How to add support to strongSwan IPsec
(05-17-2017, 10:46 PM)MarkHaysHarris777 Wrote:
(05-17-2017, 08:12 PM)kingsing2 Wrote: So, how to insert these modules or should I recompile the kernel from the beginning.
First, to answer the question you didn't ask;  Yes, you can use VPN without using strongswan.
...  you may need the IPsec-based VPN solution;  but I would try to avoid it.   On the other hand, if you need the modules you listed then you will have to compile them in;  good thing strongswan is open source.
I tried ppp VPN before, but failed. I figure that the ppp ports are screened by the ISP. I have not tried L2TP. I think most L2TP are based on IPsec, so they also need these modules.
How should I compile the module for PINE64? Is there any guide?
Besides, should the modules complied from kernel source or strongswan source?
RE: How to add support to strongSwan IPsec - by kingsing2 - 05-18-2017, 12:36 AM
  Ubuntu Xenial - Firefox add support for H264 and EAC3 klode 1 4,803 05-26-2017, 11:10 AM
Last Post: Gnx
  GPU support? adamw 15 19,404 05-27-2016, 04:08 PM
Last Post: adamw
