(ARCHIVED) Ubuntu Xenial Image (BSP Kernel)
#78
(04-03-2016, 08:20 AM)Andrew2 Wrote:
(04-03-2016, 07:37 AM)Luke Wrote: Please excuse my Linux illiteracy, but could you please briefly explain how to change hdmi_cts_compatibility to 1 or point me to a relevant article? cheers!
On longsleep's Xenial image it would be the following:
apt-get install device-tree-compiler
cd /boot/pine64/
dtc -I dtb -O dts -o sun50i-a64-pine64_dvi.dts sun50i-a64-pine64.dtb
sed -i 's/hdmi_cts_compatibility\ =\ <0x0>;/hdmi_cts_compatibility = <0x1>;/' sun50i-a64-pine64_dvi.dts
# check sun50i-a64-pine64_dvi.dts manually
cp -p sun50i-a64-pine64.dtb sun50i-a64-pine64_hdmi.dtb
dtc -I dts -O dtb -o sun50i-a64-pine64.dtb sun50i-a64-pine64_dvi.dts
reboot
With Arch almost the same except of getting the dtc binary (1st step above). With Android? Neither know nor care Smile
Unfortunately it's not that easy, since you have to adjust the .dts file and then rebuild u-boot for changes to take effect. So that's something not possible for unexperienced people ATM Sad
In case you make a backup of your card and know what you're doing you might try out the adjusted u-boot-with-spl.bin overwriting some parts of your SD card as outlined here: https://github.com/longsleep/build-pine6...ot_only.sh
I tried it out with my display and since it's HDMI black gets green as expected with Allwinner's BSP kernels but when the kernel takes over the settings are dropped (I also defined 720p for my tests) and I end up with 1080p and HDMI mode as it should be with the connected display. Obviously EDID works...
Much appreciated ! Will try this tonight Smile
Oh so it isn't possible to run hdmi-dvi currently without some more in-depth know-how ? Sad
RE: Ubuntu Xenial Image (BSP Kernel) - by peterz - 02-28-2016, 03:48 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by faddah - 04-04-2016, 10:09 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by shockr - 02-29-2016, 06:37 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by mane - 03-07-2016, 09:58 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by mane - 03-09-2016, 10:16 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by mane - 03-09-2016, 12:37 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 03-09-2016, 01:17 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by tllim - 03-09-2016, 01:40 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by peterz - 03-09-2016, 02:18 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by tllim - 03-09-2016, 02:23 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by tllim - 03-09-2016, 03:01 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by mane - 03-09-2016, 03:18 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by mane - 03-11-2016, 02:42 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 03-11-2016, 03:02 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by mane - 03-11-2016, 05:33 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by joey - 03-23-2016, 11:54 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by joey - 03-28-2016, 08:59 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Jagmn - 03-30-2016, 10:54 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 03-30-2016, 01:52 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 03-30-2016, 02:13 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 03-30-2016, 02:21 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Jagmn - 03-30-2016, 02:27 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 03-30-2016, 02:38 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 03-30-2016, 04:35 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by koopa2k - 03-30-2016, 05:47 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 03-31-2016, 04:40 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 03-31-2016, 10:30 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 03-31-2016, 12:30 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-01-2016, 04:23 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Jagmn - 04-01-2016, 04:49 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-01-2016, 04:57 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-01-2016, 06:32 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-01-2016, 11:03 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by ViperVi - 04-01-2016, 11:10 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Xyntec - 04-02-2016, 10:43 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Xyntec - 04-02-2016, 11:36 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-03-2016, 07:00 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-03-2016, 08:39 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-03-2016, 09:23 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pirin - 04-22-2016, 04:40 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pirin - 04-23-2016, 06:24 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-03-2016, 07:37 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Andrew2 - 04-03-2016, 08:20 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-03-2016, 10:21 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by yusijs - 04-03-2016, 06:49 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by faddah - 04-03-2016, 09:19 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by faddah - 04-04-2016, 05:00 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by faddah - 04-07-2016, 01:16 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by faddah - 04-07-2016, 02:03 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by joey - 04-03-2016, 09:34 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-04-2016, 09:13 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-05-2016, 04:40 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by faddah - 04-05-2016, 11:29 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-06-2016, 05:44 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-07-2016, 07:28 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Hart - 04-08-2016, 10:35 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by eender - 04-04-2016, 05:29 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by luggi - 04-05-2016, 11:10 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by joey - 04-06-2016, 12:06 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Hart - 04-08-2016, 01:54 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pirin - 04-12-2016, 10:27 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Vidiot - 04-12-2016, 10:48 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pirin - 04-15-2016, 07:24 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pirin - 04-21-2016, 07:16 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-21-2016, 08:44 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by joe - 04-22-2016, 05:28 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by joe - 04-22-2016, 11:16 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by joe - 04-22-2016, 05:43 AM
