Battery drained while turned off
(07-17-2018, 02:27 AM)Wizzard Wrote: Where did you find Ubuntu Mint? Is is just ayufans Ubuntu with some packages installed or is it a completely different image?
I suspect it was a typo, and he meant 'Mate' , since he then mentioned the i3 image. btw, he hasn't been around since March, so you may not get a reply.
Battery drained while turned off - by amentis - 03-02-2018, 01:11 PM
RE: Battery drained while turned off - by tllim - 03-05-2018, 08:30 PM
RE: Battery drained while turned off - by guidol - 03-06-2018, 07:34 AM
RE: Battery drained while turned off - by Wizzard - 07-17-2018, 02:27 AM
RE: Battery drained while turned off - by pfeerick - 07-17-2018, 02:38 AM
  Display battery charge value with LXDE and lxpanel wlad 1 4,881 12-04-2019, 03:36 AM
Last Post: pnts-se
  Improve the life of your Pinebook battery by setting charger's voltage limits wlad 0 2,795 06-11-2019, 02:27 PM
Last Post: wlad
  How can I reliably get battery status on pinebook tillea 5 8,723 06-11-2019, 10:10 AM
Last Post: wlad
  Battery Status in Bionic X-Istence 3 5,073 03-11-2019, 03:52 PM
Last Post: soupbowl
  .bashrc to show battery percentage at prompt e-minguez 1 3,066 03-05-2019, 07:03 PM
Last Post: PatrickM
  Splash But No Login After Low Battery robbiemacg 3 4,623 05-17-2018, 09:30 AM
Last Post: robbiemacg
Information i3wm xenial-i3 introduction -- mate terminal & battery monitor MarkHaysHarris777 4 7,057 08-31-2017, 04:47 AM
Last Post: shirman
