Enabling wolfson wm8960 i2c/i2s sound codec
(05-29-2017, 04:24 AM)tllim Wrote:
(05-26-2017, 07:23 AM)saro Wrote: Hi,
I'm trying to use the chip wolfosn wm8960, that is connected with I2C interface and I2S bus.
Polling it on the I2C bus, the peripheral is recognized with address 0x1a on i2c-1, but nothing related to this device like sound card found.
Another preliminary step follewed is the kernel compilation, making by activation the driver wm8960 found in sound/soc/devices/ like built-in and enabling all voices found in  "--- ASoC support for SUNXI" of menuconfig.
At this step, applying the new kernel, I don't found any peripheral with arecord -l or aplay -l or with pactl command and there isn't any row in the syslog/kernlog that show me that the wm8960 device is found.
There are few references for this codec, but I'm trying to follow the guide posted for another soc (i.MX6) in which the device driver already built-in inside the kernel source tree, showed at: https://community.nxp.com/docs/DOC-106295
Another link (for i-MX6) report also that:
WM8960
Driver location: linux/sound/soc/codecs/wm8960.c
Machine driver location: linux/sound/soc/imx/imx-wm8960.c
1.In Kernel Configuration, go to
Device Drivers --> Sound card support --> Advanced Linux Sound Architecture --> ALSA for SoC audio support --> SoC Audio for Freescale i.MX CPUs -->
2.Select <*> SoC Audio support for IMX boards with WM8960
In this case, I found
I have to specify, for example, some configuration in the dts device tree?
Is impossible to see the peripheral because there isn't the imx-wm8960.c machine based driver file matching the pine64 board?
Can someone help me, please?
Thanks in advance.
Just configure wm8960 for i2S format and follow typical audio audio DTS configuration.
Hi tllim,
my dts config report that:
sound@0 {
            compatible = "allwinner,sunxi-codec-machine";
            interrupts = <0x0 0x1c 0x4>;
            sunxi,i2s-controller = <0x4c>;
            sunxi,audio-codec = <0x4d>;
            aif2fmt = <0x3>;
            aif3fmt = <0x3>;
            aif2master = <0x1>;
            hp_detect_case = <0x1>;
            status = "okay";
            device_type = "sndcodec";
        sound@1 {
            compatible = "allwinner,sunxi-daudio0-machine";
            sunxi,daudio0-controller = <0x4e>;
            status = "disabled";
            device_type = "snddaudio0";
        sound@2 {
            compatible = "allwinner,sunxi-daudio1-machine";
            sunxi,daudio1-controller = <0x4f>;
            device_type = "snddaudio1";
        sound@3 {
            compatible = "allwinner,sunxi-hdmi-machine";
            sunxi,hdmi-controller = <0x50>;
            status = "okay";
            device_type = "sndhdmi";
        sound@4 {
            compatible = "allwinner,sunxi-spdif-machine";
            sunxi,spdif-controller = <0x51>;
            device_type = "sndspdif";
and here my wm8960.c driver:
* wm8960.c  --  WM8960 ALSA SoC Audio driver
* Copyright 2007-11 Wolfson Microelectronics, plc
* Author: Liam Girdwood
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
#include <linux/module.h>
#include <linux/moduleparam.h>
#include <linux/init.h>
#include <linux/delay.h>
#include <linux/pm.h>
#include <linux/i2c.h>
#include <linux/slab.h>
#include <sound/core.h>
#include <sound/pcm.h>
#include <sound/pcm_params.h>
#include <sound/soc.h>
#include <sound/initval.h>
#include <sound/tlv.h>
#include <sound/wm8960.h>
#include "wm8960.h"
/* R25 - Power 1 */
#define WM8960_VMID_MASK 0x180
#define WM8960_VREF      0x40
/* R26 - Power 2 */
#define WM8960_PWR2_LOUT1    0x40
#define WM8960_PWR2_ROUT1    0x20
#define WM8960_PWR2_OUT3    0x02
/* R28 - Anti-pop 1 */
#define WM8960_POBCTRL   0x80
#define WM8960_BUFDCOPEN 0x10
#define WM8960_BUFIOEN   0x08
#define WM8960_SOFT_ST   0x04
#define WM8960_HPSTBY    0x01
/* R29 - Anti-pop 2 */
#define WM8960_DISOP     0x40
#define WM8960_DRES_MASK 0x30
* wm8960 register cache
* We can't read the WM8960 register space when we are
* using 2 wire for device control, so we cache them instead.