Ubuntu Xenial Image (BSP Kernel) - by rolfl - 04-24-2016, 08:35 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 04-26-2016, 05:47 PM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 05-07-2016, 02:56 PM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 05-09-2016, 04:25 AM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 05-09-2016, 06:14 AM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 05-09-2016, 09:34 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by frewind - 05-09-2016, 01:42 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 05-09-2016, 12:58 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by jl_678 - 05-10-2016, 08:26 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jl_678 - 05-10-2016, 11:30 AM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 05-12-2016, 12:28 PM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 05-15-2016, 11:30 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Rumen - 05-31-2016, 12:00 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 05-31-2016, 10:47 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-01-2016, 12:28 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-01-2016, 10:09 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-01-2016, 11:16 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-01-2016, 11:34 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-01-2016, 12:18 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by 3lliot - 06-02-2016, 11:05 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by 3lliot - 06-05-2016, 04:37 PM
Ubuntu Xenial Image (BSP Kernel) - by rolfl - 06-08-2016, 11:08 PM
Ubuntu Xenial Image (BSP Kernel) - by rolfl - 06-09-2016, 05:27 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-16-2016, 06:45 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by jdt - 06-17-2016, 04:44 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by xalius - 06-17-2016, 12:14 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by jl_678 - 06-22-2016, 05:51 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by yodermk - 07-09-2016, 02:39 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by beh0211 - 07-17-2016, 08:20 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by ricblue - 07-17-2016, 01:44 PM
Ubuntu Xenial Image (BSP Kernel) - by hhbarnes - 07-22-2016, 06:23 AM
Ubuntu Xenial Image (BSP Kernel) - by hhbarnes - 07-25-2016, 04:26 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by xalius - 07-25-2016, 05:28 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by MrKings - 01-02-2017, 09:38 PM
Ubuntu Xenial Image (BSP Kernel) - by hhbarnes - 07-25-2016, 12:25 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Artyom - 07-28-2016, 05:41 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by xalius - 07-28-2016, 08:31 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by pekapa - 07-29-2016, 08:30 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Artyom - 07-29-2016, 10:39 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by pekapa - 07-29-2016, 04:19 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by wahlmat - 07-29-2016, 05:34 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by wahlmat - 08-01-2016, 03:28 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by xalius - 08-01-2016, 03:31 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by wahlmat - 08-02-2016, 10:11 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Artyom - 08-11-2016, 10:22 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by rallar8 - 08-11-2016, 01:34 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Artyom - 08-11-2016, 09:52 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Artyom - 08-13-2016, 09:17 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by sgjava - 08-12-2016, 11:36 AM
USB wifi with RTL8188CUS - by sgjava - 08-12-2016, 07:36 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by polv89 - 10-10-2016, 02:32 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pander - 10-16-2016, 08:24 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pander - 10-17-2016, 12:46 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pander - 10-18-2016, 03:36 AM
Ubuntu Xenial Image (BSP Kernel) - by RaspiBit - 11-02-2016, 01:14 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pander - 11-03-2016, 07:09 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by tllim - 12-18-2016, 03:24 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by sup - 01-01-2017, 11:55 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by utdrmac - 02-01-2017, 10:51 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by utdrmac - 02-01-2017, 11:52 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by sihil - 03-13-2017, 06:22 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by dkryder - 03-14-2017, 06:15 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by sihil - 03-15-2017, 03:31 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by Pander - 05-17-2017, 05:20 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by AA666 - 07-15-2017, 12:13 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by dkryder - 07-16-2017, 02:05 AM
RE: Ubuntu Xenial Image (BSP Kernel) - by AA666 - 07-16-2017, 01:08 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 01-02-2018, 03:55 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by dkryder - 01-03-2018, 06:30 PM
RE: Ubuntu Xenial Image (BSP Kernel) - by Luke - 01-31-2018, 11:58 AM
  Ubuntu server 20.04 request phi0x 2 5,413 12-30-2020, 08:02 PM
Last Post: phi0x
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 21,678 08-30-2020, 10:35 AM
Last Post: jrronimo
  Kickstarter P64 with LCD, working image? MostHated 1 4,519 01-04-2020, 10:32 AM
Last Post: igorp
  USB Wireless Drivers with Longsleep Linux Kernel jacobscarter 15 25,050 03-06-2019, 02:26 PM
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 4,862 02-01-2019, 05:09 AM
  SPI on ubuntu IlyaM 4 9,275 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 8,707 05-18-2018, 03:33 PM
Last Post: Luke
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 4,034 04-16-2018, 03:09 PM
Last Post: Rocklobster
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 11,019 02-01-2018, 09:45 AM
Last Post: Partymack711
  PPTP doesnt work with ubuntu escovedo 2 8,812 08-23-2017, 09:28 AM
Last Post: gilbertotcc
