Linux Kernal Development - BETA Boards
#29
(12-28-2015, 04:59 AM)Kommander Wrote: LPAE on ARM processors
...has been introduced long ago (Cortex-A15/A7) to solve the hard 4 GB limitation that would otherwise exist due to ARMv7 being a 32 bit architecture. Does that mean that any A15/A7 SoC is able to address more than 4 GB physical memory? Of course not. This depends on the SoC in question. Most if not all Allwinner SoCs are able to address 2 GB physical memory (16Gb) and the A64 is now able to use 3 GB (24Gb) when modules become available.
Since the A64 is a tablet SoC this memory limitation is acceptable. Other ARMv8 SoCs target other uses and therefore they're able to address much much more physical memory (AMD's A1100 for example is able to use up to 128 GB).
BTW: LPAE limits you to a 40 bit address space (ARMv7) while ARMv8 is able to use an 48 bit address space. LPAE is still there since "for compatibility reasons, we still support the entire ARMv7 machine in the new ARMv8 architecture" (quoting ARM).
HTH
RE: Linux Kernal Development - BETA Boards - by tkaiser - 12-28-2015, 05:18 AM
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 9,312 03-28-2020, 06:20 PM
Last Post: ty1911
  Howto run Linux with resolution other than 1080p longsleep 28 66,847 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 5,146 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,293 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 48,842 01-28-2019, 11:05 PM
Last Post: necrose99
  +LTS/SOPINE +PINEBOOK Mainline Armbian for A64 boards Luke 0 2,582 01-12-2019, 06:35 AM
Last Post: Luke
  Real-time linux kernel Artyom 45 73,220 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 6,202 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 5,853 01-30-2018, 10:26 AM
Last Post: Rustproof
  eta linux image?? firosiro 1 4,087 08-03-2017, 10:05 PM
Last Post: pfeerick
