running Installer
I downloaded from the link in your responsee "xenial-mate-pinebook 0.6.-74.img.xz" as a Raw disk image (xz compressed) and the make executable box was checked.  Mate's Disk utility reported that the image was 7.9GB smaller than my 8GB Sandisk SD card. When I enter Restore, nothing happens.  there are 4 partitions on the Sandisk, the largest is 7.6GB as "linux," and their contents are the same before and after Restore three times.
I tried extracting the image, but get an "insufficient space on :/root, please delete files," but I haven't how to do this in searching some of the threads.
Otherwise, I did manage a command line solution for "insuffcient room to update and upgrade."
Maybe I should just stay with my 16.10/3.10 kernel instead of worrying about 17, until it comes through Upgrade?
I also found some "Hardware" advice about how to tolerate the unresponsive keyboard.
I did go to the IRS channel, but I think the conversation is too fast for me to really participate there.  Maybe I'll look again.
Thank you again for any advice you'll have time to post.
running Installer - by stanley9000 - 07-02-2017, 09:15 AM
RE: running Installer - by pfeerick - 07-02-2017, 09:29 PM
RE: running Installer - by stanley9000 - 07-06-2017, 06:55 AM
RE: running Installer - by pfeerick - 07-07-2017, 02:33 AM
RE: running Installer - by stanley9000 - 07-08-2017, 01:26 PM
RE: running Installer - by stanley9000 - 07-17-2017, 04:15 PM
RE: running Installer - by pfeerick - 07-18-2017, 07:26 PM
RE: running Installer - by MarkHaysHarris777 - 07-17-2017, 09:43 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 152,509 01-15-2020, 12:46 PM
  Pine64 installer way slow flashing Paraplegic Racehorse 2 4,579 01-10-2018, 04:05 PM
Last Post: dkryder
  Running Netflix marcostt 4 7,313 10-09-2017, 09:50 AM
Last Post: marcostt
Smile Up and Running! Anunnaki 2 4,788 04-17-2016, 07:15 AM
Last Post: bigdaddy