static const struct reg_default wm8960_reg_defaults[] = {
    {  0x0, 0x00a7 },
    {  0x1, 0x00a7 },
    {  0x2, 0x0000 },
    {  0x3, 0x0000 },
    {  0x4, 0x0000 },
    {  0x5, 0x0008 },
    {  0x6, 0x0000 },
    {  0x7, 0x000a },
    {  0x8, 0x01c0 },
    {  0x9, 0x0000 },
    {  0xa, 0x00ff },
    {  0xb, 0x00ff },
    { 0x10, 0x0000 },
    { 0x11, 0x007b },
    { 0x12, 0x0100 },
    { 0x13, 0x0032 },
    { 0x14, 0x0000 },
    { 0x15, 0x00c3 },
    { 0x16, 0x00c3 },
    { 0x17, 0x01c0 },
    { 0x18, 0x0000 },
    { 0x19, 0x0000 },
    { 0x1a, 0x0000 },
    { 0x1b, 0x0000 },
    { 0x1c, 0x0000 },
    { 0x1d, 0x0000 },
    { 0x20, 0x0100 },
    { 0x21, 0x0100 },
    { 0x22, 0x0050 },
    { 0x25, 0x0050 },
    { 0x26, 0x0000 },
    { 0x27, 0x0000 },
    { 0x28, 0x0000 },
    { 0x29, 0x0000 },
    { 0x2a, 0x0040 },
    { 0x2b, 0x0000 },
    { 0x2c, 0x0000 },
    { 0x2d, 0x0050 },
    { 0x2e, 0x0050 },
    { 0x2f, 0x0000 },
    { 0x30, 0x0002 },
    { 0x31, 0x0037 },
    { 0x33, 0x0080 },
    { 0x34, 0x0008 },
    { 0x35, 0x0031 },
    { 0x36, 0x0026 },
    { 0x37, 0x00e9 },
static bool wm8960_volatile(struct device *dev, unsigned int reg)
    switch (reg) {
    case WM8960_RESET:
        return true;
    default:
        return false;
struct wm8960_priv {
    struct regmap *regmap;
    int (*set_bias_level)(struct snd_soc_codec *,
                  enum snd_soc_bias_level level);
    struct snd_soc_dapm_widget *lout1;
    struct snd_soc_dapm_widget *rout1;
    struct snd_soc_dapm_widget *out3;
    bool deemph;
    int playback_fs;
#define wm8960_reset(c)    snd_soc_write(c, WM8960_RESET, 0)
/* enumerated controls */
static const char *wm8960_polarity[] = {"No Inversion", "Left Inverted",
    "Right Inverted", "Stereo Inversion"};
static const char *wm8960_3d_upper_cutoff[] = {"High", "Low"};
static const char *wm8960_3d_lower_cutoff[] = {"Low", "High"};
static const char *wm8960_alcfunc[] = {"Off", "Right", "Left", "Stereo"};
static const char *wm8960_alcmode[] = {"ALC", "Limiter"};
static const struct soc_enum wm8960_enum[] = {
    SOC_ENUM_SINGLE(WM8960_DACCTL1, 5, 4, wm8960_polarity),
    SOC_ENUM_SINGLE(WM8960_DACCTL2, 5, 4, wm8960_polarity),
    SOC_ENUM_SINGLE(WM8960_3D, 6, 2, wm8960_3d_upper_cutoff),
    SOC_ENUM_SINGLE(WM8960_3D, 5, 2, wm8960_3d_lower_cutoff),
    SOC_ENUM_SINGLE(WM8960_ALC1, 7, 4, wm8960_alcfunc),
    SOC_ENUM_SINGLE(WM8960_ALC3, 8, 2, wm8960_alcmode),
static const int deemph_settings[] = { 0, 32000, 44100, 48000 };
static int wm8960_set_deemph(struct snd_soc_codec *codec)
    struct wm8960_priv *wm8960 = snd_soc_codec_get_drvdata(codec);
    int val, i, best;
    /* If we're using deemphasis select the nearest available sample
     * rate.
    if (wm8960->deemph) {
        best = 1;
        for (i = 2; i < ARRAY_SIZE(deemph_settings); i++) {
            if (abs(deemph_settings[i] - wm8960->playback_fs) <
                abs(deemph_settings[best] - wm8960->playback_fs))
                best = i;
        val = best << 1;
    } else {
        val = 0;
    dev_dbg(codec->dev, "Set deemphasis %d\n", val);
    return snd_soc_update_bits(codec, WM8960_DACCTL1,
                   0x6, val);
static int wm8960_get_deemph(struct snd_kcontrol *kcontrol,
                 struct snd_ctl_elem_value *ucontrol)
    struct snd_soc_codec *codec = snd_kcontrol_chip(kcontrol);
    ucontrol->value.integer.value[0] = wm8960->deemph;
    return 0;
static int wm8960_put_deemph(struct snd_kcontrol *kcontrol,
    int deemph = ucontrol->value.integer.value[0];
    if (deemph > 1)
        return -EINVAL;
    wm8960->deemph = deemph;
    return wm8960_set_deemph(codec);
static const DECLARE_TLV_DB_SCALE(adc_tlv, -9700, 50, 0);
static const DECLARE_TLV_DB_SCALE(dac_tlv, -12700, 50, 1);
static const DECLARE_TLV_DB_SCALE(bypass_tlv, -2100, 300, 0);
static const DECLARE_TLV_DB_SCALE(out_tlv, -12100, 100, 1);
static const DECLARE_TLV_DB_SCALE(boost_tlv, -1200, 300, 1);
static const struct snd_kcontrol_new wm8960_snd_controls[] = {
SOC_DOUBLE_R_TLV("Capture Volume", WM8960_LINVOL, WM8960_RINVOL,
         0, 63, 0, adc_tlv),
SOC_DOUBLE_R("Capture Volume ZC Switch", WM8960_LINVOL, WM8960_RINVOL,
