Is android fluid on your pine?
(04-01-2016, 12:52 AM)lucassou Wrote: (8MB/s write and 16 Read) but seriously even with a slow sd card it should not be this laggy and unstable, am i the only one?
The numbers you posted are absolutely irrelevant since they're about sequential transfer speeds and in case you haven't tested them on your own and they're just written on the card or the packaging they might even not be true at all.
What you experience is an ultra slow SD card regarding random I/O (maybe a counterfeit card). I don't get why the Pine64 folks do not warn their users that they should always check SD cards prior to usage. This wrongly labeled Wiki entry here isn't enough: http://wiki.pine64.org/index.php/Pine_A6...eit_Drives
Android devices are shipped normally with an internal NAND or eMMC storage that shows pretty high random I/O performance. When you choose a cheap SD card instead random I/O might be 50 to hundred times slower. And that's what you're currently suffering from.
Is android fluid on your pine? - by lucassou - 04-01-2016, 12:52 AM
RE: Is android fluid on your pine? - by Andrew2 - 04-01-2016, 12:58 AM
RE: Is android fluid on your pine? - by lucassou - 04-01-2016, 01:06 AM
RE: Is android fluid on your pine? - by Andrew2 - 04-01-2016, 01:29 AM
RE: Is android fluid on your pine? - by benpope81 - 04-01-2016, 06:21 AM
RE: Is android fluid on your pine? - by lucassou - 04-01-2016, 11:30 AM
RE: Is android fluid on your pine? - by gtpboy - 04-01-2016, 01:22 PM
RE: Is android fluid on your pine? - by tllim - 04-01-2016, 10:11 PM
RE: Is android fluid on your pine? - by lucassou - 04-02-2016, 04:47 AM
RE: Is android fluid on your pine? - by gtpboy - 04-02-2016, 02:58 PM
RE: Is android fluid on your pine? - by GoZone - 04-04-2016, 05:41 PM
RE: Is android fluid on your pine? - by gtpboy - 04-11-2016, 03:29 PM
RE: Is android fluid on your pine? - by gtpboy - 04-11-2016, 10:19 PM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 392,857 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 30,070 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 17,042 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,054 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,146 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,681 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,377 07-15-2019, 08:29 PM
  Bliss OS (PINE A64(+)) pineadmin 4 12,544 06-07-2019, 09:01 PM
Last Post: nukedawg
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 261,876 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,588 02-26-2019, 11:58 AM
Last Post: Twistedx
