Pine 64 benchmarks
(03-07-2016, 01:34 PM)janjwerner Wrote: Sad constants reminders of my sloppiness. updated the orignal post. sorry guys...
Thx, cpufreq not exceeding 1008MHz through the whole test and most of the times even lower (816 MHz minimum). With your current cooling capabilities the A64 can be considered to be clocked with approx. 950MHz. By adding a fan you can improve your benchmark scores by factor 1.2 (when thinking about 1152 MHz max).
If @tllim adopts our ideas regarding power through Euler connector, a perfect heatsink and a fan solution that doesn't suck after an extensive set of tests the Pine64 might also be overclocked up to 1200 MHz, 1248, 1296 or even 1344 MHz (most probably not without tweaking the dvfs settings, increasing VDD_CPUX voltage and therefore massively the need for heat dissipation) benchmark results will improve by factor 1.25 or even 1.4 (at 1344 MHz).
(using appropriate compiler switches and code optimizations might even work better Wink )
Pine 64 benchmarks - by patrickhwood - 03-02-2016, 12:11 AM
RE: Pine 64 benchmarks - by nomadewolf - 03-05-2016, 02:04 PM
RE: Pine 64 benchmarks - by patrickhwood - 03-05-2016, 03:10 PM
RE: Pine 64 benchmarks - by janjwerner - 03-06-2016, 11:16 AM
RE: Pine 64 benchmarks - by tllim - 03-06-2016, 11:30 AM
RE: Pine 64 benchmarks - by patrickhwood - 03-06-2016, 11:54 AM
RE: Pine 64 benchmarks - by janjwerner - 03-06-2016, 12:05 PM
RE: Pine 64 benchmarks - by janjwerner - 03-06-2016, 01:41 PM
RE: Pine 64 benchmarks - by longsleep - 03-06-2016, 03:06 PM
RE: Pine 64 benchmarks - by janjwerner - 03-06-2016, 08:04 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-07-2016, 11:30 AM
RE: Pine 64 benchmarks - by longsleep - 03-07-2016, 12:49 AM
RE: Pine 64 benchmarks - by janjwerner - 03-07-2016, 07:54 AM
RE: Pine 64 benchmarks - by longsleep - 03-07-2016, 12:43 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-07-2016, 12:59 PM
RE: Pine 64 benchmarks - by janjwerner - 03-07-2016, 01:34 PM
RE: Pine 64 benchmarks - by longsleep - 03-07-2016, 01:40 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-07-2016, 02:03 PM
RE: Pine 64 benchmarks - by janjwerner - 03-08-2016, 12:07 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 12:34 AM
RE: Pine 64 benchmarks - by longsleep - 03-08-2016, 01:09 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 04:04 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 06:39 AM
RE: Pine 64 benchmarks - by janjwerner - 03-08-2016, 06:59 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 07:10 AM
RE: Pine 64 benchmarks - by janjwerner - 03-08-2016, 09:42 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 10:14 AM
RE: Pine 64 benchmarks - by janjwerner - 03-08-2016, 10:34 AM
Pine 64 benchmarks - by Andrew2 - 03-08-2016, 11:16 AM
RE: Pine 64 benchmarks - by longsleep - 03-08-2016, 12:31 PM
RE: Pine 64 benchmarks - by Artyom - 03-09-2016, 02:03 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-09-2016, 03:53 AM
RE: Pine 64 benchmarks - by ssvb - 03-09-2016, 11:30 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-09-2016, 12:12 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-10-2016, 04:45 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-10-2016, 10:03 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-10-2016, 01:42 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-11-2016, 05:03 AM
RE: Pine 64 benchmarks - by norm24 - 03-11-2016, 05:39 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-11-2016, 09:59 AM
RE: Pine 64 benchmarks - by xtcrefugee - 03-11-2016, 11:35 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-11-2016, 01:03 PM
RE: Pine 64 benchmarks - by tllim - 03-11-2016, 04:56 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-12-2016, 01:08 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-11-2016, 11:55 AM
RE: Pine 64 benchmarks - by Artyom - 03-12-2016, 03:06 AM
RE: Pine 64 benchmarks - by g_t_j - 03-15-2016, 02:28 PM
RE: Pine 64 benchmarks - by tllim - 03-15-2016, 04:19 PM
RE: Pine 64 benchmarks - by g_t_j - 03-15-2016, 04:43 PM
RE: Pine 64 benchmarks - by janjwerner - 03-15-2016, 08:41 PM
RE: Pine 64 benchmarks - by g_t_j - 03-16-2016, 06:11 AM
RE: Pine 64 benchmarks - by janjwerner - 03-15-2016, 04:46 PM
RE: Pine 64 benchmarks - by g_t_j - 03-15-2016, 05:00 PM
RE: Pine 64 benchmarks - by tllim - 03-15-2016, 07:52 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-16-2016, 01:56 AM
RE: Pine 64 benchmarks - by g_t_j - 05-28-2016, 11:23 AM
RE: Pine 64 benchmarks - by tllim - 05-28-2016, 07:31 PM
RE: Pine 64 benchmarks - by g_t_j - 05-29-2016, 01:23 AM
RE: Pine 64 benchmarks - by tllim - 05-29-2016, 09:18 AM
RE: Pine 64 benchmarks - by norm24 - 03-15-2016, 11:26 PM
RE: Pine 64 benchmarks - by Andrew2 - 03-16-2016, 04:38 AM
RE: Pine 64 benchmarks - by Andrew2 - 03-16-2016, 06:04 AM
RE: Pine 64 benchmarks - by BarBrian - 03-28-2016, 11:22 PM
RE: Pine 64 benchmarks - by stealthbanana - 04-07-2016, 10:40 AM
RE: Pine 64 benchmarks - by TeaPack - 04-15-2016, 01:17 PM
RE: Pine 64 benchmarks - by tkaiser - 04-15-2016, 02:14 PM
RE: Pine 64 benchmarks - by TeaPack - 04-15-2016, 02:32 PM
RE: Pine 64 benchmarks - by tkaiser - 04-15-2016, 02:45 PM
RE: Pine 64 benchmarks - by TeaPack - 04-15-2016, 03:00 PM
  Pine A64+ mainline mipi-dsi Learnincurve 3 6,595 01-12-2021, 07:36 AM
Last Post: Learnincurve
  DietPi OS for PINE A64 MichaIng 0 9,179 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 5,487 10-02-2020, 11:38 AM
Last Post: mathiraj
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 15,744 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 19,352 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 6,622 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 6,080 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 5,144 05-09-2019, 05:42 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,270 03-30-2019, 06:48 AM
Last Post: ktaragorn
  motionEyeOS (PINE A64(+)) pineadmin 4 11,981 11-09-2018, 03:25 AM