    6, 1, 0),
SOC_DOUBLE_R("Capture Switch", WM8960_LINVOL, WM8960_RINVOL,
    7, 1, 0),
SOC_SINGLE_TLV("Right Input Boost Mixer RINPUT3 Volume",
           WM8960_INBMIX1, 4, 7, 0, boost_tlv),
SOC_SINGLE_TLV("Right Input Boost Mixer RINPUT2 Volume",
           WM8960_INBMIX1, 1, 7, 0, boost_tlv),
SOC_SINGLE_TLV("Left Input Boost Mixer LINPUT3 Volume",
           WM8960_INBMIX2, 4, 7, 0, boost_tlv),
SOC_SINGLE_TLV("Left Input Boost Mixer LINPUT2 Volume",
           WM8960_INBMIX2, 1, 7, 0, boost_tlv),
SOC_DOUBLE_R_TLV("Playback Volume", WM8960_LDAC, WM8960_RDAC,
         0, 255, 0, dac_tlv),
SOC_DOUBLE_R_TLV("Headphone Playback Volume", WM8960_LOUT1, WM8960_ROUT1,
         0, 127, 0, out_tlv),
SOC_DOUBLE_R("Headphone Playback ZC Switch", WM8960_LOUT1, WM8960_ROUT1,
    7, 1, 0),
SOC_DOUBLE_R_TLV("Speaker Playback Volume", WM8960_LOUT2, WM8960_ROUT2,
SOC_DOUBLE_R("Speaker Playback ZC Switch", WM8960_LOUT2, WM8960_ROUT2,
    7, 1, 0),
SOC_SINGLE("Speaker DC Volume", WM8960_CLASSD3, 3, 5, 0),
SOC_SINGLE("Speaker AC Volume", WM8960_CLASSD3, 0, 5, 0),
SOC_SINGLE("PCM Playback -6dB Switch", WM8960_DACCTL1, 7, 1, 0),
SOC_ENUM("ADC Polarity", wm8960_enum[0]),
SOC_SINGLE("ADC High Pass Filter Switch", WM8960_DACCTL1, 0, 1, 0),
SOC_ENUM("DAC Polarity", wm8960_enum[1]),
SOC_SINGLE_BOOL_EXT("DAC Deemphasis Switch", 0,
            wm8960_get_deemph, wm8960_put_deemph),
SOC_ENUM("3D Filter Upper Cut-Off", wm8960_enum[2]),
SOC_ENUM("3D Filter Lower Cut-Off", wm8960_enum[3]),
SOC_SINGLE("3D Volume", WM8960_3D, 1, 15, 0),
SOC_SINGLE("3D Switch", WM8960_3D, 0, 1, 0),
SOC_ENUM("ALC Function", wm8960_enum[4]),
SOC_SINGLE("ALC Max Gain", WM8960_ALC1, 4, 7, 0),
SOC_SINGLE("ALC Target", WM8960_ALC1, 0, 15, 1),
SOC_SINGLE("ALC Min Gain", WM8960_ALC2, 4, 7, 0),
SOC_SINGLE("ALC Hold Time", WM8960_ALC2, 0, 15, 0),
SOC_ENUM("ALC Mode", wm8960_enum[5]),
SOC_SINGLE("ALC Decay", WM8960_ALC3, 4, 15, 0),
SOC_SINGLE("ALC Attack", WM8960_ALC3, 0, 15, 0),
SOC_SINGLE("Noise Gate Threshold", WM8960_NOISEG, 3, 31, 0),
SOC_SINGLE("Noise Gate Switch", WM8960_NOISEG, 0, 1, 0),
SOC_DOUBLE_R("ADC PCM Capture Volume", WM8960_LINPATH, WM8960_RINPATH,
    0, 127, 0),
SOC_SINGLE_TLV("Left Output Mixer Boost Bypass Volume",
           WM8960_BYPASS1, 4, 7, 1, bypass_tlv),
SOC_SINGLE_TLV("Left Output Mixer LINPUT3 Volume",
           WM8960_LOUTMIX, 4, 7, 1, bypass_tlv),
SOC_SINGLE_TLV("Right Output Mixer Boost Bypass Volume",
           WM8960_BYPASS2, 4, 7, 1, bypass_tlv),
SOC_SINGLE_TLV("Right Output Mixer RINPUT3 Volume",
           WM8960_ROUTMIX, 4, 7, 1, bypass_tlv),
static const struct snd_kcontrol_new wm8960_lin_boost[] = {
SOC_DAPM_SINGLE("LINPUT2 Switch", WM8960_LINPATH, 6, 1, 0),
SOC_DAPM_SINGLE("LINPUT3 Switch", WM8960_LINPATH, 7, 1, 0),
SOC_DAPM_SINGLE("LINPUT1 Switch", WM8960_LINPATH, 8, 1, 0),
static const struct snd_kcontrol_new wm8960_lin[] = {
SOC_DAPM_SINGLE("Boost Switch", WM8960_LINPATH, 3, 1, 0),
static const struct snd_kcontrol_new wm8960_rin_boost[] = {
SOC_DAPM_SINGLE("RINPUT2 Switch", WM8960_RINPATH, 6, 1, 0),
SOC_DAPM_SINGLE("RINPUT3 Switch", WM8960_RINPATH, 7, 1, 0),
SOC_DAPM_SINGLE("RINPUT1 Switch", WM8960_RINPATH, 8, 1, 0),
static const struct snd_kcontrol_new wm8960_rin[] = {
SOC_DAPM_SINGLE("Boost Switch", WM8960_RINPATH, 3, 1, 0),
static const struct snd_kcontrol_new wm8960_loutput_mixer[] = {
SOC_DAPM_SINGLE("PCM Playback Switch", WM8960_LOUTMIX, 8, 1, 0),
SOC_DAPM_SINGLE("LINPUT3 Switch", WM8960_LOUTMIX, 7, 1, 0),
SOC_DAPM_SINGLE("Boost Bypass Switch", WM8960_BYPASS1, 7, 1, 0),
static const struct snd_kcontrol_new wm8960_routput_mixer[] = {
SOC_DAPM_SINGLE("PCM Playback Switch", WM8960_ROUTMIX, 8, 1, 0),
SOC_DAPM_SINGLE("RINPUT3 Switch", WM8960_ROUTMIX, 7, 1, 0),
SOC_DAPM_SINGLE("Boost Bypass Switch", WM8960_BYPASS2, 7, 1, 0),
static const struct snd_kcontrol_new wm8960_mono_out[] = {
SOC_DAPM_SINGLE("Left Switch", WM8960_MONOMIX1, 7, 1, 0),
SOC_DAPM_SINGLE("Right Switch", WM8960_MONOMIX2, 7, 1, 0),
static const struct snd_soc_dapm_widget wm8960_dapm_widgets[] = {
SND_SOC_DAPM_INPUT("LINPUT1"),
SND_SOC_DAPM_INPUT("RINPUT1"),
