Adding battery and charging circuit
(07-19-2017, 07:39 AM)advait Wrote: Hi
How can we add a battery and a charging circuit on Rock64 ?
And can rock64 display the battery status on the android 7.1 image ?
Well , that's why I told you earlier that the RK3328 is not well suited for notebook use;  it has no battery support, nor LCD support!
Having said that, depending on your engineering skills, you might be able to design a gpio controlled 12v solar charging system for use with the Rock64;  some of us have done similar with the RPi, and other SBC SoC(s);  but ofc that is up to you alone.
Adding battery and charging circuit - by advait - 07-19-2017, 07:39 AM
RE: Adding battery and charging circuit - by MarkHaysHarris777 - 07-19-2017, 07:49 AM
  Read battery state MaWalla 5 9,119 05-27-2021, 06:00 AM
Last Post: iotarduinos
  RTC backup battery max 0 1,769 05-14-2019, 09:35 AM
Last Post: max
Question Adding RTL8723BU Chip shripal17 0 1,816 03-28-2019, 04:10 AM
Last Post: shripal17
