Possible Hardware Fault/Issue
Hi All,
I have 2 brand new rock64's 2GB. they arrived a week ago. Overall very impressed compared to my old raspberry pi.
I have installed and done a basic linux / armhf config using ayufan-rock64 (jessie-omv-armhf). Everything working fine and i'm using brand new SD cards.
I setup the second board exactly the same - again using a brand new SD card. All fine for a while then i noticed occasional issues with the OMV web interface restarting. looked at the syslog and i see the board has done a reboot cycle. there is no load on the board just restart without any user intervention. Happens every few hours but no pattern.
Thought it was an installation issue so started over but same issue.
Now i am using the same SD card and swapping between the 2 boards using same network cable and power supply.  I can can firm the issue only happens on one of the two boards.
Nothing in the logs that I can find but I'm not an expert...
Can anyone help or is this a support issue for Pine 64?
Possible Hardware Fault/Issue - by jata - 11-29-2017, 12:24 PM
RE: Possible Hardware Fault/Issue - by xalius - 11-29-2017, 04:19 PM
RE: Possible Hardware Fault/Issue - by jata - 11-29-2017, 06:18 PM
RE: Possible Hardware Fault/Issue - by jata - 11-30-2017, 08:07 AM
RE: Possible Hardware Fault/Issue - by tllim - 12-03-2017, 11:46 AM
RE: Possible Hardware Fault/Issue - by jata - 12-03-2017, 12:51 PM
RE: Possible Hardware Fault/Issue - by xalius - 11-30-2017, 01:29 PM
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? klausfelix 0 1,557 07-02-2021, 03:13 PM
Last Post: klausfelix
Question Hardware issues with Rock64 grobbs 10 10,150 04-08-2021, 05:24 AM
Last Post: t4_4t
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? hunderteins 10 15,364 11-17-2020, 08:00 AM
Last Post: Johannes
  HDMI 2.0a CEC compliancy issue? Willem53 1 2,537 04-13-2019, 08:02 AM
Last Post: Willem53
  self-reboot issue pas059 6 7,035 02-11-2019, 05:02 AM
Last Post: pas059
  C++ GPIO seg fault on Rock64 using Pine64-CPP Jeff R 1 3,467 02-06-2019, 07:40 PM
Last Post: Jeff R
  Rock64 scipy, numpy, scikit-image, matplotlib issue with pip3 ictele 0 2,029 02-05-2019, 05:41 PM
Last Post: ictele
  My Rock64 no power or light issue Nolaboy406 3 4,427 07-24-2018, 12:52 AM
Last Post: Luke
  Reboot Issue with ROCK64 Linux version 4.4.77-rockchip-ayufan-141 techyjtmb 9 10,323 06-23-2018, 09:52 AM
Last Post: NablaMetal
  Hardware Acceleration H264 encoding fred-simard 1 3,713 06-07-2018, 04:53 PM
Last Post: evilbunny
