Cases and Enclosure Question
(12-13-2015, 11:14 PM)jj@pine64 Wrote: A lot of you have asked regarding cases and enclosure information.
a series of 2-3 case designs will be available in January for free download of the STL design files if you choose to print it yourself.
however, cases will be available purchase as well after the Kickstarter end.
You'll be able to add it on when we send the final survey.
Thanks.
22Dec2015
Johnson,
It would be useful to have a bit more information about the Pine A64+ board dimensions.
In addition to the basic board outline dimensions (see http://wiki.pine64.org/images/7/74/Pine6...ension.JPG),
it would be useful to know something more about the mounting hole specifications. For example,
• MH-center-to-MH-center dimension (horizontal and vertical)
• board-edge-to-MH-center dimension (horizontal and vertical)
• mounting hole diameter (what size bolts)
• mounting hole keepout diameter (what size nuts and standoffs)
• mounting hole solder mask diameter
It looks like the mounting holes are plated-through-holes. There is an argument to be made for non-PTH mounting holes so that (1) threaded mounting hardware doesn't tear the PTH leaving little metal bits to short out the board and (2) relying on mounting PTH for grounding often leads to flaky behavior if the mounting hardware tears up the PTH. My preference would be for a non-PTH mounting hole, keepout applied to all layers (including internal ground plane), solder mask up to the mounting hole, and marking the keepout boundary on the silkscreen layer.
dsm
Cases and Enclosure Question - by jj@pine64 - 12-13-2015, 11:14 PM
RE: Cases and Enclosure Question - by Danielhout - 12-14-2015, 09:38 PM
RE: Cases and Enclosure Question - by jj@pine64 - 12-15-2015, 12:03 AM
RE: Cases and Enclosure Question - by ML-Anderal - 12-20-2015, 03:39 PM
RE: Cases and Enclosure Question - by PineTree - 12-15-2015, 12:26 PM
RE: Cases and Enclosure Question - by dsm - 12-22-2015, 04:15 AM
RE: Cases and Enclosure Question - by blkadder - 12-29-2015, 05:04 PM
RE: Cases and Enclosure Question - by Opine - 12-29-2015, 06:08 PM
RE: Cases and Enclosure Question - by killor - 01-12-2016, 10:05 AM
RE: Cases and Enclosure Question - by tllim - 01-12-2016, 10:45 AM
RE: Cases and Enclosure Question - by killor - 01-13-2016, 06:02 AM
RE: Cases and Enclosure Question - by killor - 02-03-2016, 06:28 AM
RE: Cases and Enclosure Question - by scprosser - 01-17-2016, 02:12 PM
RE: Cases and Enclosure Question - by tllim - 01-17-2016, 04:20 PM
RE: Cases and Enclosure Question - by scprosser - 01-17-2016, 04:31 PM
RE: Cases and Enclosure Question - by scprosser - 01-25-2016, 11:46 PM
RE: Cases and Enclosure Question - by By-Jokese - 01-23-2016, 04:54 AM
RE: Cases and Enclosure Question - by killor - 01-23-2016, 06:57 AM
RE: Cases and Enclosure Question - by brf - 01-23-2016, 10:57 AM
RE: Cases and Enclosure Question - by By-Jokese - 01-23-2016, 11:05 AM
RE: Cases and Enclosure Question - by tllim - 01-23-2016, 01:08 PM
RE: Cases and Enclosure Question - by brf - 01-23-2016, 04:40 PM
RE: Cases and Enclosure Question - by tllim - 01-23-2016, 05:46 PM
RE: Cases and Enclosure Question - by brf - 01-26-2016, 04:25 PM
RE: Cases and Enclosure Question - by killor - 01-25-2016, 05:54 AM
RE: Cases and Enclosure Question - by tllim - 01-25-2016, 10:10 AM
RE: Cases and Enclosure Question - by killor - 01-26-2016, 04:50 AM
RE: Cases and Enclosure Question - by Nilocsemliw - 01-25-2016, 02:33 PM
RE: Cases and Enclosure Question - by Ghost - 01-26-2016, 09:03 AM
RE: Cases and Enclosure Question - by chrwei - 01-26-2016, 12:43 PM
RE: Cases and Enclosure Question - by killor - 01-27-2016, 05:23 AM
RE: Cases and Enclosure Question - by ViperVi - 02-03-2016, 09:33 AM
RE: Cases and Enclosure Question - by killor - 02-04-2016, 09:28 AM
RE: Cases and Enclosure Question - by Nilocsemliw - 02-03-2016, 12:28 PM
RE: Cases and Enclosure Question - by ViperVi - 02-04-2016, 12:53 PM
RE: Cases and Enclosure Question - by killor - 02-05-2016, 04:31 AM
RE: Cases and Enclosure Question - by ViperVi - 02-05-2016, 02:37 PM
RE: Cases and Enclosure Question - by tllim - 02-05-2016, 07:26 PM
RE: Cases and Enclosure Question - by killor - 02-06-2016, 05:25 AM
RE: Cases and Enclosure Question - by frustrated1 - 02-17-2016, 02:49 AM
RE: Cases and Enclosure Question - by Ghost - 02-17-2016, 04:27 AM
RE: Cases and Enclosure Question - by killor - 02-17-2016, 04:40 AM
RE: Cases and Enclosure Question - by brf - 02-12-2016, 01:58 PM
RE: Cases and Enclosure Question - by scprosser - 02-16-2016, 04:28 PM
RE: Cases and Enclosure Question - by brf - 02-16-2016, 09:03 PM
RE: Cases and Enclosure Question - by scprosser - 03-11-2016, 07:28 AM
RE: Cases and Enclosure Question - by frustrated1 - 02-17-2016, 05:10 AM
RE: Cases and Enclosure Question - by Ghost - 02-27-2016, 06:37 PM
RE: Cases and Enclosure Question - by Artyom - 03-02-2016, 04:16 AM
RE: Cases and Enclosure Question - by Tarjei85 - 03-12-2016, 03:36 AM
RE: Cases and Enclosure Question - by Artyom - 03-13-2016, 12:16 AM
RE: Cases and Enclosure Question - by tllim - 03-13-2016, 12:35 AM
RE: Cases and Enclosure Question - by Artyom - 03-17-2016, 02:52 AM
RE: Cases and Enclosure Question - by npull - 03-18-2016, 07:56 AM
RE: Cases and Enclosure Question - by SirLenuxx - 04-01-2016, 03:30 PM
RE: Cases and Enclosure Question - by kyllikki - 04-02-2016, 05:56 PM
RE: Cases and Enclosure Question - by Tarjei85 - 04-03-2016, 04:18 AM
RE: Cases and Enclosure Question - by tllim - 04-03-2016, 02:12 PM
RE: Cases and Enclosure Question - by kyllikki - 04-03-2016, 02:29 PM
RE: Cases and Enclosure Question - by tllim - 04-03-2016, 02:34 PM
RE: Cases and Enclosure Question - by User 563 - 04-09-2016, 01:11 PM
RE: Cases and Enclosure Question - by SirLenuxx - 04-03-2016, 09:46 AM
Photo C4 Labs Pine 64 Cases (Standard & LCD) Bluphire 95 166,034 11-02-2020, 08:43 PM
Last Post: Little_Johnny
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 20,093 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 34,394 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,534 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 7,597 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,753 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 13,127 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 25,167 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 20,188 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 19,163 11-01-2016, 06:23 PM
