Display resolutions?
(04-06-2016, 10:24 PM)lenny.raposo-pine64.pro Wrote: Here is a work around for 1280x720 resolutions from hdmi.
Execute These commands from a console or ssh into your board externally
sudo apt-get install fbset
sudo service lightdm stop
sudo fbset -a -xres 1280  -yres  720 -vxres 1280  -vyres  720
sudo service lightdm start
And voila you will see the login screen is at 720p and not 1080p. login and it will remain at 720p. Keep in mind this needs to be done everytime you reboot the board or you can simply make a script to do just that at startup Wink
I have a monitor with 1280 * 1024 resolution.
Would the code here work for me if I change  "720" to "1024"
I'm running the Debian Jessie you released June 30th (thanks! btw)
Display resolutions? - by Sailing_Nut - 04-06-2016, 09:05 AM
RE: Display resolutions? - by Sailing_Nut - 04-06-2016, 11:10 AM
RE: Display resolutions? - by Newfies - 07-13-2016, 01:21 PM
RE: Display resolutions? - by Sailing_Nut - 04-07-2016, 06:48 AM
RE: Display resolutions? - by LinuxGeek - 04-07-2016, 11:34 AM
RE: Display resolutions? - by Leoncito81 - 04-28-2016, 03:34 AM
HDMI resolution - by baryluk - 04-27-2016, 05:00 PM
  Rotate Display boyatomic 2 5,127 03-07-2017, 06:47 PM
Last Post: Kiwiboyus
Question Ultrawide Display for Ubuntu Mate DE dudeytsang 1 5,036 01-01-2017, 07:26 AM
Last Post: CaptainZalo
