HDMI "Format not supported"
(05-11-2017, 09:10 AM)MarkHaysHarris777 Wrote:
(05-11-2017, 03:45 AM)sam452 Wrote: Loaded up the Longsleep Ubuntu on my working 2gb Pine. But on a working HDMI I'm getting "Format not supported." I didn't find anything in the Wiki or this forum.
What should I try to get HDMI working?, sam
The problem is that only a very few (two) mode lines are supported;  this really comes down to having the right monitor.   720p60  or  1080p60
You may also be able to use a 1366x768  Samsung  (vga | dvi) by using the hdmi-->vga adapter from the pine store (active interface) ;   I have one of these setups working .   My other two setups both use a modern  1920x1080p60  LG  LED monitor ;  I also have a Samsung  1920x1080p60 monitor that works very  well.
If you have an older monitor you're going to have trouble.
Hi, I'd like to use Pine with my TV that has just the resolution you mentioned (Samsung LE26R32B - WXGA 1366 x 768 Pixel). The TV has VGA connector marked PC and also Jack hole next to it (together they are PC - IN group). So I would use this HDMI->VGA adapter from store, use jack-jack cable to connect Pine audio out to TV audio in and everything should work well?
I'd be really glad to get this working since I already tried out Remix OS with Kodi on my FullHD monitor and I was quite pleased. However, connecting to the TV I currently get "Unsupported mode" error.
HDMI "Format not supported" - by sam452 - 05-11-2017, 03:45 AM
RE: HDMI "Format not supported" - by Beta_Ravener - 06-11-2017, 10:38 AM
RE: HDMI "Format not supported" - by sam452 - 05-11-2017, 03:29 PM
  A list of supported OSes would be helpful blicken 2 4,979 01-06-2020, 04:20 PM
Last Post: bcnaz
  Pine HDMI -> DVI monitor Pineapple 4 7,824 09-10-2019, 11:28 AM
Last Post: Pineapple
  First Boot HDMI/USB problem reefer 1 5,024 11-18-2018, 10:32 PM
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 8,216 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  What is the format that one should use for imaging SD cards on APINE64+2GB Board? Doryan 1 3,542 03-05-2018, 08:11 PM
  RESOLVED - LCD screen not working, HDMI does asuras 10 16,015 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI and LCD hienhuynh1982 19 25,270 03-23-2017, 10:16 PM
  HDMI-VGA adapter. Blank screen. trumad 10 17,954 03-05-2017, 03:17 AM
Last Post: pfeerick
  no sound over HDMI mbjpine64 2 4,595 10-09-2016, 01:45 PM
Last Post: dicenicheserr
Question No Audio other than HDMI jwouellette 8 9,254 08-03-2016, 03:08 PM
Last Post: jwouellette
