 - 04-23-2016, 01:16 PM
RE: Help with HW Acceleration - by moondark - 04-19-2016, 11:58 PM
RE: Help with HW Acceleration - by moondark - 04-20-2016, 03:23 AM
RE: Help with HW Acceleration - by moondark - 04-20-2016, 04:49 AM
RE: Help with HW Acceleration - by longsleep - 04-20-2016, 05:06 AM
RE: Help with HW Acceleration - by moondark - 04-20-2016, 05:49 AM
RE: Help with HW Acceleration - by longsleep - 04-20-2016, 01:59 PM
RE: Help with HW Acceleration - by moondark - 04-20-2016, 04:08 PM
RE: Help with HW Acceleration - by longsleep - 04-21-2016, 01:37 PM
RE: Help with HW Acceleration - by moondark - 04-22-2016, 02:10 PM
RE: Help with HW Acceleration - by Luke - 04-22-2016, 10:08 AM
RE: Help with HW Acceleration - by rahlquist - 04-22-2016, 12:26 PM
RE: Help with HW Acceleration - by sirhcjw - 04-26-2016, 07:50 AM
RE: Help with HW Acceleration - by baryluk - 04-26-2016, 02:43 PM
RE: Help with HW Acceleration - by Luke - 04-27-2016, 07:55 AM
RE: Help with HW Acceleration - by fishmech - 05-06-2016, 02:01 PM
RE: Help with HW Acceleration - by CaptainZalo - 05-31-2016, 12:57 PM
RE: Help with HW Acceleration - by tllim - 05-31-2016, 05:26 PM
RE: Help with HW Acceleration - by Luke - 05-31-2016, 05:57 PM
RE: Help with HW Acceleration - by CybeX - 06-01-2016, 08:47 AM
RE: Help with HW Acceleration - by Metalazzo - 06-06-2016, 10:16 AM
RE: Help with HW Acceleration - by tllim - 06-06-2016, 06:31 PM
RE: Help with HW Acceleration - by CybeX - 06-10-2016, 12:08 PM
RE: Help with HW Acceleration - by CaptainZalo - 06-13-2016, 12:50 PM
RE: Help with HW Acceleration - by tllim - 06-14-2016, 11:45 AM
RE: Help with HW Acceleration - by pietrondo - 06-06-2016, 05:51 PM
RE: Help with HW Acceleration - by Metalazzo - 06-07-2016, 03:22 AM
RE: Help with HW Acceleration - by BringItOn - 06-11-2016, 04:28 AM
RE: Help with HW Acceleration - by fneves - 06-14-2016, 04:55 AM
RE: Help with HW Acceleration - by pietrondo - 06-14-2016, 09:32 AM
RE: Help with HW Acceleration - by Luke - 06-14-2016, 12:22 PM
RE: Help with HW Acceleration - by CaptainZalo - 06-16-2016, 11:41 AM
RE: Help with HW Acceleration - by tllim - 06-16-2016, 12:30 PM
RE: Help with HW Acceleration - by tllim - 06-17-2016, 10:31 AM
RE: Help with HW Acceleration - by ViperVi - 06-17-2016, 11:40 AM
RE: Help with HW Acceleration - by tllim - 06-17-2016, 05:08 PM
RE: Help with HW Acceleration - by ViperVi - 06-17-2016, 06:37 PM
RE: Help with HW Acceleration - by Ghost - 06-20-2016, 04:00 AM
RE: Help with HW Acceleration - by CaptainZalo - 06-20-2016, 11:05 PM
RE: Help with HW Acceleration - by tllim - 06-21-2016, 03:54 PM
RE: Help with HW Acceleration - by tllim - 06-23-2016, 07:50 AM
RE: Help with HW Acceleration - by jl_678 - 06-23-2016, 07:58 AM
RE: Help with HW Acceleration - by Luke - 06-23-2016, 08:57 AM
RE: Help with HW Acceleration - by jl_678 - 06-23-2016, 01:23 PM
RE: Help with HW Acceleration - by Monochrome - 06-23-2016, 01:49 PM
