Any OS for 2K Monitor?
(02-19-2018, 02:07 PM)dkryder Wrote: i get 1920x1080 [full HD] on my pine64 64A 2GB board when it is properly declared in uEnv.txt. my understanding is that 1920x1080 is full HD. also, 1920x1080 as you can see is just short of 2,000 pixels wide and could be considered 2K. 2560x1440 is more commonly [in my neck of the woods] called 1440p. as you can see it is actually 2.5K you might contact ayufan in chat and check if a 1440p works and if so how to configure, as Luke mentioned it is sorta not desktop screen, especially @ 165Hz.
Thank you for your answer. I don't need to run at 165HZ, i just want to be able to use my Pine64 with my current display. I am the one who bought when it was a project on Kickstarter. Since then i couldn't use my board properly. At the early days (when i have full hd display) we were out of the OS. Now i see some pretty OS but can not get any signal to my display. My board is getting decay day by day in my drawer.
*I also wanted to use it as a headless board with OpenMediaVault but i got error when i try to mount the usb drive.
*Then tried to flash with Volumio to stream music via Airplay from iPhone and Macbook, it has a backround noise like (hissss) and also if you turn up the volume like almost more than 25% you backround noise kills the music.
I will try to contact with Ayufan and update the post with what i learned. Please, any idea will be nice.
Thank you.
Any OS for 2K Monitor? - by sercancayir - 02-19-2018, 11:22 AM
RE: Any OS for 2K Monitor? - by Luke - 02-19-2018, 01:03 PM
RE: Any OS for 2K Monitor? - by dkryder - 02-19-2018, 02:07 PM
RE: Any OS for 2K Monitor? - by sercancayir - 02-20-2018, 04:21 AM
  Rezize Monitor ? Spore 1 2,756 02-28-2017, 09:51 PM
Last Post: MarkHaysHarris777
  Use a iMac as Monitor SirLenuxx 4 5,872 04-19-2016, 09:15 PM
