Ethernet issue
Installed the latest pine64-image-debianmate-310102bsp-2.img, it flashed fine, running on a Pine64 2GB board, using the Wi-Fi / BT module.
When Debian starts up, the Eth0 connection says connected, and the negotiation icon on top right stays on and moving, thing is, i don't even have an Ethernet cable plugged in and it says "Connected"? I have to disconnect the connection before it stops. When I plug an Ethernet cable in, it will not initiate DHCP, or if i insert static, there is just no connection.
I even inserted the SD into another Pine64 board, same result. Eth0 just won't work, Wi-FI works fine though. Any suggestions?
p.s I did run the scripts to update etc...
Ethernet issue - by Matthew - 07-21-2017, 06:23 AM
RE: Ethernet issue - by MarkHaysHarris777 - 07-21-2017, 07:07 AM
RE: Ethernet issue - by Matthew - 07-21-2017, 07:51 AM
RE: Ethernet issue - by Luke - 07-21-2017, 08:09 AM
RE: Ethernet issue - by Matthew - 07-21-2017, 08:24 AM
  Strange OpenSSL RSA speed Test issue _835_ 2 3,629 07-27-2017, 12:51 AM
Last Post: _835_
  Variable Gigabit Ethernet speed? sheffield_nick 4 5,857 08-24-2016, 11:26 PM
Last Post: MarkHaysHarris777
  network issue with no ethernet chrwei 4 7,307 05-03-2016, 11:22 AM
Last Post: longsleep
