running Installer
lol... brag away... have to earn those brownie points somehow to ensure you can keep buying toys Wink
Ok, I *think* I might have finally gotten my head around what the problem is... you're trying to run the pine64-installer on the pinebook itself, aren't you? If so, it won't work, and neither will etcher, as they do not have a ARMHF/ARM64 version for you to run.
What I would suggest you do if this is indeed the case is
  1. Download the current Ubuntu Mate build for the pinebook
  2. Use the Disks utility in Ubuntu Mate (System -> Preferences -> Hardware -> Disks) to write it to a MicroSD card, so you can boot from the microSD card. [In the Disks tool, you'll want to highlight the SD card reader, then click the menu button up at the top right of the window (has three horizontal lines), choose 'Restore Disk Image' and then find that ubuntu Mate image you just downloaded]
  3. Reboot the Pinebook with the newly made boot microSD, and it should boot from the microSD you just wrote to.
  4. Connect to the internet (wifi, ethernet over usb, etc).
  5. Open a terminal (Applications -> System Tools -> Mate Terminal) and run 'sudo pine64_install_to_emmc.sh xenial-mate' to download and install the Ubuntu Xenial Mate image to your Pinebook's eMMC.
running Installer - by stanley9000 - 07-02-2017, 09:15 AM
RE: running Installer - by pfeerick - 07-02-2017, 09:29 PM
RE: running Installer - by stanley9000 - 07-06-2017, 06:55 AM
RE: running Installer - by pfeerick - 07-07-2017, 02:33 AM
RE: running Installer - by stanley9000 - 07-08-2017, 01:26 PM
RE: running Installer - by stanley9000 - 07-17-2017, 04:15 PM
RE: running Installer - by pfeerick - 07-18-2017, 07:26 PM
RE: running Installer - by MarkHaysHarris777 - 07-17-2017, 09:43 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 153,448 01-15-2020, 12:46 PM
  Pine64 installer way slow flashing Paraplegic Racehorse 2 4,616 01-10-2018, 04:05 PM
Last Post: dkryder
  Running Netflix marcostt 4 7,336 10-09-2017, 09:50 AM
Last Post: marcostt
Smile Up and Running! Anunnaki 2 4,809 04-17-2016, 07:15 AM
Last Post: bigdaddy