SND_SOC_DAPM_INPUT("LINPUT2"),
SND_SOC_DAPM_INPUT("RINPUT2"),
SND_SOC_DAPM_INPUT("LINPUT3"),
SND_SOC_DAPM_INPUT("RINPUT3"),
SND_SOC_DAPM_SUPPLY("MICB", WM8960_POWER1, 1, 0, NULL, 0),
SND_SOC_DAPM_MIXER("Left Boost Mixer", WM8960_POWER1, 5, 0,
           wm8960_lin_boost, ARRAY_SIZE(wm8960_lin_boost)),
SND_SOC_DAPM_MIXER("Right Boost Mixer", WM8960_POWER1, 4, 0,
           wm8960_rin_boost, ARRAY_SIZE(wm8960_rin_boost)),
SND_SOC_DAPM_MIXER("Left Input Mixer", WM8960_POWER3, 5, 0,
           wm8960_lin, ARRAY_SIZE(wm8960_lin)),
SND_SOC_DAPM_MIXER("Right Input Mixer", WM8960_POWER3, 4, 0,
           wm8960_rin, ARRAY_SIZE(wm8960_rin)),
SND_SOC_DAPM_ADC("Left ADC", "Capture", WM8960_POWER1, 3, 0),
SND_SOC_DAPM_ADC("Right ADC", "Capture", WM8960_POWER1, 2, 0),
SND_SOC_DAPM_DAC("Left DAC", "Playback", WM8960_POWER2, 8, 0),
SND_SOC_DAPM_DAC("Right DAC", "Playback", WM8960_POWER2, 7, 0),
SND_SOC_DAPM_MIXER("Left Output Mixer", WM8960_POWER3, 3, 0,
    &wm8960_loutput_mixer[0],
    ARRAY_SIZE(wm8960_loutput_mixer)),
SND_SOC_DAPM_MIXER("Right Output Mixer", WM8960_POWER3, 2, 0,
    &wm8960_routput_mixer[0],
    ARRAY_SIZE(wm8960_routput_mixer)),
SND_SOC_DAPM_PGA("LOUT1 PGA", WM8960_POWER2, 6, 0, NULL, 0),
SND_SOC_DAPM_PGA("ROUT1 PGA", WM8960_POWER2, 5, 0, NULL, 0),
SND_SOC_DAPM_PGA("Left Speaker PGA", WM8960_POWER2, 4, 0, NULL, 0),
SND_SOC_DAPM_PGA("Right Speaker PGA", WM8960_POWER2, 3, 0, NULL, 0),
SND_SOC_DAPM_PGA("Right Speaker Output", WM8960_CLASSD1, 7, 0, NULL, 0),
SND_SOC_DAPM_PGA("Left Speaker Output", WM8960_CLASSD1, 6, 0, NULL, 0),
SND_SOC_DAPM_OUTPUT("SPK_LP"),
SND_SOC_DAPM_OUTPUT("SPK_LN"),
SND_SOC_DAPM_OUTPUT("HP_L"),
SND_SOC_DAPM_OUTPUT("HP_R"),
SND_SOC_DAPM_OUTPUT("SPK_RP"),
SND_SOC_DAPM_OUTPUT("SPK_RN"),
SND_SOC_DAPM_OUTPUT("OUT3"),
static const struct snd_soc_dapm_widget wm8960_dapm_widgets_out3[] = {
SND_SOC_DAPM_MIXER("Mono Output Mixer", WM8960_POWER2, 1, 0,
    &wm8960_mono_out[0],
    ARRAY_SIZE(wm8960_mono_out)),
/* Represent OUT3 as a PGA so that it gets turned on with LOUT1/ROUT1 */
static const struct snd_soc_dapm_widget wm8960_dapm_widgets_capless[] = {
SND_SOC_DAPM_PGA("OUT3 VMID", WM8960_POWER2, 1, 0, NULL, 0),
static const struct snd_soc_dapm_route audio_paths[] = {
    { "Left Boost Mixer", "LINPUT1 Switch", "LINPUT1" },
    { "Left Boost Mixer", "LINPUT2 Switch", "LINPUT2" },
    { "Left Boost Mixer", "LINPUT3 Switch", "LINPUT3" },
    { "Left Input Mixer", "Boost Switch", "Left Boost Mixer", },
    { "Left Input Mixer", NULL, "LINPUT1", },  /* Really Boost Switch */
    { "Left Input Mixer", NULL, "LINPUT2" },
    { "Left Input Mixer", NULL, "LINPUT3" },
    { "Right Boost Mixer", "RINPUT1 Switch", "RINPUT1" },
    { "Right Boost Mixer", "RINPUT2 Switch", "RINPUT2" },
    { "Right Boost Mixer", "RINPUT3 Switch", "RINPUT3" },
    { "Right Input Mixer", "Boost Switch", "Right Boost Mixer", },
    { "Right Input Mixer", NULL, "RINPUT1", },  /* Really Boost Switch */
    { "Right Input Mixer", NULL, "RINPUT2" },
    { "Right Input Mixer", NULL, "RINPUT3" },
    { "Left ADC", NULL, "Left Input Mixer" },
    { "Right ADC", NULL, "Right Input Mixer" },
    { "Left Output Mixer", "LINPUT3 Switch", "LINPUT3" },
    { "Left Output Mixer", "Boost Bypass Switch", "Left Boost Mixer"} ,
    { "Left Output Mixer", "PCM Playback Switch", "Left DAC" },
    { "Right Output Mixer", "RINPUT3 Switch", "RINPUT3" },
    { "Right Output Mixer", "Boost Bypass Switch", "Right Boost Mixer" } ,
    { "Right Output Mixer", "PCM Playback Switch", "Right DAC" },
    { "LOUT1 PGA", NULL, "Left Output Mixer" },
    { "ROUT1 PGA", NULL, "Right Output Mixer" },
    { "HP_L", NULL, "LOUT1 PGA" },
    { "HP_R", NULL, "ROUT1 PGA" },
    { "Left Speaker PGA", NULL, "Left Output Mixer" },
    { "Right Speaker PGA", NULL, "Right Output Mixer" },
    { "Left Speaker Output", NULL, "Left Speaker PGA" },
    { "Right Speaker Output", NULL, "Right Speaker PGA" },
    { "SPK_LN", NULL, "Left Speaker Output" },
    { "SPK_LP", NULL, "Left Speaker Output" },
    { "SPK_RN", NULL, "Right Speaker Output" },
    { "SPK_RP", NULL, "Right Speaker Output" },
static const struct snd_soc_dapm_route audio_paths_out3[] = {