RE: Help with HW Acceleration - by extr - 06-23-2016, 02:13 PM
RE: Help with HW Acceleration - by xalius - 06-23-2016, 02:56 PM
RE: Help with HW Acceleration - by ssvb - 06-23-2016, 03:03 PM
RE: Help with HW Acceleration - by barawn - 07-02-2016, 10:33 AM
RE: Help with HW Acceleration - by xalius - 06-24-2016, 11:45 AM
RE: Help with HW Acceleration - by Sak3r - 06-24-2016, 10:54 AM
RE: Help with HW Acceleration - by ssvb - 06-24-2016, 11:58 AM
RE: Help with HW Acceleration - by Xabaras76 - 06-24-2016, 04:48 PM
RE: Help with HW Acceleration - by ssvb - 06-25-2016, 02:58 PM
RE: Help with HW Acceleration - by longsleep - 06-25-2016, 03:40 PM
RE: Help with HW Acceleration - by tllim - 06-26-2016, 06:57 PM
RE: Help with HW Acceleration - by nagmier - 06-27-2016, 09:25 AM
RE: Help with HW Acceleration - by ssvb - 06-25-2016, 05:30 PM
RE: Help with HW Acceleration - by jrullan - 06-25-2016, 07:09 PM
RE: Help with HW Acceleration - by CaptainZalo - 06-27-2016, 03:13 PM
RE: Help with HW Acceleration - by nagmier - 06-28-2016, 05:50 AM
RE: Help with HW Acceleration - by CaptainZalo - 06-28-2016, 07:21 AM
RE: Help with HW Acceleration - by CaptainZalo - 07-01-2016, 02:24 AM
RE: Help with HW Acceleration - by tllim - 07-02-2016, 09:50 PM
RE: Help with HW Acceleration - by nagmier - 07-14-2016, 06:59 PM
RE: Help with HW Acceleration - by tllim - 07-16-2016, 07:35 PM
RE: Help with HW Acceleration - by nagmier - 07-17-2016, 07:41 AM
RE: Help with HW Acceleration - by longsleep - 07-03-2016, 09:19 AM
RE: Help with HW Acceleration - by longsleep - 07-06-2016, 11:09 PM
RE: Help with HW Acceleration - by janeku - 07-06-2016, 03:42 PM
RE: Help with HW Acceleration - by janeku - 07-07-2016, 09:19 AM
RE: Help with HW Acceleration - by longsleep - 07-07-2016, 10:17 AM
RE: Help with HW Acceleration - by Bart333 - 07-11-2016, 10:41 AM
RE: Help with HW Acceleration - by Luke - 07-11-2016, 10:59 AM
RE: Help with HW Acceleration - by jrullan - 07-11-2016, 08:42 PM
RE: Help with HW Acceleration - by CaptainZalo - 07-16-2016, 06:44 AM
RE: Help with HW Acceleration - by Boring - 07-17-2016, 03:42 AM
RE: Help with HW Acceleration - by adamw - 07-19-2016, 08:06 PM
RE: Help with HW Acceleration - by CaptainZalo - 07-20-2016, 03:49 AM
RE: Help with HW Acceleration - by vinodmenon80 - 07-20-2016, 04:04 AM
RE: Help with HW Acceleration - by nugu53 - 07-27-2016, 01:54 AM
RE: Help with HW Acceleration - by Monochrome - 07-29-2016, 10:18 AM
RE: Help with HW Acceleration - by adamw - 07-29-2016, 10:29 AM
RE: Help with HW Acceleration - by jl_678 - 07-29-2016, 11:17 AM
RE: Help with HW Acceleration - by jrullan - 07-29-2016, 04:16 PM
RE: Help with HW Acceleration - by jkmooney - 07-29-2016, 02:40 PM
RE: Help with HW Acceleration - by fire219 - 07-29-2016, 09:18 PM
RE: Help with HW Acceleration - by nagmier - 07-30-2016, 10:27 AM
RE: Help with HW Acceleration - by tllim - 07-30-2016, 06:23 PM
HW Acceleration Working - by Monochrome - 07-30-2016, 01:03 AM
