Compatible LCD DSI
(01-09-2018, 04:15 AM)desai_amogh Wrote:
(12-26-2017, 02:23 PM)drock Wrote: correct there is no touch screen.  The cable coming off the screen will plug directly into the DSI port(its is a 30pin .5mm pitch ribbon), but it is very short and I do not recommend it for purposes other than testing. Unless you make a housing that will properly secure this setup you should buy an extension. It's a basic part and cheap, for example:
https://www.ebay.com/i/162768952020?chn=ps
There are number available.  I think you can get these from somewhere like mouser as well.
I have almost found the touch panel separate as well, but not with the correct cable. I think that most of these touch panels come with a straight cable that goes into a touch panel ic, but the one used by the pine is a bit different and has an ic inline on the ribbon cable.
If I am incorrect someone let me know.
@drock check this post. hope this helps.
Third Party LCD Panel and Touch Screen options for Pine64
Thanks on posting this article link :-)
Compatible LCD DSI - by drock - 10-02-2017, 10:42 PM
RE: Compatible LCD DSI - by dkryder - 10-03-2017, 12:44 AM
RE: Compatible LCD DSI - by drock - 10-03-2017, 12:00 PM
RE: Compatible LCD DSI - by dkryder - 10-03-2017, 08:35 PM
RE: Compatible LCD DSI - by drock - 10-05-2017, 09:49 PM
RE: Compatible LCD DSI - by dkryder - 10-06-2017, 05:05 AM
RE: Compatible LCD DSI - by tllim - 10-11-2017, 01:02 AM
RE: Compatible LCD DSI - by desai_amogh - 12-12-2017, 02:42 AM
RE: Compatible LCD DSI - by drock - 12-20-2017, 03:51 AM
RE: Compatible LCD DSI - by tllim - 12-21-2017, 12:39 PM
RE: Compatible LCD DSI - by ricoli - 12-25-2017, 11:25 AM
RE: Compatible LCD DSI - by tllim - 12-25-2017, 03:34 PM
RE: Compatible LCD DSI - by drock - 12-26-2017, 02:23 PM
RE: Compatible LCD DSI - by desai_amogh - 01-09-2018, 04:15 AM
RE: Compatible LCD DSI - by tllim - 01-09-2018, 08:05 PM
RE: Compatible LCD DSI - by drock - 01-11-2018, 02:11 AM
RE: Compatible LCD DSI - by dkryder - 01-09-2018, 07:08 PM
RE: Compatible LCD DSI - by desai_amogh - 01-09-2018, 10:40 PM
RE: Compatible LCD DSI - by desai_amogh - 01-11-2018, 03:15 AM
RE: Compatible LCD DSI - by desai_amogh - 01-11-2018, 04:53 AM
RE: Compatible LCD DSI - by drock - 01-11-2018, 08:01 PM
RE: Compatible LCD DSI - by desai_amogh - 01-11-2018, 11:43 PM
  Search Compatible 10.1" touchscreen alfredo78 0 2,214 07-06-2018, 03:48 AM
Last Post: alfredo78
  8inch display compatible to FY07024DI26A30-D mbt28 0 2,375 01-26-2017, 10:07 AM
Last Post: mbt28
