Pine A64 Plus Fails to Boot
(04-10-2017, 07:42 PM)TinkerBear Wrote: I sorta had my doubts that it could be the power supply, so I sat down to do some rigourous testing - three different power supplies to try, recording fluctuations on the power input (DC in and 5V lines) via Euler header and a DSO (Siglent SDS1052DL).
Wait - ONE MORE THING TO TRY - move that 10µF cap to the DC IN pin of the Euler connector...  And I'm booted and running off the PQI supply.  But not the 5V3A chinese supply.  Let's try that again.  Yep, works on 2nd try.  Hmmm, maybe bigger capacitor.
Yeah, me also, since I have a 8000mah lipo strapped to the underneath of the pine64, so it ain't gonna gonna get any ripple in the supply that way. It all seems rather strange... as this particular unit (which does have a WiFi module installed, but no ethernet) had been pretty stable prior to now, and then started having issues on reboots. However, I tell a lie (unless I had a different SD card inserted at the time - which is possible... I often swap that one between vanilla ubuntu and Armbian ubuntu depending on what it is being used for... it's a mobile test rig) it is currently on "ARMBIAN 5.25 stable Ubuntu 16.04.2 LTS 3.10.104-pine64", so if it was this image that was having issues, it is not 105 kernel related. However, I'm pretty sure it exhibiting reboot roulette (i.e. have to keep rebooting it until it decides to work) until I plugged the HDMI in, but that could be something going on with the WiFi driver from what longsleep was saying.
If I didn't have a battery connected I would probably also try 1nf, 100µF (and a 1F supercap :-P) on the euler pins just to make sure things are smoothed out, but in my case it has a battery connected... so already has a bit one Wink Or the PMIC just isn't doing it's job.
Pine A64 Plus Fails to Boot - by grobbs - 03-27-2017, 01:04 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 03-27-2017, 07:52 PM
RE: Pine A64 Plus Fails to Boot - by xalius - 03-28-2017, 05:14 AM
RE: Pine A64 Plus Fails to Boot - by grobbs - 03-28-2017, 01:50 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-08-2017, 11:21 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-09-2017, 02:08 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-09-2017, 03:18 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-09-2017, 05:16 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-09-2017, 07:17 PM
RE: Pine A64 Plus Fails to Boot - by Luke - 04-10-2017, 05:31 AM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-10-2017, 07:42 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-10-2017, 08:56 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-10-2017, 09:18 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-11-2017, 06:34 PM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-13-2017, 02:36 AM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-16-2017, 03:02 AM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-10-2017, 10:59 PM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-11-2017, 05:28 AM
RE: Pine A64 Plus Fails to Boot - by dkryder - 04-11-2017, 05:22 AM
RE: Pine A64 Plus Fails to Boot - by xalius - 04-11-2017, 05:37 AM
RE: Pine A64 Plus Fails to Boot - by dkryder - 04-11-2017, 03:17 PM
RE: Pine A64 Plus Fails to Boot - by Luke - 04-11-2017, 04:32 PM
RE: Pine A64 Plus Fails to Boot - by tommypine - 04-12-2017, 04:47 AM
RE: Pine A64 Plus Fails to Boot - by tommypine - 04-13-2017, 02:56 AM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-13-2017, 05:07 AM
RE: Pine A64 Plus Fails to Boot - by tommypine - 04-13-2017, 10:18 AM
RE: Pine A64 Plus Fails to Boot - by TinkerBear - 04-17-2017, 12:52 AM
RE: Pine A64 Plus Fails to Boot - by tommypine - 04-17-2017, 02:45 AM
RE: Pine A64 Plus Fails to Boot - by pfeerick - 04-17-2017, 06:06 PM
  Pine A64+ mainline mipi-dsi Learnincurve 3 6,612 01-12-2021, 07:36 AM
Last Post: Learnincurve
  DietPi OS for PINE A64 MichaIng 0 9,201 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 5,507 10-02-2020, 11:38 AM
Last Post: mathiraj
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 15,764 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 19,454 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 6,647 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 6,088 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 5,151 05-09-2019, 05:42 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,313 03-30-2019, 06:48 AM
Last Post: ktaragorn
  motionEyeOS (PINE A64(+)) pineadmin 4 11,994 11-09-2018, 03:25 AM