    { "Mono Output Mixer", "Left Switch", "Left Output Mixer" },
    { "Mono Output Mixer", "Right Switch", "Right Output Mixer" },
    { "OUT3", NULL, "Mono Output Mixer", }
static const struct snd_soc_dapm_route audio_paths_capless[] = {
    { "HP_L", NULL, "OUT3 VMID" },
    { "HP_R", NULL, "OUT3 VMID" },
    { "OUT3 VMID", NULL, "Left Output Mixer" },
    { "OUT3 VMID", NULL, "Right Output Mixer" },
static int wm8960_add_widgets(struct snd_soc_codec *codec)
    struct wm8960_data *pdata = codec->dev->platform_data;
    struct snd_soc_dapm_context *dapm = &codec->dapm;
    struct snd_soc_dapm_widget *w;
    snd_soc_dapm_new_controls(dapm, wm8960_dapm_widgets,
                  ARRAY_SIZE(wm8960_dapm_widgets));
    snd_soc_dapm_add_routes(dapm, audio_paths, ARRAY_SIZE(audio_paths));
    /* In capless mode OUT3 is used to provide VMID for the
     * headphone outputs, otherwise it is used as a mono mixer.
    if (pdata && pdata->capless) {
        snd_soc_dapm_new_controls(dapm, wm8960_dapm_widgets_capless,
                      ARRAY_SIZE(wm8960_dapm_widgets_capless));
        snd_soc_dapm_add_routes(dapm, audio_paths_capless,
                    ARRAY_SIZE(audio_paths_capless));
    } else {
        snd_soc_dapm_new_controls(dapm, wm8960_dapm_widgets_out3,
                      ARRAY_SIZE(wm8960_dapm_widgets_out3));
        snd_soc_dapm_add_routes(dapm, audio_paths_out3,
                    ARRAY_SIZE(audio_paths_out3));
    /* We need to power up the headphone output stage out of
     * sequence for capless mode.  To save scanning the widget
     * list each time to find the desired power state do so now
     * and save the result.
    list_for_each_entry(w, &codec->card->widgets, list) {
        if (w->dapm != &codec->dapm)
            continue;
        if (strcmp(w->name, "LOUT1 PGA") == 0)
            wm8960->lout1 = w;
        if (strcmp(w->name, "ROUT1 PGA") == 0)
            wm8960->rout1 = w;
        if (strcmp(w->name, "OUT3 VMID") == 0)
            wm8960->out3 = w;
    return 0;
static int wm8960_set_dai_fmt(struct snd_soc_dai *codec_dai,
        unsigned int fmt)
    struct snd_soc_codec *codec = codec_dai->codec;
    u16 iface = 0;
    /* set master/slave audio interface */
    switch (fmt & SND_SOC_DAIFMT_MASTER_MASK) {
    case SND_SOC_DAIFMT_CBM_CFM:
        iface |= 0x0040;
        break;
    case SND_SOC_DAIFMT_CBS_CFS:
        break;
    default:
        return -EINVAL;
    /* interface format */
    switch (fmt & SND_SOC_DAIFMT_FORMAT_MASK) {
    case SND_SOC_DAIFMT_I2S:
        iface |= 0x0002;
        break;
    case SND_SOC_DAIFMT_RIGHT_J:
        break;
    case SND_SOC_DAIFMT_LEFT_J:
        iface |= 0x0001;
        break;
    case SND_SOC_DAIFMT_DSP_A:
        iface |= 0x0003;
        break;
    case SND_SOC_DAIFMT_DSP_B:
        iface |= 0x0013;
        break;
    default:
        return -EINVAL;
    /* clock inversion */
    switch (fmt & SND_SOC_DAIFMT_INV_MASK) {
    case SND_SOC_DAIFMT_NB_NF:
        break;
    case SND_SOC_DAIFMT_IB_IF:
        iface |= 0x0090;
        break;
    case SND_SOC_DAIFMT_IB_NF:
        iface |= 0x0080;
        break;
    case SND_SOC_DAIFMT_NB_IF:
        iface |= 0x0010;
        break;
    default:
        return -EINVAL;
    /* set iface */
    snd_soc_write(codec, WM8960_IFACE1, iface);
    return 0;
static struct {
    int rate;
    unsigned int val;
} alc_rates[] = {
    { 48000, 0 },
    { 44100, 0 },
    { 32000, 1 },
    { 22050, 2 },
    { 24000, 2 },
    { 16000, 3 },
    { 11025, 4 },
    { 12000, 4 },
    {  8000, 5 },
static int wm8960_hw_params(struct snd_pcm_substream *substream,
                struct snd_pcm_hw_params *params,
                struct snd_soc_dai *dai)
    struct snd_soc_codec *codec = dai->codec;
    u16 iface = snd_soc_read(codec, WM8960_IFACE1) & 0xfff3;
    snd_pcm_format_t format = params_format(params);
    int i;
    /* bit size */
    switch (format) {
    case SNDRV_PCM_FORMAT_S16_LE:
    case SNDRV_PCM_FORMAT_S16_BE:
        break;
    case SNDRV_PCM_FORMAT_S20_3LE:
    case SNDRV_PCM_FORMAT_S20_3BE:
        iface |= 0x0004;
