How to Write an Image to the eMMC Module Tutorial
(08-15-2017, 11:46 AM)fire219 Wrote: Really good guide!
But I would just like to make it clear that this guide is for Linux images!  Maybe you should mention that clearly in the OP, Mark. Wink
If you are looking for how to install Android onto eMMC, there are much easier ways. Such as my own SADIE script. Windows version of SADIE is still in the works, hopefully for release later this week. Smile
Noted, and corrected.  Actually, this process is much much easier than it at first glance appears;  I used this procedure today during test and loaded my new Rock64 board eMMC in less than ten minutes from start to finish -- no hits, no runs, no errors !
I also have ported ayufan's script to the rock64 -- rock64_install_to_emmc,  which further simplifies things by allowing the user to select the system and version, as well automatically generating the curl file;  very nice.
Thanks for the tip fire219.
(08-15-2017, 08:06 AM)jl_678 Wrote: I just searched the forums and cannot find the serial console tutorial that you refer to. Can you provide a link? I have a serial cable that I have used with RPis over the years and so am hoping that I can use that one.
Sent from my SM-T537V using Tapatalk
My apologies, I found it here: https://forum.pine64.org/showthread.php?tid=4674
Thank you for the tip;  I corrected the post with the hyper-link;  the intended one you may get right here.
RE: How to Write an Image to the eMMC Module Tutorial - by MarkHaysHarris777 - 08-15-2017, 12:05 PM
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,089 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 3,015 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 3,774 08-19-2021, 06:46 PM
Last Post: bcnaz
  Download IDB fail when trying to flash Android image cherkasoff 0 4,396 04-05-2020, 07:41 AM
Last Post: cherkasoff
  Receiving errors about eMMC (?) acasta 11 16,000 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 29,512 07-27-2019, 04:27 PM
  Rock 64 network error as soon as I try to write or read. georgegohl888 1 3,019 03-12-2019, 09:35 AM
Last Post: georgegohl888
  Rock64 scipy, numpy, scikit-image, matplotlib issue with pip3 ictele 0 2,035 02-05-2019, 05:41 PM
Last Post: ictele
  flash image to sd/emmc through ethernet LMM 0 2,300 02-04-2019, 07:36 AM
Last Post: LMM
  HW image transitions in Python gaggleoxfoggy 7 8,072 11-24-2018, 10:41 AM
Last Post: gaggleoxfoggy