RE: HW Acceleration Working - by Er0l - 07-30-2016, 01:27 AM
RE: HW Acceleration Working - by DefinitelyNotLA - 07-30-2016, 02:20 AM
RE: HW Acceleration Working - by ssvb - 07-30-2016, 02:41 AM
RE: HW Acceleration Working - by Luke - 07-30-2016, 07:15 AM
RE: HW Acceleration Working - by longsleep - 07-30-2016, 07:33 AM
RE: HW Acceleration Working - by Xabaras76 - 07-30-2016, 09:20 AM
RE: HW Acceleration Working - by Zoidiano0 - 07-30-2016, 09:55 AM
RE: HW Acceleration Working - by Vidiot - 07-30-2016, 02:50 PM
RE: HW Acceleration Working - by Terra854 - 07-30-2016, 11:28 PM
RE: HW Acceleration Working - by Monochrome - 07-31-2016, 03:54 AM
RE: HW Acceleration Working - by longsleep - 07-31-2016, 01:54 PM
RE: HW Acceleration Working - by Monochrome - 07-31-2016, 02:13 PM
RE: HW Acceleration Working - by longsleep - 07-31-2016, 02:17 PM
RE: HW Acceleration Working - by Monochrome - 07-31-2016, 02:18 PM
RE: HW Acceleration Working - by longsleep - 07-31-2016, 02:19 PM
HW Acceleration Working - by Monochrome - 07-31-2016, 02:41 PM
RE: HW Acceleration Working - by longsleep - 07-31-2016, 03:43 PM
RE: HW Acceleration Working - by xalius - 07-31-2016, 03:57 PM
HW Acceleration Working - by Monochrome - 07-31-2016, 10:35 PM
RE: HW Acceleration Working - by Monochrome - 08-01-2016, 09:53 AM
RE: HW Acceleration Working - by longsleep - 08-01-2016, 10:29 AM
RE: HW Acceleration Working - by xalius - 08-01-2016, 11:40 AM
RE: HW Acceleration Working - by Monochrome - 08-01-2016, 11:54 AM
RE: HW Acceleration Working - by longsleep - 08-01-2016, 12:46 PM
RE: HW Acceleration Working - by Monochrome - 08-01-2016, 01:21 PM
RE: HW Acceleration Working - by longsleep - 08-01-2016, 03:06 PM
RE: HW Acceleration Working - by Monochrome - 08-02-2016, 01:46 PM
RE: HW Acceleration Working - by rallar8 - 08-02-2016, 12:07 PM
RE: HW Acceleration Working - by HorreC - 08-03-2016, 12:30 PM
RE: HW Acceleration Working - by rallar8 - 08-03-2016, 03:26 PM
RE: HW Acceleration Working - by HorreC - 08-03-2016, 04:06 PM
RE: HW Acceleration Working - by kflorek46 - 08-03-2016, 11:25 PM
RE: HW Acceleration Working - by HorreC - 08-04-2016, 09:53 AM
RE: HW Acceleration Working - by jodybrown99 - 08-04-2016, 02:19 PM
RE: HW Acceleration Working - by piner64 - 08-08-2016, 02:04 AM
RE: HW Acceleration Working - by Monochrome - 08-08-2016, 04:05 AM
RE: HW Acceleration Working - by shadowheart - 08-11-2016, 04:52 AM
RE: HW Acceleration Working - by Monochrome - 08-11-2016, 06:38 AM
RE: HW Acceleration Working - by xalius - 08-11-2016, 06:50 AM
RE: HW Acceleration Working - by dkryder - 08-12-2016, 02:43 AM
RE: HW Acceleration Working - by xalius - 08-12-2016, 02:48 AM
RE: HW Acceleration Working - by dkryder - 08-12-2016, 03:22 AM
RE: HW Acceleration Working - by jrullan - 08-17-2016, 06:32 PM
RE: HW Acceleration Working - by protonic - 08-19-2016, 05:23 AM
RE: HW Acceleration Working - by rcgalvao - 08-23-2016, 06:59 PM