        break;
    case SNDRV_PCM_FORMAT_S24_LE:
    case SNDRV_PCM_FORMAT_S24_BE:
        iface |= 0x0008;
        break;
    default:
        dev_err(codec->dev, "unsupported format %i\n", format);
        return -EINVAL;
    /* Update filters for the new rate */
    if (substream->stream == SNDRV_PCM_STREAM_PLAYBACK) {
        wm8960->playback_fs = params_rate(params);
    } else {
        for (i = 0; i < ARRAY_SIZE(alc_rates); i++)
            if (alc_rates[i].rate == params_rate(params))
                            WM8960_ADDCTL3, 0x7,
                            alc_rates[i].val);
    /* set iface */
    return 0;
static int wm8960_mute(struct snd_soc_dai *dai, int mute)
    if (mute)
        snd_soc_update_bits(codec, WM8960_DACCTL1, 0x8, 0x8);
    else
        snd_soc_update_bits(codec, WM8960_DACCTL1, 0x8, 0);
    return 0;
static int wm8960_set_bias_level_out3(struct snd_soc_codec *codec,
    switch (level) {
    case SND_SOC_BIAS_ON:
        break;
    case SND_SOC_BIAS_PREPARE:
        /* Set VMID to 2x50k */
        snd_soc_update_bits(codec, WM8960_POWER1, 0x180, 0x80);
        break;
    case SND_SOC_BIAS_STANDBY:
        if (codec->dapm.bias_level == SND_SOC_BIAS_OFF) {
            regcache_sync(wm8960->regmap);
            /* Enable anti-pop features */
            snd_soc_write(codec, WM8960_APOP1,
                      WM8960_POBCTRL | WM8960_SOFT_ST |
                      WM8960_BUFDCOPEN | WM8960_BUFIOEN);
            /* Enable & ramp VMID at 2x50k */
            snd_soc_update_bits(codec, WM8960_POWER1, 0x80, 0x80);
            msleep(100);
            /* Enable VREF */
            snd_soc_update_bits(codec, WM8960_POWER1, WM8960_VREF,
                        WM8960_VREF);
            /* Disable anti-pop features */
            snd_soc_write(codec, WM8960_APOP1, WM8960_BUFIOEN);
        /* Set VMID to 2x250k */
        snd_soc_update_bits(codec, WM8960_POWER1, 0x180, 0x100);
        break;
    case SND_SOC_BIAS_OFF:
        /* Disable VMID and VREF, let them discharge */
        snd_soc_write(codec, WM8960_POWER1, 0);
        msleep(600);
        break;
    codec->dapm.bias_level = level;
    return 0;
static int wm8960_set_bias_level_capless(struct snd_soc_codec *codec,
    int reg;
    switch (level) {
        break;
        switch (codec->dapm.bias_level) {
            /* Enable anti pop mode */
            snd_soc_update_bits(codec, WM8960_APOP1,
                        WM8960_BUFDCOPEN,
                        WM8960_BUFDCOPEN);
            /* Enable LOUT1, ROUT1 and OUT3 if they're enabled */
            reg = 0;
            if (wm8960->lout1 && wm8960->lout1->power)
                reg |= WM8960_PWR2_LOUT1;
            if (wm8960->rout1 && wm8960->rout1->power)
                reg |= WM8960_PWR2_ROUT1;
            if (wm8960->out3 && wm8960->out3->power)
                reg |= WM8960_PWR2_OUT3;
            snd_soc_update_bits(codec, WM8960_POWER2,
                        WM8960_PWR2_LOUT1 |
                        WM8960_PWR2_ROUT1 |
                        WM8960_PWR2_OUT3, reg);
            /* Enable VMID at 2*50k */
                        WM8960_VMID_MASK, 0x80);
            /* Ramp */
            msleep(100);
            /* Enable VREF */
                        WM8960_VREF, WM8960_VREF);
            msleep(100);
            break;
            /* Enable anti-pop mode */
                        WM8960_BUFDCOPEN,
                        WM8960_BUFDCOPEN);
            /* Disable VMID and VREF */
                        WM8960_VREF | WM8960_VMID_MASK, 0);
            break;
            break;
        default:
            break;
        break;
            /* Disable HP discharge */
            snd_soc_update_bits(codec, WM8960_APOP2,
                        WM8960_DISOP | WM8960_DRES_MASK,
                        0);
                        WM8960_BUFDCOPEN,
                        WM8960_BUFDCOPEN);
            break;
        default:
            break;
        break;
        break;
    return 0;
/* PLL divisors */
struct _pll_div {
    u32 pre_div:1;
    u32 n:4;
    u32 k:24;
/* The size in bits of the pll divide multiplied by 10
