Usually you set CROSS_COMPILE=/path/to/toolchain/<prefix> make xyz
For example to cross compile a kernel... if you use autotools and ./configure script there are also more options you can set like --target= or --toolchain=, but that depends on the source
CROSS_COMPILE=/opt/gcc-linaro-6.3.1-2017.02-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- ARCH=arm64 make -j9 Image
Come have a chat in the Pine IRC channel >>
