Way to boot quickly in to a single java application?
It doesn't really matter what distro you use. I don't think anyone has profiled the bootup times of the different ones. Quickly logging into a java application is pretty easily done, just google "auto login <your distro>" to find out how to do that, and then "run command on startup" after that.
Yes someone probably could make a distro that did just that, but why would they? Its far easier to make one general purpose linux distro image and then have the user configure it how they want from there.
RE: Way to boot quickly in to a single java application? - by Epsilon - 03-23-2016, 10:38 AM
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,310 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Secure boot & OTP efuse program devangpanchal90 0 2,628 05-25-2018, 01:59 AM
Last Post: devangpanchal90
  boot process for pine a64 awaysu 1 4,453 01-24-2018, 05:09 AM
Last Post: xalius
  Can't boot headless after running update_uboot.sh Borglesnorgle Williams 2 4,340 08-17-2017, 04:08 AM
Last Post: Borglesnorgle Williams
Exclamation Pine A64 Plus Fails to Boot grobbs 35 41,906 06-28-2017, 08:53 AM
Last Post: sarav_sara
  Boot issues: What todo when you muck up your FSTAB file Dagremote 1 3,827 04-16-2017, 10:28 PM
Last Post: pfeerick
Question Pine64 cannot boot jamiechang917 6 9,808 04-16-2017, 10:21 PM
Last Post: pfeerick
  U-Boot for A64 git longsleep 38 69,948 03-21-2017, 01:59 PM
Last Post: longsleep
  OpenWRT supports ARMv8 - arm64, u-boot problem? rgdonato 4 6,861 03-20-2017, 03:59 PM
Last Post: rgdonato
  USB OTG Boot devilsclaw 25 39,754 03-01-2017, 03:22 PM
Last Post: CaptainZalo