* to allow rounding later */
#define FIXED_PLL_SIZE ((1 << 24) * 10)
static int pll_factors(unsigned int source, unsigned int target,
               struct _pll_div *pll_div)
    unsigned long long Kpart;
    unsigned int K, Ndiv, Nmod;
    pr_debug("WM8960 PLL: setting %dHz->%dHz\n", source, target);
    /* Scale up target to PLL operating frequency */
    target *= 4;
    Ndiv = target / source;
    if (Ndiv < 6) {
        source >>= 1;
        pll_div->pre_div = 1;
    } else
        pll_div->pre_div = 0;
    if ((Ndiv < 6) || (Ndiv > 12)) {
        pr_err("WM8960 PLL: Unsupported N=%d\n", Ndiv);
        return -EINVAL;
    pll_div->n = Ndiv;
    Nmod = target % source;
    Kpart = FIXED_PLL_SIZE * (long long)Nmod;
    do_div(Kpart, source);
    K = Kpart & 0xFFFFFFFF;
    /* Check if we need to round */
    if ((K % 10) >= 5)
        K += 5;
    /* Move down to proper range now rounding is done */
    K /= 10;
    pll_div->k = K;
    pr_debug("WM8960 PLL: N=%x K=%x pre_div=%d\n",
         pll_div->n, pll_div->k, pll_div->pre_div);
    return 0;
static int wm8960_set_dai_pll(struct snd_soc_dai *codec_dai, int pll_id,
        int source, unsigned int freq_in, unsigned int freq_out)
    u16 reg;
    static struct _pll_div pll_div;
    int ret;
    if (freq_in && freq_out) {
        ret = pll_factors(freq_in, freq_out, &pll_div);
        if (ret != 0)
            return ret;
    /* Disable the PLL: even if we are changing the frequency the
     * PLL needs to be disabled while we do so. */
    snd_soc_update_bits(codec, WM8960_CLOCK1, 0x1, 0);
    snd_soc_update_bits(codec, WM8960_POWER2, 0x1, 0);
    if (!freq_in || !freq_out)
        return 0;
    reg = snd_soc_read(codec, WM8960_PLL1) & ~0x3f;
    reg |= pll_div.pre_div << 4;
    reg |= pll_div.n;
    if (pll_div.k) {
        reg |= 0x20;
        snd_soc_write(codec, WM8960_PLL2, (pll_div.k >> 16) & 0xff);
        snd_soc_write(codec, WM8960_PLL3, (pll_div.k >> 8) & 0xff);
        snd_soc_write(codec, WM8960_PLL4, pll_div.k & 0xff);
    snd_soc_write(codec, WM8960_PLL1, reg);
    /* Turn it on */
    snd_soc_update_bits(codec, WM8960_POWER2, 0x1, 0x1);
    msleep(250);
    snd_soc_update_bits(codec, WM8960_CLOCK1, 0x1, 0x1);
    return 0;
static int wm8960_set_dai_clkdiv(struct snd_soc_dai *codec_dai,
        int div_id, int div)
    u16 reg;
    switch (div_id) {
    case WM8960_SYSCLKDIV:
        reg = snd_soc_read(codec, WM8960_CLOCK1) & 0x1f9;
        snd_soc_write(codec, WM8960_CLOCK1, reg | div);
        break;
    case WM8960_DACDIV:
        reg = snd_soc_read(codec, WM8960_CLOCK1) & 0x1c7;
        break;
    case WM8960_OPCLKDIV:
        reg = snd_soc_read(codec, WM8960_PLL1) & 0x03f;
        snd_soc_write(codec, WM8960_PLL1, reg | div);
        break;
    case WM8960_DCLKDIV:
        reg = snd_soc_read(codec, WM8960_CLOCK2) & 0x03f;
        snd_soc_write(codec, WM8960_CLOCK2, reg | div);
        break;
    case WM8960_TOCLKSEL:
        reg = snd_soc_read(codec, WM8960_ADDCTL1) & 0x1fd;
        snd_soc_write(codec, WM8960_ADDCTL1, reg | div);
        break;
    default:
        return -EINVAL;
    return 0;
static int wm8960_set_bias_level(struct snd_soc_codec *codec,
    return wm8960->set_bias_level(codec, level);
#define WM8960_RATES SNDRV_PCM_RATE_8000_48000
#define WM8960_FORMATS \
    (SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S20_3LE | \
    SNDRV_PCM_FMTBIT_S24_LE)
static const struct snd_soc_dai_ops wm8960_dai_ops = {
    .hw_params = wm8960_hw_params,
    .digital_mute = wm8960_mute,
    .set_fmt = wm8960_set_dai_fmt,
    .set_clkdiv = wm8960_set_dai_clkdiv,
    .set_pll = wm8960_set_dai_pll,
static struct snd_soc_dai_driver wm8960_dai = {
    .name = "wm8960-hifi",
    .playback = {
        .stream_name = "Playback",
        .channels_min = 1,
        .channels_max = 2,
        .rates = WM8960_RATES,
        .formats = WM8960_FORMATS,},
    .capture = {
        .stream_name = "Capture",
        .channels_min = 1,
        .channels_max = 2,
    .ops = &wm8960_dai_ops,
    .symmetric_rates = 1,
static int wm8960_suspend(struct snd_soc_codec *codec)