RE: HW Acceleration Working - by pietrondo - 08-25-2016, 06:12 AM
RE: HW Acceleration Working - by jkmooney - 08-25-2016, 06:05 AM
RE: HW Acceleration Working - by nagmier - 08-25-2016, 12:39 PM
RE: HW Acceleration Working - by pietrondo - 08-25-2016, 02:33 PM
RE: HW Acceleration Working - by jrullan - 08-25-2016, 09:13 PM
RE: HW Acceleration Working - by nagmier - 08-25-2016, 07:06 PM
RE: HW Acceleration Working - by pfeerick - 08-25-2016, 11:29 PM
RE: HW Acceleration Working - by dkryder - 08-26-2016, 04:18 AM
RE: HW Acceleration Working - by jrullan - 08-26-2016, 07:36 AM
RE: HW Acceleration Working - by Monochrome - 08-26-2016, 09:36 AM
RE: HW Acceleration Working - by joe - 08-26-2016, 09:55 AM
RE: HW Acceleration Working - by pfeerick - 08-26-2016, 11:58 PM
RE: HW Acceleration Working - by Terra854 - 08-29-2016, 09:39 AM
RE: HW Acceleration Working - by jrullan - 08-29-2016, 09:17 PM
RE: HW Acceleration Working - by jrullan - 08-29-2016, 02:47 PM
HW Acceleration Working - by Monochrome - 08-29-2016, 03:03 PM
RE: HW Acceleration Working - by jrullan - 08-29-2016, 03:17 PM
RE: HW Acceleration Working - by CaptainZalo - 08-29-2016, 10:45 PM
RE: HW Acceleration Working - by longsleep - 08-29-2016, 11:41 PM
RE: HW Acceleration Working - by CaptainZalo - 08-30-2016, 01:37 AM
RE: HW Acceleration Working - by CaptainZalo - 08-30-2016, 02:03 AM
RE: HW Acceleration Working - by pfeerick - 08-30-2016, 02:13 AM
RE: HW Acceleration Working - by pfeerick - 08-30-2016, 02:50 AM
RE: HW Acceleration Working - by pfeerick - 08-30-2016, 03:10 AM
RE: HW Acceleration Working - by pfeerick - 08-30-2016, 03:50 AM
RE: HW Acceleration Working - by jrullan - 08-30-2016, 04:47 AM
RE: HW Acceleration Working - by jrullan - 08-30-2016, 06:20 AM
RE: HW Acceleration Working - by longsleep - 08-30-2016, 10:43 AM
RE: HW Acceleration Working - by pfeerick - 08-30-2016, 03:44 PM
RE: HW Acceleration Working - by jrullan - 08-30-2016, 12:33 PM
RE: HW Acceleration Working - by adamw - 08-30-2016, 02:53 PM
RE: HW Acceleration Working - by pietrondo - 08-30-2016, 03:14 PM
RE: HW Acceleration Working - by longsleep - 08-30-2016, 05:13 PM
RE: HW Acceleration Working - by jrullan - 08-30-2016, 06:47 PM
RE: HW Acceleration Working - by tkaiser - 08-30-2016, 11:24 PM
RE: HW Acceleration Working - by tkaiser - 08-31-2016, 03:23 AM
RE: HW Acceleration Working - by tkaiser - 08-31-2016, 07:22 AM
RE: HW Acceleration Working - by adamw - 08-31-2016, 08:54 AM
RE: HW Acceleration Working - by tkaiser - 08-31-2016, 09:14 AM
RE: HW Acceleration Working - by jrullan - 08-31-2016, 02:57 PM
RE: HW Acceleration Working - by tkaiser - 08-31-2016, 03:18 PM
RE: HW Acceleration Working - by jkmooney - 08-31-2016, 04:00 PM
RE: HW Acceleration Working - by jrullan - 08-31-2016, 04:37 PM
RE: HW Acceleration Working - by jrullan - 08-31-2016, 05:20 PM
RE: HW Acceleration Working - by ssvb - 08-31-2016, 05:54 PM
RE: HW Acceleration Working - by jrullan - 08-31-2016, 06:36 PM
