Receiving errors about eMMC (?)
(08-17-2018, 04:20 PM)mikekehrli Wrote: Ok, thanks a lot.  That helped.
I'm still having stability issues with my rock64. It keeps crashing for no apparent reason and no help in any of the logs. I would say it crashes after about 10-12 hours of run time. So, I can't use it yet.  I took the emmc card out and am booting from SD card, but root partition is on a USB ssd. I've heard of stability issues with the usb3 port. Currently I'm testing it by writing 1 GB files back and forth between ssd and SD partitions. That's been running for 1/2 hour without incident.
I want to get to the bottom of this.  I'm not doing anything fancy with it, but it keeps dying on me.  I'm using debian from ayufan too. I've gotta think there is something wrong at kernel level for it to die without logging anything.
About random hangs: yes, I've had a bunch of those too, they are quite random in my case, the board works perfectly for a few days but then suddenly it hangs.
It does not crash, it hangs, stops dead in its tracks.
I use rockchip-linux bsp kernel with a bunch patches taken from ayufan's and Kwiboo's repos , one of the mods I use converts the red led into a heart-beat, if the cpu is alive - its blinking.
When the board dies the led stops blinking, I have a usb-ttl (uart) adapter constantly plugged into my "big" server, which logs everything coming from the rock64,
when the board hangs nothing gets logged, no backtrace, no panic, nothing.
So my guess would be - yes, it's some low-level kernel or hardware problem.
Don't think it's related to emmc tho, I've had those hangs with sdcard too.
When this happens the best way to deal with it IMO is to completely remove power for a few minutes.
Receiving errors about eMMC (?) - by acasta - 10-12-2017, 11:31 AM
RE: Receiving errors about eMMC (?) - by acasta - 10-19-2017, 10:16 AM
RE: Receiving errors about eMMC (?) - by gusarg81 - 08-02-2018, 10:02 PM
RE: Receiving errors about eMMC (?) - by asavah - 08-15-2018, 03:09 PM
RE: Receiving errors about eMMC (?) - by asavah - 08-16-2018, 10:34 AM
RE: Receiving errors about eMMC (?) - by asavah - 08-20-2018, 04:41 PM
RE: Receiving errors about eMMC (?) - by ridgarou - 09-24-2019, 10:26 PM
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,076 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 2,989 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 3,740 08-19-2021, 06:46 PM
Last Post: bcnaz
  USB -> eMMC is now available. Luke 15 29,236 07-27-2019, 04:27 PM
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 106,005 02-06-2019, 04:02 PM
  flash image to sd/emmc through ethernet LMM 0 2,290 02-04-2019, 07:36 AM
Last Post: LMM
  OMV - graphical distortion and SIP errors Mentaluproar 4 5,378 06-27-2018, 04:06 PM
Last Post: Mentaluproar
  Card emmc Auggoncalves 2 3,696 06-25-2018, 03:20 AM
Last Post: Auggoncalves
  Debian to eMMC? Hoerli 7 8,613 05-06-2018, 05:41 PM
Last Post: pfeerick
  [SOLVED] stuck at emmc dr_dre 10 12,688 04-29-2018, 05:10 PM
Last Post: pfeerick