    wm8960->set_bias_level(codec, SND_SOC_BIAS_OFF);
    return 0;
static int wm8960_resume(struct snd_soc_codec *codec)
    wm8960->set_bias_level(codec, SND_SOC_BIAS_STANDBY);
    return 0;
static int wm8960_probe(struct snd_soc_codec *codec)
    struct wm8960_data *pdata = dev_get_platdata(codec->dev);
    int ret;
    wm8960->set_bias_level = wm8960_set_bias_level_out3;
    if (!pdata) {
        dev_warn(codec->dev, "No platform data supplied\n");
    } else {
        if (pdata->capless)
            wm8960->set_bias_level = wm8960_set_bias_level_capless;
    ret = snd_soc_codec_set_cache_io(codec, 7, 9, SND_SOC_REGMAP);
    if (ret < 0) {
        dev_err(codec->dev, "Failed to set cache I/O: %d\n", ret);
        return ret;
    ret = wm8960_reset(codec);
    if (ret < 0) {
        dev_err(codec->dev, "Failed to issue reset\n");
        return ret;
    /* Latch the update bits */
    snd_soc_update_bits(codec, WM8960_LINVOL, 0x100, 0x100);
    snd_soc_update_bits(codec, WM8960_RINVOL, 0x100, 0x100);
    snd_soc_update_bits(codec, WM8960_LADC, 0x100, 0x100);
    snd_soc_update_bits(codec, WM8960_RADC, 0x100, 0x100);
    snd_soc_update_bits(codec, WM8960_LDAC, 0x100, 0x100);
    snd_soc_update_bits(codec, WM8960_RDAC, 0x100, 0x100);
    snd_soc_update_bits(codec, WM8960_LOUT1, 0x100, 0x100);
    snd_soc_update_bits(codec, WM8960_ROUT1, 0x100, 0x100);
    snd_soc_update_bits(codec, WM8960_LOUT2, 0x100, 0x100);
    snd_soc_update_bits(codec, WM8960_ROUT2, 0x100, 0x100);
    snd_soc_add_codec_controls(codec, wm8960_snd_controls,
                     ARRAY_SIZE(wm8960_snd_controls));
    wm8960_add_widgets(codec);
    return 0;
/* power down chip */
static int wm8960_remove(struct snd_soc_codec *codec)
    return 0;
static struct snd_soc_codec_driver soc_codec_dev_wm8960 = {
    .probe =    wm8960_probe,
    .remove =    wm8960_remove,
    .suspend =    wm8960_suspend,
    .resume =    wm8960_resume,
    .set_bias_level = wm8960_set_bias_level,
static const struct regmap_config wm8960_regmap = {
    .reg_bits = 7,
    .val_bits = 9,
    .max_register = WM8960_PLL4,
    .reg_defaults = wm8960_reg_defaults,
    .num_reg_defaults = ARRAY_SIZE(wm8960_reg_defaults),
    .cache_type = REGCACHE_RBTREE,
    .volatile_reg = wm8960_volatile,
static int wm8960_i2c_probe(struct i2c_client *i2c,
                const struct i2c_device_id *id)
    struct wm8960_data *pdata = dev_get_platdata(&i2c->dev);
    struct wm8960_priv *wm8960;
    int ret;
    wm8960 = devm_kzalloc(&i2c->dev, sizeof(struct wm8960_priv),
                  GFP_KERNEL);
    if (wm8960 == NULL)
        return -ENOMEM;
    wm8960->regmap = devm_regmap_init_i2c(i2c, &wm8960_regmap);
    if (IS_ERR(wm8960->regmap))
        return PTR_ERR(wm8960->regmap);
    if (pdata && pdata->shared_lrclk) {
        ret = regmap_update_bits(wm8960->regmap, WM8960_ADDCTL2,
                     0x4, 0x4);
        if (ret != 0) {
            dev_err(&i2c->dev, "Failed to enable LRCM: %d\n",
                ret);
            return ret;
    i2c_set_clientdata(i2c, wm8960);
    ret = snd_soc_register_codec(&i2c->dev,
            &soc_codec_dev_wm8960, &wm8960_dai, 1);
    return ret;
static int wm8960_i2c_remove(struct i2c_client *client)
    snd_soc_unregister_codec(&client->dev);
    return 0;
static const struct i2c_device_id wm8960_i2c_id[] = {
    { "wm8960", 0 },
MODULE_DEVICE_TABLE(i2c, wm8960_i2c_id);
static struct i2c_driver wm8960_i2c_driver = {
    .driver = {
        .name = "wm8960",
        .owner = THIS_MODULE,
    .probe =    wm8960_i2c_probe,
    .remove =   wm8960_i2c_remove,
    .id_table = wm8960_i2c_id,
module_i2c_driver(wm8960_i2c_driver);
MODULE_DESCRIPTION("ASoC WM8960 driver");
MODULE_AUTHOR("Liam Girdwood");
MODULE_LICENSE("GPL");
Can you help me to compile the dts file properly or in i2s device setting, please?
Thanks in advance Wink
RE: Enabling wolfson wm8960 i2c/i2s sound codec - by saro - 06-01-2017, 03:04 AM
  sound amp and speakers for the case Israeldelamo 4 7,188 12-29-2019, 08:38 AM
Last Post: Little_Johnny
  Sound quality from audio jack devanl 0 3,320 10-11-2017, 10:39 PM
Last Post: devanl
