running 32 bit arm
The armv8 processors can run in 32bit mode (like the Raspberry Pi 3 currently does) but the Linuxes do not support a mixed mode.
So everything is either 32 bit (OS and userland) or 64 bit.
You would have to build a 64bit btsync from source, but it's closed source, so that's no option.
A 32bit Linux does not exist for the Pine, so you cannot run the btsync binary.
Edit:
After reading the refered Debian post it indeed looks possible with the Debian multi Arch framework, but trying to reproduce this on Arch linux is obviously not the easy road.
You have two challenges at once:
Running Debian packages on Arch and running 32bit apps on a 64bit platform. Regarding the latter, I am not familiar with the Arch features for multi arch.
I would start with using the Debian based Ubuntu image instead of the Arch image.
If you really want to use Arch instead of Ubuntu then you should first try to run a simple standard Arch 32 bit binary like eg "cat" on your 64bit Arch installation. If that works you could focus on the Debian btsync.
Edit 2:
You'll need a kernel compiled with the
config ARMV7_COMPAT
option set for 32bit compatibility. See
https://github.com/longsleep/linux-pine6...64/Kconfig
Just checked, the longsleep kernel has this option set, so it should be possible to get it working...
Edit 3:
Shouldn't you use something like
pacman -S --arch armv7h glibc
instead of "arm"?
running 32 bit arm - by falk.ben@gmail.com - 04-01-2016, 10:31 AM
RE: running 32 bit arm - by tomtor - 04-03-2016, 01:39 AM
RE: running 32 bit arm - by falk.ben@gmail.com - 04-04-2016, 09:30 AM
RE: running 32 bit arm - by Pander - 01-25-2017, 10:15 AM
RE: running 32 bit arm - by falk.ben@gmail.com - 01-25-2017, 10:33 AM
RE: running 32 bit arm - by Pander - 01-25-2017, 10:44 AM
RE: running 32 bit arm - by umiddelb - 04-04-2016, 09:37 AM
RE: running 32 bit arm - by falk.ben@gmail.com - 01-27-2017, 10:30 AM
  Fedora Running On Pine64! cztian 26 37,498 10-26-2017, 05:51 PM
Last Post: gregjo
  Can't boot headless after running update_uboot.sh Borglesnorgle Williams 2 4,334 08-17-2017, 04:08 AM
Last Post: Borglesnorgle Williams
  Pine64 will be supported by HypriotOS (a Debian Jessie based OS for running Docker) Quintus23M 9 17,055 02-03-2017, 05:50 AM
Last Post: pfeerick
Question Need help : Issue in running compiled kernel with tftp+uboot dinesh.bhoyar 2 4,705 01-30-2017, 12:44 AM
Last Post: dinesh.bhoyar
