How to Write an Image to the eMMC Module Tutorial
#31
I edited your previous post to put your logs in a code block;  always do this please, it makes reading your post much easier for everyone.  thanks.
(09-03-2017, 01:15 PM)rhille Wrote:
(09-03-2017, 12:10 PM)MarkHaysHarris777 Wrote:
(09-03-2017, 07:43 AM)z4v4l Wrote: Why installation is not done by just like this:
1) insert an SD card card with the "minimal" linux.
2) snap an empty eMMC in
3) turn the board on, boot from SD
4) download an image and flash it into eMMC by that smartass script.
I know it's obvious and hardly nobody could think of it before, rather there are some obstacles to do so. What they are?
Hi, the reason your simplified approach will not work is that boot precedence and eMMC initialization create two problems which prevent it.  If there is an image on the eMMC already, then the eMMC will boot 'first'.  If there is no image on the eMMC then either the machine will not boot, or if it does boot,  both devices will not be 'seen' by the OS during initialization; both mmcblk0 and mmcblk1 must be present, AND the machine has to be booted from SD.
The jumper used has one function,  it grounds the clock line of the eMMC, deactivating it temporarily;  that way the SD card will boot-up because (for all intents and purposes) the eMMC is not there.  We interrupt the boot-up at the uboot timer and then continue the bootup with the jumper removed--  this allows the boot-up to continue on SD, but also allows the OS to 'see' the eMMC module during initialization.
Thanks for the question.
Seems I'm missing something here because
booted from sd
Can you enlight me?
What is your question , please ?
RE: How to Write an Image to the eMMC Module Tutorial - by MarkHaysHarris777 - 09-03-2017, 01:42 PM
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,076 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 2,989 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 3,740 08-19-2021, 06:46 PM
Last Post: bcnaz
  Download IDB fail when trying to flash Android image cherkasoff 0 4,354 04-05-2020, 07:41 AM
Last Post: cherkasoff
  Receiving errors about eMMC (?) acasta 11 15,915 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 29,234 07-27-2019, 04:27 PM
  Rock 64 network error as soon as I try to write or read. georgegohl888 1 2,996 03-12-2019, 09:35 AM
Last Post: georgegohl888
  Rock64 scipy, numpy, scikit-image, matplotlib issue with pip3 ictele 0 2,027 02-05-2019, 05:41 PM
Last Post: ictele
  flash image to sd/emmc through ethernet LMM 0 2,290 02-04-2019, 07:36 AM
Last Post: LMM
  HW image transitions in Python gaggleoxfoggy 7 8,006 11-24-2018, 10:41 AM
Last Post: gaggleoxfoggy
