USB-port powering & CEC support
Hello everyone! where i can get the Information if it’s possible to power up/down the USB-ports seperately?
I' m not sure if the information under the storage section at http://wiki.pine64.org/index.php/ROCK64_Main_Page :
  • 2 USB2.0 Dedicated Host port (one of them is USB-OTG)
mean what i wish they do Huh .
I’m looking forward to buy this board and use it as kind of all-in-one-device (router, wifi ac with USB wifi dongle,
kodi 4k video player, pi-hole-like ad-filter and something like a NAS. For this reason i need to know if i can power
an external USB 2.0 or 3.0 harddrive on demand only for example for a scheduled backup-task. Afterwards i wish to cut the power thus the hard drive don’t has to run all the time unlike the board itself (which should run 24/7). Also it would nice to know which commands are used to enable USB Powering ON/OFF for each USB-port
My 2nd question: Is the rock64 media board fully supported with CEC controls using Linux Distributions?
Thanks in advance Wink
USB-port powering & CEC support - by gonzo - 08-04-2017, 03:42 AM
RE: USB-port powering & CEC support - by Luke - 08-04-2017, 03:54 AM
RE: USB-port powering & CEC support - by gonzo - 08-04-2017, 04:07 AM
RE: USB-port powering & CEC support - by pfeerick - 08-04-2017, 07:46 AM
RE: USB-port powering & CEC support - by gonzo - 08-04-2017, 09:53 AM
RE: USB-port powering & CEC support - by pfeerick - 08-04-2017, 06:57 PM
RE: USB-port powering & CEC support - by gonzo - 08-07-2017, 10:36 AM
  Testing USB port(s) clach04 2 3,081 09-29-2021, 07:18 PM
Last Post: Rocklobster
  Trustzone support for Rock64 capablegh 1 2,433 07-17-2021, 10:15 AM
Last Post: capablegh
  Sent support order status , no responses RockPro64Newbie 3 6,085 01-19-2021, 12:09 PM
Last Post: mathygreen
  Rock64 problems with external Hard Drive and powering mjd 1 2,865 12-14-2019, 10:05 AM
Last Post: helsinki92
Photo Has anyone been able to get a signal from the av/composite/cvbs port? bestpc 2 3,874 09-17-2019, 12:51 PM
Last Post: bestpc
  10 bit HEVC support on Rock64? Bowser 3 5,925 01-07-2019, 09:05 AM
  WiringPi support for Rock64 CristianM 1 3,001 12-26-2018, 08:02 AM
Last Post: CristianM
Exclamation Volumio 2 on Rock64 support gkkpch 5 10,835 12-01-2018, 05:05 PM
Last Post: Luke
  Does this support AES-NI instructions? oealias 1 4,268 06-08-2018, 02:56 AM
Last Post: wirr
  [Issue] Can't install the LibreElec Port from Raybuntu k0Lm_ 1 2,880 03-23-2018, 04:31 PM
Last Post: k0Lm_