RE: HW Acceleration Working - by Pander - 09-04-2016, 07:09 AM
RE: HW Acceleration Working - by Ghelorn - 09-04-2016, 03:52 PM
RE: HW Acceleration Working - by psychedup - 09-06-2016, 05:12 PM
RE: HW Acceleration Working - by Pander - 09-07-2016, 07:00 AM
RE: HW Acceleration Working - by pietrondo - 09-10-2016, 05:33 AM
RE: HW Acceleration Working - by pfeerick - 09-10-2016, 11:36 PM
RE: HW Acceleration Working - by Luke - 09-11-2016, 03:13 PM
RE: HW Acceleration Working - by Zoidiano0 - 09-10-2016, 07:08 AM
RE: HW Acceleration Working - by dkryder - 09-10-2016, 08:31 PM
RE: HW Acceleration Working - by HayseedGeek - 09-10-2016, 10:40 PM
RE: HW Acceleration Working - by FlameCRO - 09-11-2016, 08:01 AM
RE: HW Acceleration Working - by tampadave - 10-04-2016, 04:16 PM
RE: HW Acceleration Working - by pfeerick - 10-04-2016, 07:14 PM
RE: HW Acceleration Working - by dkryder - 10-04-2016, 08:30 PM
RE: HW Acceleration Working - by HayseedGeek - 10-05-2016, 07:09 AM
RE: HW Acceleration Working - by ssvb - 10-05-2016, 07:28 AM
RE: HW Acceleration Working - by pfeerick - 10-05-2016, 06:56 PM
RE: HW Acceleration Working - by dkryder - 10-06-2016, 11:01 PM
RE: HW Acceleration Working - by Gnx - 11-26-2016, 02:05 PM
RE: HW Acceleration Working - by bmarquismarkail - 12-01-2016, 08:05 AM
RE: HW Acceleration Working - by Gnx - 12-05-2016, 12:23 PM
RE: HW Acceleration Working - by Terra854 - 12-05-2016, 08:22 PM
RE: HW Acceleration Working - by Luke - 12-06-2016, 06:38 AM
RE: HW Acceleration Working - by tllim - 12-15-2016, 06:27 PM
RE: HW Acceleration Working - by Pander - 12-08-2016, 05:20 AM
RE: HW Acceleration Working - by Gnx - 12-11-2016, 11:58 AM
RE: HW Acceleration Working - by Pander - 12-16-2016, 08:18 AM
RE: HW Acceleration Working - by Flint - 12-29-2016, 02:49 AM
RE: HW Acceleration Working - by Gnx - 01-20-2017, 03:04 AM
RE: HW Acceleration Working - by Flint - 02-06-2017, 09:22 AM
RE: HW Acceleration Working - by makzoom01 - 02-14-2017, 11:40 PM
RE: HW Acceleration Working - by pqueiro - 03-13-2017, 04:46 AM
RE: HW Acceleration Working - by CaptainZalo - 03-13-2017, 07:29 AM
RE: HW Acceleration Working - by pqueiro - 03-15-2017, 05:11 AM
RE: HW Acceleration Working - by Gnx - 05-09-2017, 09:32 PM
RE: HW Acceleration Working - by Luke - 05-10-2017, 03:08 AM
RE: HW Acceleration Working - by Gnx - 05-14-2017, 10:45 PM
RE: HW Acceleration Working - by Luke - 05-15-2017, 05:11 AM
RE: HW Acceleration Working - by Gnx - 05-15-2017, 12:27 PM
RE: HW Acceleration Working - by pqueiro - 12-01-2017, 02:25 PM
RE: HW Acceleration Working - by Pander - 12-02-2017, 06:44 AM
RE: HW Acceleration Working - by Luke - 12-02-2017, 04:37 PM
RE: HW Acceleration Working - by Brian Beuken - 03-04-2018, 02:54 PM
RE: HW Acceleration Working - by Luke - 03-05-2018, 04:27 AM
  Brand New LCD not working adamjedgar 3 6,623 03-11-2017, 12:20 AM
Last Post: simplexdan
  Pine64+: 3 working, 1 shows nothing on tv zumtra 1 3,999 07-30-2016, 05:47 PM
